I am trying to use a nv_imx219 (CONFIG_NV_VIDEO_IMX219) driver in Jetpack 35.1. I am facing problem with the active_l and active_t properties which are missing in the device tree file.
[ 5.861006] imx219 10-0010: sensor_common_parse_image_props:active_l property missing
[ 5.861345] imx219 10-0010: Failed to read mode0 image props
[ 5.861531] imx219 10-0010: Could not initialize sensor properties.
[ 5.861891] imx219 10-0010: Failed to initialize imx219
[ 5.862056] imx219 10-0010: tegra camera driver registration failed
[ 5.862508] imx219: probe of 10-0010 failed with error -61
The code checking the properties are present below:
static int sensor_common_parse_image_props(
struct device *dev, struct device_node *node,
struct sensor_image_properties *image)
const char *temp_str;
int err = 0, ret = 0;
const char *phase_str, *mode_str;
int depth;
char pix_format[24];
u32 value = 0;
err = read_property_u32(node, "active_l",
&image->left);
if (err) {
dev_err(dev, "%s:active_l property missing\n", __func__);
goto fail;
err = read_property_u32(node, "active_t",
&image->top);
if (err) {
dev_err(dev, "%s:active_t property missing\n", __func__);
goto fail;
Also these two properties are missing in the Sensor programming guide:
https://docs.nvidia.com/jetson/archives/r35.1/DeveloperGuide/text/SD/CameraDevelopment/SensorSoftwareDriverProgramming.html
Could you please let me know what should I keep values of these two properties in imx219 dt file?
