ActivityFlushAll returned error code
I have both a 2080 Ti and a 50 HX graphics card installed on my machine. I attempted to remotely connect to this machine using the NVIDIA system tools to analyze a program running on it. This program runs on the 2080 Ti and does not utilize the 50 HX. However, after profiling the target, I received the following two errors:
  1. ActivityFlushAll returned 42: CUPTI_ERROR_CMP_DEVICE_NOT_SUPPORTED
  2. ActivityFlushAll returned 39: CUPTI_ERROR_MULTIPLE_SUBSCRIBERS_NOT_SUPPORTED
    Additionally, I am unable to see the CUDA HW subplot in the timeline view.
    nvidia-bug-report.log.gz (606.3 KB)
To clarify, you were connecting to the remote machine and launching a application there and then you saw these messages? (Rather than attempting to connect to an already running process?)
When Nsight Systems collects CUDA api and kernel information we use CUPTI, which is another NVIDIA tool. Unfortunately only one collector can use a CUPTI instance. It looks like what happened was that something else was already using CUPTI system wide and Nsys therefore could not use it.
My guess on likely candidate would be DCGM if you were running that.
Yes, I was connecting to the remote machine and launching a application there.
I didn’t install DCGM there. The OS is Ubuntu 22.04.4 LTS. I just installed CUDA 12.6 on it. Nothing else.
When I removed the 50HX GPU from the server, everything returned to normal.
@mjain is that CTK CUPTI expected to work on the 50 HX
The NVIDIA 50HX is a Crypto Mining Processor (CMP), and NVIDIA developer tools, such as profilers and debuggers, do not support these devices. As a result, CUPTI returns the error code CUPTI_ERROR_CMP_DEVICE_NOT_SUPPORTED when attempting to interact with them.
Ref: NVIDIA Development Tools Solutions - ERR_NVCMPGPU: | NVIDIA Developer
Is there any way to install the 50HX GPU without interfering with my use of tools like Nsight Systems to analyze programs running on the 2080Ti?
@liuyi, is there a way for @SparkHu to tell the tools only to use the one GPU?
