AD-HOC Network issue TX1
I’m creating an ad-hoc network on my Jetson TX1, when the network is activated the jetson stops, it doesn’t continue working. I’ve created the network and saved it, now when the Jetson turned on it stops at the start.
A serial console would provide a lot of information as to just where things stop. Would it be possible for you to set up a serial console and show a log of boot? See:
http://elinux.org/Jetson/TX1_Serial_Console
http://www.jetsonhacks.com/2015/12/01/serial-console-nvidia-jetson-tx1/
Would you share the steps you’ve used to set it up ?
What do you mean by ‘when the network is activated the jetson stops, it doesn’t continue working’ ?
