ADC on Jetson Orin Nano
I need some analog to digital converter (ADC) on Jetson Orin Nano. Does any of the GPIOs on the carrier board connector can be used as ADC?
Thank you
Ramin
Hi ramin.rahamim,
Are you using the devkit or custom board for Orin Nano?
Which ADC module are you using? What’s the communication interface? (I2C? SPI?)
Hello Kevin,
I ordered Jetson EVB:
Carrier Board:
Module Board:
I just need two ADCs and I am wondering if any of the Jetson GPIOs can be used as ADC too.
Do you mean the Orin Nano developer kit?
Jetson Orin Nano can work with ADC module, but we need to know the exact model of ADC module you use and the interface you need.
You should also request your vendor of ADC for porting guide or resources.
