Hello, NVpeople.
I try to get 4ch sound from ADC PCM1865.
But I get no record.
my dts:
tegra_sound: sound {
compatible = “nvidia,tegra-audio-t186ref-mobile-rt565x”;
nvidia,model = “tegra-snd-t186ref-mobile-rt565x”;
nvidia,num-codec-link = <1>;
nvidia,mclk-fs = <256>;
nvidia,audio-routing =
“x VINL1”, “x Mic”,
“x VINR1”, “x Mic”,
“x VINL2”, “x Mic”,
“x VINR2”, “x Mic”,
“x VINL3”, “x Mic”,
“x VINR3”, “x Mic”,
“x VINL4”, “x Mic”,
“x VINR4”, “x Mic”,
“x Capture”, “x ADC1”,
“x Capture”, “x ADC2”;
nvidia,xbar = <&tegra_axbar>;
mclk-fs = <256>;
hdr40_snd_link_i2s: i2s_dai_link1: nvidia,dai-link-1 {
link-name = “codec_pcm1865”;
cpu-dai = <&tegra_i2s1>;
codec-dai = <&pcm1865>;
cpu-dai-name = “I2S1”;
codec-dai-name = “pcm1865-aif”;
format = “dsp_b”;
bitclock-slave;
frame-slave;
bitclock-noninversion;
frame-noninversion;
bit-format = “s32_le”;
srate = <48000>;
num-channel = <4>;
ignore_suspend;
name-prefix = “x”;
status = “okay”;
PCM1865 registers registers.txt (569.4 KB)
dmesg:
nvidia@nvidia:~$ dmesg | grep -E “(pcm1|asoc)”
[ 21.376805] pcm186x 0-004a: probing a PCM186x device
[ 21.382011] pcm186x 0-004a: supplies requested successfully
[ 21.389822] pcm186x 0-004a: supplies enabled
[ 21.394227] pcm186x 0-004a: device reset
[ 21.398443] pcm186x 0-004a: PCM186X_CLK_CTRL
[ 21.402964] pcm186x 0-004a: PCM186X_LRK_DIV
[ 21.407394] pcm186x 0-004a: PCM186X_TDM_TX_SEL
[ 21.412085] pcm186x 0-004a: ADC1 Left Mux set to {VIN1P,VIN1M}[DIFF]
[ 21.418686] pcm186x 0-004a: ADC1 Right Mux set to {VIN2P,VIN2M}[DIFF]
[ 21.425373] pcm186x 0-004a: ADC1 Left Mux set to {VIN3P,VIN3M}[DIFF]
[ 21.431976] pcm186x 0-004a: ADC2 Right Mux set to {VIN4P,VIN4M}[DIFF]
[ 21.438425] pcm186x 0-004a: supplies disabled
[ 21.442784] pcm186x 0-004a: switching type
[ 21.446891] pcm186x 0-004a: codec registered as pcm1865
[ 21.595648] tegra-asoc: sound: ADMAIF1 ↔ ADMAIF1 mapping ok
[ 21.595724] tegra-asoc: sound: ADMAIF2 ↔ ADMAIF2 mapping ok
[ 21.595802] tegra-asoc: sound: ADMAIF3 ↔ ADMAIF3 mapping ok
[ 21.595868] tegra-asoc: sound: ADMAIF4 ↔ ADMAIF4 mapping ok
[ 21.595936] tegra-asoc: sound: ADMAIF5 ↔ ADMAIF5 mapping ok
[ 21.596003] tegra-asoc: sound: ADMAIF6 ↔ ADMAIF6 mapping ok
[ 21.596066] tegra-asoc: sound: ADMAIF7 ↔ ADMAIF7 mapping ok
[ 21.596133] tegra-asoc: sound: ADMAIF8 ↔ ADMAIF8 mapping ok
[ 21.596199] tegra-asoc: sound: ADMAIF9 ↔ ADMAIF9 mapping ok
[ 21.596264] tegra-asoc: sound: ADMAIF10 ↔ ADMAIF10 mapping ok
[ 21.596332] tegra-asoc: sound: ADMAIF11 ↔ ADMAIF11 mapping ok
[ 21.596398] tegra-asoc: sound: ADMAIF12 ↔ ADMAIF12 mapping ok
[ 21.596464] tegra-asoc: sound: ADMAIF13 ↔ ADMAIF13 mapping ok
[ 21.596534] tegra-asoc: sound: ADMAIF14 ↔ ADMAIF14 mapping ok
[ 21.596599] tegra-asoc: sound: ADMAIF15 ↔ ADMAIF15 mapping ok
[ 21.596664] tegra-asoc: sound: ADMAIF16 ↔ ADMAIF16 mapping ok
[ 21.596737] tegra-asoc: sound: ADMAIF17 ↔ ADMAIF17 mapping ok
[ 21.596802] tegra-asoc: sound: ADMAIF18 ↔ ADMAIF18 mapping ok
[ 21.596874] tegra-asoc: sound: ADMAIF19 ↔ ADMAIF19 mapping ok
[ 21.596940] tegra-asoc: sound: ADMAIF20 ↔ ADMAIF20 mapping ok
[ 21.599375] pcm186x 0-004a: pcm186x_set_fmt() format=0x4005
[ 21.604965] pcm186x 0-004a: operating in slave mode
[ 21.622068] pcm186x 0-004a: ## pcm186x_set_bias_level: 0 → 1
[ 27.099203] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.105076] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=1
[ 27.113339] pcm186x 0-004a: pcm186x: width : 16
[ 27.118232] pcm186x 0-004a: ASoC: can’t set pcm1865-aif hw params: -22
[ 27.124821] tegra-asoc: sound: ASoC: PRE_PMU: x Capture-I2S1 DAP Receive event failed: -22
[ 27.133515] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.269882] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.276689] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 27.292127] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.297960] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=2
[ 27.306195] pcm186x 0-004a: pcm186x: width : 16
[ 27.314228] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.429782] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.435914] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 27.556631] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.562433] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=1
[ 27.570634] pcm186x 0-004a: pcm186x: width : 16
[ 27.575250] pcm186x 0-004a: ASoC: can’t set pcm1865-aif hw params: -22
[ 27.581790] tegra-asoc: sound: ASoC: PRE_PMU: x Capture-I2S1 DAP Receive event failed: -22
[ 27.590477] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.599671] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.605789] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 27.613060] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.618958] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=2
[ 27.627152] pcm186x 0-004a: pcm186x: width : 16
[ 27.632488] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.638789] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.644985] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 27.756569] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.762373] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=1
[ 27.770565] pcm186x 0-004a: pcm186x: width : 16
[ 27.775118] pcm186x 0-004a: ASoC: can’t set pcm1865-aif hw params: -22
[ 27.781654] tegra-asoc: sound: ASoC: PRE_PMU: x Capture-I2S1 DAP Receive event failed: -22
[ 27.790263] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.801968] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.808061] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 27.817066] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 27.822921] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=2
[ 27.831180] pcm186x 0-004a: pcm186x: width : 16
[ 27.836638] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 27.845291] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 27.851453] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
[ 28.007817] pcm186x 0-004a: ## pcm186x_set_bias_level: 1 → 2
[ 28.013721] pcm186x 0-004a: pcm186x_hw_params() rate=44100 format=0x2 width=16 channels=2
[ 28.021997] pcm186x 0-004a: pcm186x: width : 16
[ 28.027371] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 3
[ 33.183837] pcm186x 0-004a: ## pcm186x_set_bias_level: 3 → 2
[ 33.190229] pcm186x 0-004a: ## pcm186x_set_bias_level: 2 → 1
nvidia@nvidia:~$ echo 0 | sudo tee /sys/kernel/debug/tracing/trace
0
nvidia@nvidia:~$ echo 0 | sudo tee /sys/kernel/debug/tracing/events/enable
0
nvidia@nvidia:~$ echo 1 | sudo tee /sys/kernel/debug/tracing/tracing_on
1
nvidia@nvidia:~$ echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_path/enable
1
nvidia@nvidia:~$ echo 1 | sudo tee /sys/kernel/debug/tracing/events/asoc/snd_soc_dapm_widget_power/enable
1
nvidia@nvidia:~$ arecord -Dhw:tegrasndt186ref,0 -c 4 -r 48000 -f S32_LE -d 5 out.wav
Recording WAVE ‘out.wav’ : Signed 32 bit Little Endian, Rate 48000 Hz, Channels 4
nvidia@nvidiasudo cat /sys/kernel/debug/tracing/trace
trace.txt (268.8 KB)
