I have a project for counting people in a shop, I saw some example but I would want to try to do by myself and understand what I do.
I konw to script in php/mysql/jquery/… but I just start with python and AI.
I have install jetson-inference.
I have created a new directory “example” and I run it with
cd jetson-inference
docker/run.sh --volume ~/example:/example
cd /example/
python3 example.py
In example.py I have add this script :
Blockquote
#!/usr/bin/python3
import numpy as np
import cv2
import jetson.inference
import jetson.utilssetup the network we are using
net = jetson.inference.detectNet(“ssd-mobilenet-v2”, threshold=0.5)
cap = cv2.VideoStream(src=1).start()
cap = cv2.VideoCapture(1)
cap = cv2.VideoCapture(‘video.mp4’)
cap.set(3,640)
cap.set(4,480)while (True):
ret, frame = cap.read()
frame = cv2.resize(frame, (640, 480))
w = frame.shape[1]
h = frame.shape[0]
# to RGBA
# to float 32
input_image = cv2.cvtColor(frame, cv2.COLOR_RGB2RGBA).astype(np.float32)
# move the image to CUDA:
input_image = jetson.utils.cudaFromNumpy(input_image)detections = net.Detect(input_image, w, h) count = len(detections) print("detected {:d} objects in image".format(len(detections))) for detection in detections: print(detection) # print out timing info net.PrintProfilerTimes() # Display the resulting frame numpyImg = jetson.utils.cudaToNumpy(input_image, w, h, 4) # now back to unit8 result = numpyImg.astype(np.uint8) # Display fps fps = 1000.0 / net.GetNetworkTime() font = cv2.FONT_HERSHEY_SIMPLEX line = cv2.LINE_AA cv2.putText(result, "FPS: " + str(int(fps)) + ' | Detecting', (11, 20), font, 0.5, (32, 32, 32), 4, line) cv2.putText(result, "FPS: " + str(int(fps)) + ' | Detecting', (10, 20), font, 0.5, (240, 240, 240), 1, line) cv2.putText(result, "Total: " + str(count), (11, 45), font, 0.5, (32, 32, 32), 4, line) cv2.putText(result, "Total: " + str(count), (10, 45), font, 0.5, (240, 240, 240), 1, line) # show frames cv2.imshow('frame', result) if cv2.waitKey(1) & 0xFF == ord('q'): break
When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
Blockquote
And now I want to add cv2.line to split in two spaces my frame.
I have try to put it out of the while and inside but nothing appen.
with this :
cv2.line(frame, (0, h // 2), (w, h // 2), (0, 255, 255), 2)
Could you help me for that, thanks in advance
