Add dsexample>cvmat to the buffer (input of the sgie)
I want to modify each bbox before the sgie. I am using gstdexample.cpp to concatenate the bbox detected by the pgie and my target in order to make person recognition in the sgie.
I am able to make the concatenation with :
in_mat =
cv::Mat (dsexample->processing_height, dsexample->processing_width,
CV_8UC4, dsexample->inter_buf->surfaceList[0].mappedAddr.addr[0],
dsexample->inter_buf->surfaceList[0].pitch);
out_mat = cv::Mat (cv::Size(dest_width, dest_height), CV_8UC3);
cv::cvtColor (in_mat, out_mat, CV_RGBA2BGR);
target = cv::imread(“target.jpg”);
cv::hconcat(out_mat, target, dual_mat);
#if (CV_MAJOR_VERSION >= 4)
cv::cvtColor (dual_mat, *dsexample->cvmat, cv::COLOR_RGBA2BGR);
But I don’t know how to add dual_mat to the buffer and give it as input to the sgie.
How can I do that?
Best regards
You will need to add the updated bounding box into metadata.
For example:
// Process to get the output
output =
    DsExampleProcess (dsexample->dsexamplelib_ctx,
    dsexample->cvmat->data);
// Attach the metadata for the full frame
attach_metadata_full_frame (dsexample, frame_meta, scale_ratio, output, i);
i++;
free (output);
The output will be added into metadata and passed into sgie.
So you can try to convert the dual_mat into DsExampleOutput, and attach to the metadata also.
HI,
Thanks, one question. For adding bounding box into metadata, which function should I used? attach_metadata_full_frame() or attach_metadata_object()? BEcause in your example you use attach_metadata_full_frame().
Best regards
There are two mechanism in the dsexample: full frame or crop bbox.
Please use the corresponding attach function for each use case.
if (dsexample->process_full_frame) {
} else {
    attach_metadata_object (dsexample, obj_meta, output);
It is controlled by the config file directly:
[ds-example]
<b>full-frame=0</b>
Thanks, ti works. But I have one more problem.
How can I normalize the data in order to feed the sgie? Beacuse, initially I though that this step was automatically done by the pipeline, and later I realize that it is not done. I try the following code:
img2.convertTo(*dsexample->cvmat, CV_32F, 1.0 / 255, 0);
But it does not work.
Regards
