• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 5:20.09
• Issue Type( questions, new requirements, bugs): New Requirement
From the next release of Deepstream, can it be shipped along with the Gst-python overrides? There are a lot of useful overrides like make_and_add() and link_many() which should simplify the code, make it more pythonic and readable
(the link_many()
function from C-GStreamer does not have a direct binding in Python)
If this is being done, perhaps the Python-examples on Nvidia-ai-iot github can also be updated
This can be done in many ways, an example Dockerfile that makes use of the GS-python bindings can be seen here. Do note that the overrides have to be installed exactly where Gstreamer has setup the python bindings. In case on Ubuntu it was installed using OS packages (apt-get install …), then you might have to make a symbolic link to link the installation directories (as seen in the first RUN
command of the Dockerfile I linked^
