My TX2 installed the JetPack 4.3 version of the system, I want to add the TLV320AIC32X4 audio driver.I’ve seen it here:Add I2S audio in the source code of JetPack4.2
Is there any difference between jetpack 4.3 and jetpack 4.2?About configuration!
Hello!
For the most part if should be very similar. However, with regard to setting up the pins on the 40-pin header, you can now use the Jetson-IO tool to do this instead of editing the cfg file if you so wish.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide%2Fhw_setup_jetson_io.html%23
Regards,
Jon
Thank you for your reply. We will try.
