This seems to be a Isaac 2022.2.0 bug as mentioned in Slack. This issue has been fixed internally and will be included in the next Isaac release.
For now, the temporary fix is to add an arbitrary object with semantic labels:
cone = rep.create.cone(semantics=[("class", "cone")])
Based on your code, the modified code should look like:
camera = Camera(
prim_path="/World/camera",
position=np.array([0.0, 0.0, 25.0]),
frequency=20,
resolution=(256, 256),
orientation=rot_utils.euler_angles_to_quats(np.array([0, 90, 0]), degrees=True),
my_world.scene.add_default_ground_plane()
my_world.reset()
camera.initialize()
i = 0
camera.add_motion_vectors_to_frame()
camera.add_pointcloud_to_frame()
while simulation_app.is_running():
my_world.step(render=True)
print(camera.get_current_frame())
