1、I don’t konw how to change the dts, can you give me some suggestion?
2、can you give me the driver for LAN743x for version 32.6.1 on AGX xavier,because the driver what we find on the
internet can not work on it.
Thank you very much.
There shouldn’t be any device tree change. Please check if lspci can detect them or not.
We don’t provide vendor driver. If our kernel source does not have it, then we don’t have it either. Please consult with the vendor to get their driver.
Hi ,
OK, I will check the driver for the vendor
Now I use the lspci,but I can not find anything information
Does it mean there is a problem with our hardware?
PCI seems to be able to recognize two different devices.
Do I just need to add the lan743x driver to make it work?
By the way, why did I only recognize two lan7430, but we took three?
In addition, why can our network card only negotiate the 100 megabit rate, but not the Gigabit rate
Thank you
I am not sure about your exact question here. Why are you able to see network card but you also said you need lan743x driver? I mean if you don’t have this driver, then your network interface won’t be up. You won’t have a 100 M speed problem here.
Where is the third card connected here? Do you have a schematic?
1、Sorry, I didn’t describe it clearly. I have a total of four network ports, three of which are through lan743x and there is no driver, so there is no connection. One is designed completely with reference to Xavier dome board, which can be connected, but can only obtain 100m network.
Hi
While I enable the pcie@14160000, the pcie will init failed, and the yphy0 uphy8 will also not find
this is dmesg, Can you give me some suggest add_pcie_1416.log (80.6 KB)
there is some other information:
we use the kernel5.10 version(Not yet published for you)
it include the LAN743x driver, and we have 3 eth worked,now just the uphy8 not work
