I use Jetson Xavier NX with below OS spec :
$ cat /etc/nv_tegra_release
# R35 (release), REVISION: 5.0, GCID: 35550185, BOARD: t186ref, EABI: aarch64, DATE: Tue Feb 20 04:46:31 UTC 2024
$ cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
I want add device tree overlay by editing /boot/extlinux/extlinux.conf file as below :
$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
FDT /boot/dtb/kernel_tegra194-p3668-0001-p3509-0000.dtb
FDT_OVERLAY /boot/tegra194-p3668-all-p3509-0000-adafruit-sph0645lm4h.dtbo
INITRD /boot/initrd
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 video=efifb:off nospectre_bhb
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
# sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
# LABEL backup
# MENU LABEL backup kernel
# LINUX /boot/Image.backup
# FDT /boot/dtb/kernel_tegra194-p3668-0001-p3509-0000.dtb
# INITRD /boot/initrd
# APPEND ${cbootargs}
The device tree file is presented and permission set to 644 :
$ ls -lh /boot/tegra194-p3668-all-p3509-0000-adafruit-sph0645lm4h.dtbo
-rw-r--r-- 1 root root 1.1K Feb 20 2024 /boot/tegra194-p3668-all-p3509-0000-adafruit-sph0645lm4h.dtbo
but after reboot I get this Error in booting time :
Jetson UEFI firmware (version 202210.4-d00a5d3a-dirty built on 2024-10-16T05:00:
52+03:30)
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
OpenAndReadUntrustedFileToBuffer: Failed to open _OVERLAY \boot\tegra194-p3668-a
11-p3509-0000-adafruit-sph06451m4h.dtbo: Not Found
ExtLinuxBoot:sds Failed to Authenticate boot\extlinux\extlinux.conf (Not Found)
LATLauncher: Unable to boot via extlinux: Not Found
LATLauncher: Attempting Kernel Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
Why dose this error occur and bootloader is unable to find device tree file?
How to solve it?
