Adding new robot model without gripper
I am following the “Adding a new manipulator” turorial (Adding a New Manipulator — Omniverse IsaacSim) but with a different robot URDF. The URDF only contains the robot links and no grippers. I have created the USD model with this URDF. I now want to load the USD in Isaac Sim using the python API. How would the python code look like in this case? The example codes I have found so far, they all load manipulators that have grippers. How would the python code look like if the manipulator has no gripper?
Thanks in advance.
Ok, the solution to this problem is discussed here Unable to use world.reset() using a SingleManipulator without a gripper.
