I’m not sure what happened, it looks like your DeepStream has some installation issues.
Please try reinstalling or using Docker, or upgrading to DS-7.0
Yes I did try using docker, everything is fine in docker but I faced a new issue when I tried to containerize, I have raised a new forum about it.
This is the new issue I am facing.
Generally speaking, the --net=host parameter will directly use the host’s network for communication.
docker run --volume video_volume --volume video_volume -e video=video.mp4 --gpus all --network dock-db-test -it ae10514a69f6 bash
BTW I was able to ping postgres and kafka in my second container after I created the network.
ping kafka_docker
PING kafka_docker (172.22.0.2) 56(84) bytes of data.
64 bytes from test-kafka_docker-1.dock-db-test (172.22.0.2): icmp_seq=1 ttl=64 time=0.135 ms
64 bytes from test-kafka_docker-1.dock-db-test (172.22.0.2): icmp_seq=2 ttl=64 time=0.091 ms
ping postgres
PING postgres (172.22.0.3) 56(84) bytes of data.
64 bytes from test-postgres-1.dock-db-test (172.22.0.3): icmp_seq=1 ttl=64 time=0.153 ms
64 bytes from test-postgres-1.dock-db-test (172.22.0.3): icmp_seq=2 ttl=64 time=0.062 ms
The docker network is another problem. Please test it in the same docker.
# start docker and run the kafka server
docker run --gpus all -it --rm --name for-kafka-test --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.4 nvcr.io/nvidia/deepstream:6.4-gc-triton-devel
# open a new terminal run deepstream-test-4.py, if you need more terminal for the docker, execute it again
docker exec -it for-kafka-test bash
