• Hardware Platform : DGPU
• DeepStream Version : 6.2.0 **
• TensorRT Version : 8.5.2.2
• NVIDIA GPU Driver Version : 530.30.02
• Issue Type
Not able to include Nvstreamdemux into the python pipeline
•Requirement :
write the python implementation of the command line
Reference command line in gstreamer:
gst-launch-1.0 -e filesrc location=$file_path ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux batch-size=1 width=1280 height=720 name=m ! nvstreamdemux name=d d.src_0 ! nvv4l2h264enc ! h264parse ! qtmux ! filesink location=$output_file enable-last-sample=0
Equivalent python implementation
import time
import sys
import os
import gi
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from common.bus_call import bus_call
import time
import pyds
def cb_new_pad(qtdemux, pad, data):
h264parser = data
name = pad.get_name()
if "video_0" in name and pad.link(h264parser.get_static_pad("sink")):
print(f"Could not link {name} pad of qtdemux to sink pad of h264parser")
def main(source_path,dest_path):
Gst.init(None)
pipeline = Gst.Pipeline()
source = Gst.ElementFactory.make("filesrc", "file-source")
demux = Gst.ElementFactory.make("qtdemux", "demux")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
encoder = Gst.ElementFactory.make("nvv4l2h264enc", "nvv4l2-h264-encoder")
h264parser2 = Gst.ElementFactory.make("h264parse", "h264-parser2")
qtmux = Gst.ElementFactory.make("qtmux", "qtmux")
sink = Gst.ElementFactory.make("filesink", "filesink")
nvstreamdemux = Gst.ElementFactory.make("nvstreamdemux", "nvstream-demux")
sink.set_property("location", dest_path)
source.set_property('location', source_path) # replace it with your mp4 file
streammux.set_property('batch-size', 1)
if os.environ.get('USE_NEW_NVSTREAMMUX') != 'yes':
streammux.set_property('width', 1280)
streammux.set_property('height', 720)
pipeline.add(source)
pipeline.add(demux)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(nvstreamdemux)
pipeline.add(encoder)
pipeline.add(h264parser2)
pipeline.add(qtmux)
pipeline.add(sink)
print("Linking elements in the Pipeline \n")
source.link(demux)
demux.connect("pad-added", cb_new_pad, h264parser)
h264parser.link(decoder)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write(" Unable to get the sink pad of streammux \n")
srcpad = decoder.get_static_pad("src")
if not srcpad:
sys.stderr.write(" Unable to get source pad of decoder \n")
srcpad.link(sinkpad)
streammux.link(nvstreamdemux)
sinkpad_nvdemux = encoder.get_request_pad("sink_0")
if not sinkpad_nvdemux:
sys.stderr.write(" Unable to get the sink pad of encoder\n")
srcpad_nvdemux = nvstreamdemux.get_static_pad("src")
if not srcpad_nvdemux:
sys.stderr.write(" Unable to get source pad of nvdemux\n")
srcpad_nvdemux.link(sinkpad_nvdemux)
encoder.link(h264parser2)
h264parser2.link(qtmux)
qtmux.link(sink)
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect ("message", bus_call, loop)
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
pipeline.set_state(Gst.State.NULL)
I am unable to link the nvstreammux-> Nvstreamdemux->encoder.
Can u help in rectifying the issue ?
