Adding OpenCV to Jetpack system path
Hello all,
I have built OpenCV from source with Cuda support successfully. The python detects OpenCV correctly and returns its version, however, Jetson_release -v returns that OpenCV is not installed. Is there way to add the built OpenCV from source to system that can be detected using the command Jetson_release -v
The binary jetson_release is not in default release. We don’t see it by searching root path:
nvidia@nvidia-desktop:/$ sudo find -name *jetson_release*
You may check which vendor provides the binary and get help from the vendor.
Thanks DaneLLL
You are right Jetson_release belongs to this provider GitHub - rbonghi/jetson_stats: 📊 Simple package for monitoring and control your NVIDIA Jetson [Xavier NX, Nano, AGX Xavier, TX1, TX2]
I have opened issue there
