Adding pcie peripherals to Orin NX with JP6
We have a custom carrier board for Orin NX with RTL8111 on PCIE port 3 and M2 PCIe module on PCIE port 2. I have enables C7 and C9, and changed ODMDATA to 9 in p3767.conf.common
I am using p3509-a02-p3767-0000.conf to flash the board. This file references p3768-0000-p3767-0000-a0.conf which specifies the device tree file tegra234-p3768-0000+p3767-0000-nv.dtb. I also set TBCDTB_FILE=“${DTB_FILE}” to remove DTB from UEFI.
I checked pinmux and all the signals are correct by default.
I have followed the developer guide but I am stuck at how to define the PHY node. The developer guide shows example as follows;
Configuration Option 2 (Device Tree)
pcie@141e0000 { /* C7x1 node */
    status = "okay";
    phys = <&p2u_gbe_0>;
    phy-names = "p2u-0";
pcie@140c0000 { /* C9x1 */
    status = "okay";
    phys = <&p2u_gbe_1>;
and when I add this to the C7 and C9 PCIe controller nodes I get this error when recompiling the dts
"ERROR (phandle_references): /bus@0/pcie@141e0000: Reference to non-existent node or label “p2u_gbe_0”
The developer guide references this file to edit pcie in sources but it does not exist in sources or file system.
“pipe2uphy DT nodes are defined in SoC DT at $(TOP)/hardware/nvidia/soc/t234/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi”
So I am decompiling the tegra234-p3768-0000+p3767-0000-nv.dtb, editing the dts, and recompiling to dtb.
Without making the phy changes, it recompiles and I can flash the device and I can see the peripherals in lspci, but I do not get an IP address to the RTL8111 , which appears as Eth1 in ifconfig on the device.
Can you tell me how to edit the phy nodes correctly.
The original device tree already provided a overlay to enable C7 and C9. You should read it first.
Can you provide a link to the document has this information that I should read first.
tegra234-p3767-sku-handling.dtsi
I could not find any file called tegra234-p3767-sku-handling.dtsi in latest jetpack 6 (jetson-linux-r3640).
There is an overlay specified in p3768-0000-p3767-0000-a0.conf which is
OVERLAY_DTB_FILE+=“,tegra234-p3768-0000+p3767-0000-dynamic.dtbo”
inside this file it specifies pcie node overlays for C7 and C9
so is there anything that needs to be edited to get PCIe ports 2 and 3 to work in the latest jetpack 6 on a custom carrier board.
For every Jetson, the source code are public source code tarball that you should download from our website… you won’t find it in the BSP directory.
I am saying that I dont find this file in the repo for jetson-linux-r3640
These are the files downloaded and extracted
Jetson_Linux_R36.4.0_aarch64.tbz2
Tegra_Linux_Sample-Root-Filesystem_R36.4.0_aarch64.tbz2
public_sources.tbz2
using these extraction commands for public sources
tar xjf public_sources.tbz2
cd Linux_for_Tegra/source
tar xjf kernel_src.tbz2
Is there some other download I am missing ?
NVIDIA kernel dts files are inside of kernel_oot_modules_src.tbz2
Thanks Wayne, can you direct me to the procedure for applying this dsti
I am not asking you to apply this dtsi directly. I am just telling that this dtsi has an example to enable C7 and C9.
When I use the C7 and C9 details in example file tegra234-p3767-sku-handling.dtsi and add to overlay file tegra234-p3768-0000+p3767-0000-dynamic.dtbo then I get these errors.
Is there another step required to add the missing references …
overlay.dts:57.39-61.27: ERROR (phandle_references): /p3767-sku-handling-fragment@6/overlay/pcie@141e0000: Reference to non-existent node or label “p2u_gbe_0”
overlay.dts:64.39-70.27: ERROR (phandle_references): /p3767-sku-handling-fragment@6/overlay/pcie@140c0000: Reference to non-existent node or label “vdd_1v8_ao”
overlay.dts:64.39-70.27: ERROR (phandle_references): /p3767-sku-handling-fragment@6/overlay/pcie@140c0000: Reference to non-existent node or label “p2u_gbe_1”
You can just trace the code to find out where the reference is.
The references come from this file "tegra234-p3767-sku-handling.dtsi " for C7 and C9 configuration, specifically,
                    /* C7 */
                    pcie@141e0000 {
                            num-lanes = <1>;
                    /* C9 */
                    pcie@140c0000 {
                            status = "okay";
                            vddio-pex-ctl-supply = <&vdd_1v8_ao>;
                            num-lanes = <1>;
This is the same as the online developer guide example for editing pcie as per my original question. I was stuck at the same point which is why I asked this question.
Do I need to create these phandles p2u_gbe_1, p2u_gbe_0 , if so, is there a guide to what is required and how to implement it.
Trace more down to the code to find out where p2u_gbe_1 and p2u_gbe_0 are defined…
It is already defined somehwere. It just your code didn’t include that.
This is basic code tracing thing. There is no document needed for such easy thing…
@WayneWWW why not just answer the question? Wouldn’t that take as long as typing the responses you did already that offered zero help?
I think the required two nodes are in hardware/nvidia/t23x/nv-public/tegra234.dtsi:
as follows:
p2u_gbe_0: phy@3f20000 {
compatible = “nvidia,tegra234-p2u”;
reg = <0x0 0x03f20000 0x0 0x10000>;
reg-names = “ctl”;
#phy-cells = <0>;
p2u_gbe_1: phy@3f30000 {
reg = <0x0 0x03f30000 0x0 0x10000>;
reg-names = “ctl”;
#phy-cells = <0>;
But let’s confirm that with the people here that are paid to help users. What do you think @WayneWWW ?
