Adding RGB-D sensor to robotic end-effector
Hey there,
I use Isaac Sim 4.1.0 and OmniGibson, and I already add kuka iwwa7 arm and robotiq 2f-85 gripper to Isaac Sim. Then I tried to add Realsense D435i sensor to the wrist. However, there are only 455 sensor intergrated in Isaac Sim (but with the error of missing reference found, I also cannot add it successfully).
Could you tell me how to add Realsense D435i sensor (or maybe other RGB-D sensor) to the robot in Isaac Sim? Maybe directly in the software or through the urdf file?
Thanks a lot in advance!
Best regards,
Yunfeng
Could you share the details of this issue? Have you experienced the same problem in Isaac Sim 4.2?
You can use the URDF importer to bring in a USD asset for your desired camera to obtain the mesh. Alternatively, you could create a USD with camera prims positioned appropriately. Then, from a script or extension, add the necessary annotators (such as distance to image plane, RGB, etc.) to the render products associated with those camera prims.
