Administrator Login Issues on Jetson Nano
Currently you could use the console and see if you could login the console.
Method 1. Run ctrl+alt + f1~6 and see if the console shows up on your screen.
Method 2. Enable serial console.
If you can login, then please try to add new user/password to the system and see if you can login desktop again.
