hi,
after reading the configuration of the ADV7280m this is the best that I could get to.
I have attached the driver that I have slightly modified, the device tree (camera-dummy), gstreamer debug data, terminal log, and trace data.
adv7180.c (48.6 KB) camera-dummy.dtsi (3.6 KB) gstreamer debug (12.0 KB) Terminal Log.txt (9.3 KB) trace (72.6 KB)
It looks like there might be format issues “libv4l2: error set_fmt gave us a different result then try_fmt!”
Moreover if I run the following line
gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x-raw, format=(string)UYVY,width=720,height=576,framerate=(fraction)25/1’ ! xvimagesink
it fails to start a window with the encoded stream,
Only If I run the following for while:
gst-launch-1.0 v4l2src --gst-debug=GST_DEBUG=*:3,v4l2src:5 device=/dev/video0 ! nvvidconv ! fakesink
and then
Then it starts to display alternatly green screen and then an artifical screen from the ADV7280m, a movie is attached. I do not understnad why.
Another thing that I have noticed was running the following line
v4l2-compliance -d /dev/video0
I get a failure, which I think is because dv_timing reserved struct is not nullified, but I do, so I do not know the reason:
Driver Info:
Driver name : tegra-video
Card type : vi-output, adv7180 6-0021
Bus info : platform:15700000.vi:0
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix FormatCompliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OKAllow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OKDebug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OKInput ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
fail: v4l2-test-io-config.cpp(174): TIMINGS cap not set, but could still get timings
fail: v4l2-test-io-config.cpp(239): Timings check failed for input 0.
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: FAIL
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 6 Private Controls: 7Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
test VIDIOC_G/S_PARM: OK (Not Supported)
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
test VIDIOC_S_FMT: OK
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OKTest input 0:
Total: 42, Succeeded: 41, Failed: 1, Warnings: 0
Any support will be appreciated.
