Adv7282a-m does not detect with i2cdetect
adv7282a-m does not detect on my jetson xavier nx with i2cdetect command, although i can get and set values using i2cget/i2cset commands.
Do i need to change anything in the device tree so that it can be detected on i2cdetect command?
hello SR663,
did you meant the device functionality still works normally?
Hi JerryChang, I just need to know how to detect the chip using i2cdetect command
hello SR663,
you may refer to Port Binding section to examine device tree settings.
please also check To verify the port binding result to examine the node.
