Advice on aerodynamic simulation
I would like to try to simulate the design of PC fan blades that make the lowest noise possible.
The program should itself suggest a suitable fan blade profile and number of blades, after specifying the fan diameter, desired airflow volume, maximum fan revolution speed and maximum desired noise value in dB.
Can you advise me which the latest CUDA software to use with sample code? (e.g. Omniverse Modulus Extension, NVIDIA PhysX SDK 4.1 etc.)
Hi, did you solve the problem with Aerodynamic ?
