Thanks for that clarification. However, jetson-inference is referenced in jetson-containers under the jetson-containers/packages/cv/jetson-inference. When I try to build this Docker from jetson-containers with the command jetson-contaienrs run $(autotag jetson-inferece), it gives an error related to a numpy version incompatibilty:
[00:31:26] [25/25] Testing jetson-inference (jetson-inference:r36.4.tegra-aarch64-cu126-22.04-jetson-inference)24 stages completed in 32m44s at 00:31:26
│ > TESTING jetson-inference:r36.4.tegra-aarch64-cu126-22.04-jetson-inference │
docker run -t --rm --network=host --privileged --runtime=nvidia \
--volume /ssd/repos/jetson-containers/packages/cv/jetson-inference:/test \
--volume /ssd/repos/jetson-containers/data:/data \
jetson-inference:r36.4.tegra-aarch64-cu126-22.04-jetson-inference \
/bin/bash -c '/bin/bash /test/test_utils.sh
testing jetson-utils...
--2025-09-05 07:31:28-- https://raw.githubusercontent.com/dusty-nv/jetson-inference/master/data/images/granny_smith_1.jpg
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.110.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 547142 (534K) [image/jpeg]
Saving to: ‘/tmp/apple.jpg’
/tmp/apple.jpg 100%[===================>] 534.32K 3.36MB/s in 0.2s
2025-09-05 07:31:29 (3.36 MB/s) - ‘/tmp/apple.jpg’ saved [547142/547142]
A module that was compiled using NumPy 1.x cannot be run in
NumPy 2.2.6 as it may crash. To support both 1.x and 2.x
versions of NumPy, modules must be compiled with NumPy 2.0.
Some module may need to rebuild instead e.g. with 'pybind11>=2.12'.
If you are a user of the module, the easiest solution will be to
downgrade to 'numpy<2' or try to upgrade the affected module.
We expect that some modules will need time to support NumPy 2.
Traceback (most recent call last): File "/opt/jetson-inference/build/aarch64/bin/cuda-examples.py", line 26, in <module>
from jetson_utils import (cudaAllocMapped, cudaConvertColor, cudaCrop,
File "/usr/lib/python3.10/dist-packages/jetson_utils/__init__.py", line 4, in <module>
from jetson_utils_python import *
AttributeError: _ARRAY_API not found
SystemError: initialization of jetson_utils_python raised unreported exception
[00:31:29] =====================================================================================
[00:31:29] `jetson-containers build` failed after 1969.2 seconds (32.8 minutes)
[00:31:29] Error: Command 'docker run -t --rm --network=host --privileged --runtime=nvidia --volume /ssd/repos/jetson-containers/packages/cv/jetson-inference:/test --volume /ssd/repos/jetson-containers/data:/data jetson-inference:r36.4.tegra-aarch64-cu126-22.04-jetson-inference /bin/bash -c '/bin/bash /test/test_utils.sh' 2>&1 | tee /ssd/repos/jetson-containers/logs/20250904_235834/test/25-1_jetson-inference_r36.4.tegra-aarch64-cu126-22.04-jetson-inference_test_utils.sh.txt; exit ${PIPESTATUS[0]}' returned non-zero exit status 1.
File "/usr/lib/python3.10/runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.10/runpy.py", line 86, in _run_code
exec(code, run_globals)
File "/ssd/repos/jetson-containers/jetson_containers/tag.py", line 58, in <module>
image = find_container(args.packages[0], prefer_sources=args.prefer, disable_sources=args.disable, user=args.user, quiet=args.quiet)
File "/ssd/repos/jetson-containers/jetson_containers/container.py", line 668, in find_container
return build_container('', package) #, simulate=True)
File "/ssd/repos/jetson-containers/jetson_containers/container.py", line 246, in build_container
test_container(container_name, pkg, simulate, build_idx=idx)
File "/ssd/repos/jetson-containers/jetson_containers/container.py", line 456, in test_container
status = subprocess.run(cmd.replace(_NEWLINE_, ' '), executable='/bin/bash', shell=True, check=True)
File "/usr/lib/python3.10/subprocess.py", line 526, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command 'docker run -t --rm --network=host --privileged --runtime=nvidia --volume /ssd/repos/jetson-containers/packages/cv/jetson-inference:/test --volume /ssd/repos/jetson-containers/data:/data jetson-inference:r36.4.tegra-aarch64-cu126-22.04-jetson-inference /bin/bash -c '/bin/bash /test/test_utils.sh' 2>&1 | tee /ssd/repos/jetson-containers/logs/20250904_235834/test/25-1_jetson-inference_r36.4.tegra-aarch64-cu126-22.04-jetson-inference_test_utils.sh.txt; exit ${PIPESTATUS[0]}' returned non-zero exit status 1.
-- Error: return code 1
V4L2_DEVICES: --device /dev/video0 --device /dev/video1 --device /dev/video2 --device /dev/video3 --device /dev/video4 --device /dev/video5 --device /dev/video6 --device /dev/video7
### DISPLAY environmental variable is already set: ":1"
localuser:root being added to access control list
### ARM64 architecture detected
### Jetson Detected
SYSTEM_ARCH=tegra-aarch64
+ docker run --runtime nvidia --env NVIDIA_DRIVER_CAPABILITIES=compute,utility,graphics -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /ssd/repos/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/video0 --device /dev/video1 --device /dev/video2 --device /dev/video3 --device /dev/video4 --device /dev/video5 --device /dev/video6 --device /dev/video7 --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-7 --device /dev/i2c-9 --name jetson_container_20250905_003130
docker: 'docker run' requires at least 1 argument
Usage: docker run [OPTIONS] IMAGE [COMMAND] [ARG...]
See 'docker run --help' for more information
