# ASUS Ascent GX10 (DGX Spark): repeated PCIe Surprise Down on both ConnectX-7 root ports → mlx5 recovery hang → hard reset (one unit only)
## Setup
- 3× ASUS Ascent GX10 (GB10). Two at a time run one vLLM tensor-parallel (TP=2) model over RoCEv2, using both ConnectX-7 PCIe functions (`rocep1s0f0` + `roceP2p1s0f0`), direct QSFP DAC, 200G.
- Ubuntu 24.04 / DGX OS, kernel **6.17.0-1031-nvidia** (pinned — see note 2 below), NVIDIA driver **580.173.02**
- BIOS `GX10DGX.0105.2026.0505.1153`, ConnectX-7 fw **28.45.4028** (PSID `NVD0000000087`, board “NVIDIA DGX Spark P4242”)
- EC `0x02000006`, SoC fw `0x03000007`, USB-C PD fw `0x516` on all units
- `iommu.passthrough=1` (see note 1)
## The problem
**Unit A** (always the same chassis) has had **11 events in 5 days**. **Units B and C**, on the same cable and workload, have **never logged a PCIe error**.
Signature, the same every time:
pcieport 0002:00:00.0: AER: Correctable error … [ 0] RxErr (First)
pcieport 0000:00:00.0: AER: Uncorrectable (Fatal) … Transaction Layer
pcieport 0000:00:00.0: device [10de:22ce] error status/mask=00000020/04400000
pcieport 0000:00:00.0: [ 5] SDES (First)
pcieport 0002:00:00.0: AER: Uncorrectable (Fatal) … [ 5] SDES
mlx5_core 0000:01:00.0: mlx5_pci_err_detected … pci channel state = 2
mlx5_core 0000:01:00.0: mlx5_error_sw_reset: PCI channel offline, stop waiting for NIC IFC
mlx5_core 0002:01:00.1: poll_health: Fatal error 1 detected / PCI slot is unavailable
mlx5_core 0000:01:00.0 enp1s0f0np0: NETDEV WATCHDOG … transmit queue timed out
watchdog: BUG: soft lockup - CPU#3 stuck for 130s! [irq/329-aerdrv]
… pci_find_ext_capability ← pci_save_state ← mlx5_pci_slot_reset ← report_slot_reset ← pcie_do_recovery ← aer_isr
- **Both** CX7 root ports report Surprise Down within ~50 ms. The two x4 links are separate, so the whole NIC is dropping off the bus.
- The AER recovery thread then spins on config reads to the missing device. After that come hundreds of soft lockups, and the box stays hung (up to 95 min) until it’s power-cycled.
- The peer node only logs QSFP `Link down` at the same instant. It has no PCIe or mlx5 errors.
- No AER has ever come from the NVMe, the 10G Realtek or the Wi-Fi domains.
**Event times (CDT):**
| Date | Times |
| Sep 21 | 18:25 |
| Sep 22 | 01:22, 02:22, 07:15, 08:20, 09:23, 10:51, 12:40, 15:44, 19:57 (TX timeout only) |
| Sep 25 | 13:57 |
**Observations:**
- **Startup timing:** 10 of 11 came within ~5 min of the vLLM container starting (NCCL/RDMA setup), often during restart loops. But Sep 25 hit while the engine was idle, blocked at rendezvous with essentially no NIC traffic.
- **Cabling:** every event was on a **direct DAC** link. Nothing happened in ~25 h through a switch, though that was light load.
- **Things that didn’t stop it:**
IOMMU translated or passthrough
PD firmware mismatched (`0x1` on the peer) or matched (`0x516`)
Different peer node
- **Cable ruled out as the failing part:** QSFP PHY counters (CRC/symbol/FEC/discards) are all 0, and the failure is on the PCIe side.
- **Slot power:** every unit logs `mlx5_pcie_event: Detected insufficient power on the PCIe slot (27W)` on every boot. `DISABLE_SLOT_POWER_LIMITER` is not supported on this firmware.
**Firmware error records (BERT)** appear after each reset. MediaTek vendor section `3c1e3f4b-1e1a-43df-af28-59820e958e3c` (“MTKID”), severity corrected. There are two variants:
…a451e0a4 c2964450 0ae9a1c7 0000fa95 00 a0 … 80 (after most storm hangs)
…a451e0a4 c2964450 0ae9a1c7 0080fa95 00 20 … 40 (other resets)
Linux can’t decode these.
**Unexplained reset:** Unit A also reset once while idle and healthy (Sep 25 04:06). There was nothing in the kernel log, no pstore dump and no button press. The peer saw the link down for 46 s, versus 12–15 s for a normal reboot.
**Current test:** Unit B has been replaced by Unit C on the same cable. It has been clean for ~21 h so far, but we’ve seen 66 h quiet stretches before.
## Questions
1. Is Surprise Down on both CX7 root ports (`10de:22ce`) a known issue on GX10 / DGX Spark, and is there a firmware or BIOS fix?
2. Can someone decode the MTKID BERT records above? We’d like to know whether they indicate a power or reset cause.
3. Is this RMA territory for Unit A? We can supply full logs, pstore dumps and BERT dumps.
4. The AER recovery path hangs the whole system instead of failing the NIC. Is that expected with mlx5 on this platform?
## Side findings that may help others
1. **`iommu.passthrough=0` (the stock `/etc/default/grub.d/iommu.cfg`) caps ConnectX-7 DMA at ~13 Gb/s per PCIe function.**
This showed up in loopback, cross-node, RDMA read/write/send and TCP.
The SMMU was not faulting.
With `iommu.passthrough=1` we get **~112 Gb/s per function and ~196 Gb/s across both** (`ib_write_bw`).
For TP=2 LLM serving this cut prefill time-to-first-token ~27% (32K: 23.5 s → 17.1 s).
Is the translated-mode cap expected?
2. **Kernel 7.0.0-1019-nvidia:** `ibv_reg_mr` on CUDA pinned host memory fails with ENOMEM ~40% of the time (4/10 runs, sometimes at the very first 4 MB MR). This breaks NCCL. 6.17.0-1031 had 0/10 failures.
3. **`dgx-spark-fieldiag` 2.0.4** depends on `ofed-scripts`, which isn’t in any DGX OS repo. It is in the DOCA host repo (`linux.mellanox.com/public/repo/doca/latest/ubuntu24.04/arm64-sbsa/`). Its signing key is the repo’s own `doca_keyring.gpg` (`DC726C5E41B9CC50`), not `GPG-KEY-Mellanox.pub`.
BERT RECORDS:
BERT (ACPI Boot Error Record Table) records — head gx10-3502 (ASUS GX10, BIOS GX10DGX.0105.2026.0505.1153)
Each record is reported by firmware at boot and describes an error from the PREVIOUS boot. Times US Central (CDT).
Generated 2026-09-25 21:40:21 CDT from the persistent systemd journal (kernel ring buffer at boot).
SUMMARY (head) — variant = differing bytes at payload offsets 0x2C-0x3D; firmware section GUID 3c1e3f4b-1e1a-43df-af28-59820e958e3c (MediaTek ‘MTKID’, not decoded by Linux)
Storm lines = SDES / mlx5_pci_err_detected / soft lockup / NETDEV WATCHDOG lines in the boot that ended.
reported at variant boot that ended (duration) storm lines note
Sep 20 19:15:29 A Sep 19 12:44–19:12 (1828 min) 0
Sep 21 16:26:27 A Sep 20 19:18–16:23 (1265 min) 0
Sep 22 02:19:27 B Sep 21 20:03–02:16 (373 min) 264
Sep 22 02:33:32 B Sep 22 02:21–02:30 (9 min) 43
Sep 22 07:07:39 A Sep 22 02:35–07:05 (269 min) 0
Sep 22 08:13:28 B Sep 22 07:11–08:09 (58 min) 249
Sep 22 08:27:40 A Sep 22 08:20–08:25 (5 min) 27
Sep 22 08:50:48 A Sep 22 08:41–08:47 (5 min) 0
Sep 22 09:27:12 A Sep 22 09:00–09:24 (24 min) 4
Sep 22 10:55:41 A Sep 22 09:36–10:53 (77 min) 5
Sep 22 11:03:32 A Sep 22 10:57–11:00 (2 min) 0
Sep 22 14:06:01 B Sep 22 11:25–14:03 (158 min) 386
Sep 22 16:54:10 B Sep 22 14:09–16:51 (162 min) 314
Sep 25 04:08:44 A Sep 23 23:22–04:06 (1723 min) 0 unexplained reset 04:06, lane loaded & idle, no pstore dump
Sep 25 14:03:01 B Sep 25 04:08–14:00 (592 min) 10
Worker gx10-efa8: one record only, reported Sep 11 22:19 CT (boot right after its fwupd SoC/EC firmware update at Sep 11 22:09 CT):
22:19:01.965229 gx10-efa8 kernel: ACPI: BERT 0x0000000087065D98 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
22:19:02.004372 gx10-efa8 kernel: BERT: Error records from previous boot:
22:19:02.004382 gx10-efa8 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
22:19:02.004393 gx10-efa8 kernel: [Hardware Error]: event severity: corrected
22:19:02.004402 gx10-efa8 kernel: [Hardware Error]: Error 0, type: corrected
22:19:02.004412 gx10-efa8 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
22:19:02.004421 gx10-efa8 kernel: [Hardware Error]: section length: 0x3e
22:19:02.004430 gx10-efa8 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
22:19:02.004440 gx10-efa8 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
22:19:02.004450 gx10-efa8 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0100fa95 ..Q.PD…
22:19:02.004459 gx10-efa8 kernel: [Hardware Error]: 00000030: 00 80 00 00 00 00 00 00 00 00 00 00 00 80 …
22:19:02.004468 gx10-efa8 kernel: BERT: Total records found: 1
(variant C: …0100fa95 00 80 … 80)
Observation: A and B do not separate storm crashes from non-storm resets — both follow storms. Decoding needs ASUS/MediaTek.
Reported at boot -64 starting Sep 20 19:15:29 | previous boot’s last journal entry: Sep 20 19:12:50 | variant A (…0080fa95 00 20 … 40)
19:15:29.398979 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
19:15:29.436040 gx10-3502 kernel: BERT: Error records from previous boot:
19:15:29.436050 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
19:15:29.436060 gx10-3502 kernel: [Hardware Error]: event severity: corrected
19:15:29.436070 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
19:15:29.436081 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
19:15:29.436091 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
19:15:29.436103 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
19:15:29.436115 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
19:15:29.436125 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
19:15:29.436144 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
19:15:29.436153 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -61 starting Sep 21 16:26:27 | previous boot’s last journal entry: Sep 21 16:23:51 | variant A (…0080fa95 00 20 … 40)
16:26:27.719713 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
16:26:27.759364 gx10-3502 kernel: BERT: Error records from previous boot:
16:26:27.759373 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
16:26:27.759383 gx10-3502 kernel: [Hardware Error]: event severity: corrected
16:26:27.759393 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
16:26:27.759402 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
16:26:27.759412 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
16:26:27.759422 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
16:26:27.759433 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
16:26:27.759442 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
16:26:27.759453 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
16:26:27.759462 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -55 starting Sep 22 02:19:27 | previous boot’s last journal entry: Sep 22 02:16:44 | variant B (…0000fa95 00 a0 … 80)
02:19:27.111556 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
02:19:27.153013 gx10-3502 kernel: BERT: Error records from previous boot:
02:19:27.153022 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
02:19:27.153032 gx10-3502 kernel: [Hardware Error]: event severity: corrected
02:19:27.153042 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
02:19:27.153052 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
02:19:27.153062 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
02:19:27.153073 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
02:19:27.153085 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
02:19:27.153095 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
02:19:27.153105 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
02:19:27.153114 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -53 starting Sep 22 02:33:32 | previous boot’s last journal entry: Sep 22 02:30:52 | variant B (…0000fa95 00 a0 … 80)
02:33:32.894030 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
02:33:32.933068 gx10-3502 kernel: BERT: Error records from previous boot:
02:33:32.933078 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
02:33:32.933087 gx10-3502 kernel: [Hardware Error]: event severity: corrected
02:33:32.933097 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
02:33:32.933106 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
02:33:32.933116 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
02:33:32.933126 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
02:33:32.933137 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
02:33:32.933147 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
02:33:32.933157 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
02:33:32.933167 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -51 starting Sep 22 07:07:39 | previous boot’s last journal entry: Sep 22 07:05:01 | variant A (…0080fa95 00 20 … 40)
07:07:39.876143 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
07:07:39.915864 gx10-3502 kernel: BERT: Error records from previous boot:
07:07:39.915874 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
07:07:39.915884 gx10-3502 kernel: [Hardware Error]: event severity: corrected
07:07:39.915894 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
07:07:39.915904 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
07:07:39.915914 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
07:07:39.915924 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
07:07:39.915935 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
07:07:39.915945 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
07:07:39.915955 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
07:07:39.915964 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -49 starting Sep 22 08:13:28 | previous boot’s last journal entry: Sep 22 08:09:59 | variant B (…0000fa95 00 a0 … 80)
08:13:28.047227 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
08:13:28.086260 gx10-3502 kernel: BERT: Error records from previous boot:
08:13:28.086270 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
08:13:28.086280 gx10-3502 kernel: [Hardware Error]: event severity: corrected
08:13:28.086289 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
08:13:28.086299 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
08:13:28.086308 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
08:13:28.086318 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
08:13:28.086329 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
08:13:28.086339 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
08:13:28.086350 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
08:13:28.086360 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -46 starting Sep 22 08:27:40 | previous boot’s last journal entry: Sep 22 08:25:33 | variant A (…0080fa95 00 20 … 40)
08:27:40.146873 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
08:27:40.183091 gx10-3502 kernel: BERT: Error records from previous boot:
08:27:40.183101 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
08:27:40.183110 gx10-3502 kernel: [Hardware Error]: event severity: corrected
08:27:40.183119 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
08:27:40.183129 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
08:27:40.183138 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
08:27:40.183148 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
08:27:40.183159 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
08:27:40.183169 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
08:27:40.183178 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
08:27:40.183188 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -37 starting Sep 22 08:50:48 | previous boot’s last journal entry: Sep 22 08:47:12 | variant A (…0080fa95 00 20 … 40)
08:50:48.066754 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
08:50:48.105649 gx10-3502 kernel: BERT: Error records from previous boot:
08:50:48.105658 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
08:50:48.105668 gx10-3502 kernel: [Hardware Error]: event severity: corrected
08:50:48.105677 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
08:50:48.105687 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
08:50:48.105696 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
08:50:48.105706 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
08:50:48.105717 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
08:50:48.105726 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
08:50:48.105736 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
08:50:48.105745 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -31 starting Sep 22 09:27:12 | previous boot’s last journal entry: Sep 22 09:24:55 | variant A (…0080fa95 00 20 … 40)
09:27:12.354309 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
09:27:12.393463 gx10-3502 kernel: BERT: Error records from previous boot:
09:27:12.393473 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
09:27:12.393483 gx10-3502 kernel: [Hardware Error]: event severity: corrected
09:27:12.393493 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
09:27:12.393503 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
09:27:12.393512 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
09:27:12.393522 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
09:27:12.393533 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
09:27:12.393543 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
09:27:12.393553 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
09:27:12.393563 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -25 starting Sep 22 10:55:41 | previous boot’s last journal entry: Sep 22 10:53:27 | variant A (…0080fa95 00 20 … 40)
10:55:41.225832 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
10:55:41.265113 gx10-3502 kernel: BERT: Error records from previous boot:
10:55:41.265123 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
10:55:41.265133 gx10-3502 kernel: [Hardware Error]: event severity: corrected
10:55:41.265142 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
10:55:41.265153 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
10:55:41.265164 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
10:55:41.265174 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
10:55:41.265185 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
10:55:41.265195 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
10:55:41.265204 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
10:55:41.265214 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -23 starting Sep 22 11:03:32 | previous boot’s last journal entry: Sep 22 11:00:00 | variant A (…0080fa95 00 20 … 40)
11:03:32.036379 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
11:03:32.073010 gx10-3502 kernel: BERT: Error records from previous boot:
11:03:32.073019 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
11:03:32.073029 gx10-3502 kernel: [Hardware Error]: event severity: corrected
11:03:32.073038 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
11:03:32.073049 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
11:03:32.073058 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
11:03:32.073068 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
11:03:32.073079 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
11:03:32.073088 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
11:03:32.073098 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
11:03:32.073107 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -11 starting Sep 22 14:06:01 | previous boot’s last journal entry: Sep 22 14:03:55 | variant B (…0000fa95 00 a0 … 80)
14:06:01.319239 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
14:06:01.359114 gx10-3502 kernel: BERT: Error records from previous boot:
14:06:01.359124 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
14:06:01.359133 gx10-3502 kernel: [Hardware Error]: event severity: corrected
14:06:01.359142 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
14:06:01.359152 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
14:06:01.359161 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
14:06:01.359171 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
14:06:01.359182 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
14:06:01.359192 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
14:06:01.359201 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
14:06:01.359211 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -9 starting Sep 22 16:54:10 | previous boot’s last journal entry: Sep 22 16:51:46 | variant B (…0000fa95 00 a0 … 80)
16:54:10.722777 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
16:54:10.762374 gx10-3502 kernel: BERT: Error records from previous boot:
16:54:10.762383 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
16:54:10.762393 gx10-3502 kernel: [Hardware Error]: event severity: corrected
16:54:10.762403 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
16:54:10.762412 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
16:54:10.762423 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
16:54:10.762433 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
16:54:10.762444 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
16:54:10.762453 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
16:54:10.762463 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
16:54:10.762473 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -2 starting Sep 25 04:08:44 | previous boot’s last journal entry: Sep 25 04:06:28 | variant A (…0080fa95 00 20 … 40)
04:08:44.686810 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
04:08:44.725306 gx10-3502 kernel: BERT: Error records from previous boot:
04:08:44.725316 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
04:08:44.725326 gx10-3502 kernel: [Hardware Error]: event severity: corrected
04:08:44.725335 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
04:08:44.725345 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
04:08:44.725355 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
04:08:44.725365 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
04:08:44.725374 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
04:08:44.725386 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0080fa95 ..Q.PD…
04:08:44.725397 gx10-3502 kernel: [Hardware Error]: 00000030: 00 20 00 00 00 00 00 00 00 00 00 00 00 40 . …@
04:08:44.725407 gx10-3502 kernel: BERT: Total records found: 1
Reported at boot -1 starting Sep 25 14:03:01 | previous boot’s last journal entry: Sep 25 14:00:46 | variant B (…0000fa95 00 a0 … 80)
14:03:01.075382 gx10-3502 kernel: ACPI: BERT 0x0000000087065D18 000030 (v01 MTKID MTKTABLE 00000001 CREA 00000001)
14:03:01.111772 gx10-3502 kernel: BERT: Error records from previous boot:
14:03:01.111782 gx10-3502 kernel: [Hardware Error]: It has been corrected by h/w and requires no further action
14:03:01.111791 gx10-3502 kernel: [Hardware Error]: event severity: corrected
14:03:01.111801 gx10-3502 kernel: [Hardware Error]: Error 0, type: corrected
14:03:01.111811 gx10-3502 kernel: [Hardware Error]: section type: unknown, 3c1e3f4b-1e1a-43df-af28-59820e958e3c
14:03:01.111820 gx10-3502 kernel: [Hardware Error]: section length: 0x3e
14:03:01.111830 gx10-3502 kernel: [Hardware Error]: 00000000: 000d0000 544d0000 0044494b 00000000 …MTKID…
14:03:01.111839 gx10-3502 kernel: [Hardware Error]: 00000010: 00000000 00000010 00000022 56190000 …"…V
14:03:01.111851 gx10-3502 kernel: [Hardware Error]: 00000020: a451e0a4 c2964450 0ae9a1c7 0000fa95 ..Q.PD…
14:03:01.111860 gx10-3502 kernel: [Hardware Error]: 00000030: 00 a0 00 00 00 00 00 00 00 00 00 00 00 80 …
14:03:01.111870 gx10-3502 kernel: BERT: Total records found: 1
