Aerial cuBB 26-1: repeated process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
I am debugging an issue with an Aerial cuBB + OAI gNB testbed on GH200. After starting the L1 container and OAI gNB container, cuBB repeatedly prints the following warning:
nv-cubb         | 03:21:21.720029 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.00 Mbps    0 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 0
nv-cubb         | 03:21:22.720008 CON timer_thread 0 [SCF.PHY] Cell  0 | DL    0.00 Mbps    0 Slots | UL    0.00 Mbps    0 Slots CRC   0 (     0) | Tick 2000
nv-cubb         | 03:21:22.738545 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.758526 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.778522 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.798522 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.818524 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.838524 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.858525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.878525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.898522 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.918525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
oai-gnb-aerial  | [03:21:22.998515] [NR_MAC] I Frame.Slot 128.0
oai-gnb-aerial  |
nv-cubb         | 03:21:22.938525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.958525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.978524 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:22.998536 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:23.018525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:23.038526 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:23.058524 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
nv-cubb         | 03:21:23.078525 WRN msg_processing 0 [SCF.PHY] process_dl_tx_request: PDU count mismatch DL_TTI=0 TX_DATA=1
Could you please advise how to resolve this warning?
Thank you.
configs.zip (7.2 KB)
Hi, we are seeing the same issue on Aerial cuBB 25-3 with GH server.
The stack comes up normally, OAI gNB connects to AMF, and the cell is in service, but cuBB repeatedly logs:
DL/UL remain at 0 Mbps.
We also tested fresh OAI ATB1.0_integration, ARC1.7, TDD/SSB changes, SLOT.response changes, and cuBB rebuilds, but the issue remains.
Please let us know if there is a solution to resolve this error.
Hi everyone,
This error typically indicates a FAPI version mismatch between your L1 and L2 builds.
Please try recompiling the cuBB system by enabling the FAPI 10.04 flag in your build script: -DSCF_FAPI_10_04=ON
Thanks,
Davide
