I just flashed the Jetson Tx2 and made an
sudo apt-get update && sudo apt-get upgrade
and after that i checked if any critical files where damged with
sha1sum -c /etc/nv_tegra_release
and it gave me one error:
/usr/lib/xorg/modules/extensions/libglx.so: FAILED
Is this critical? And how can i solve this?
The GUI will likely fail with this. The version intended to go there should be in “/usr/lib/aarch64-linux-gnu/tegra/libglx.so”, but the link to this gets overwritten. You can do this:
sudo -s
cd /usr/lib/xorg/modules/extensions
rm -f libglx.so
ln -sf /usr/lib/aarch64-linux-gnu/tegra/libglx.so .
exit
It somehow solved itself after a reboot.
after a reboot and a new check with
I get all Oks!
If i look at libglx.so 's location it gives me:
nvidia@tegra-ubuntu:/usr/lib/xorg/modules/extensions$ ll
total 8
drwxr-xr-x 2 root root 4096 Dec 12 15:48 ./
drwxr-xr-x 5 root root 4096 Dec 12 11:51 ../
lrwxrwxrwx 1 root root 42 Dec 12 15:48 libglx.so -> /usr/lib/aarch64-linux-gnu/tegra/libglx.so*
seem’s to be allright !?
