After building Kernel, the default value in make menuconfig disappears
Jetson Linux: 36.3、JetPack: 6.0
I currently have needs for Build Kernel and DTBs. I referred to the official steps and procedures.
https://docs.nvidia.com/jetson/archives/r36.3/DeveloperGuide/SD/Kernel/KernelCustomization.html
The following is the instruction flow I executed:
CURRENT_DIR=$PWD
cd JP6/Linux_for_Tegra/source
./generic_rt_build.sh "disable"
export CROSS_COMPILE=$HOME/l4t-gcc/aarch64--glibc--stable-2022.08-1/bin/aarch64-buildroot-linux-gnu-
make -C kernel
export INSTALL_MOD_PATH=$CURRENT_DIR/JP6/Linux_for_Tegra/rootfs/
sudo -E make install -C kernel
cp kernel/kernel-jammy-src/arch/arm64/boot/Image $CURRENT_DIR/JP6/Linux_for_Tegra/kernel/Image
export IGNORE_PREEMPT_RT_PRESENCE=1
export KERNEL_HEADERS=$PWD/kernel/kernel-jammy-src
make modules
sudo -E make modules_install
cd ..
sudo ./tools/l4t_update_initrd.sh
make dtbs
cp nvidia-oot/device-tree/platform/generic-dts/dtbs/* $CURRENT_DIR/JP6/Linux_for_Tegra/kernel/dtb/
The construction was successful, but when I executed make menuconfig in source/kernel/kernel-jammy-src again, many default values ​​were cancelled.
Why does this problem occur?
How to fix or restore default values
You need make savedefconfig:
So I need to execute make savedefconfig before make -C kernel,
After all steps are completed,
Execute cp defconfig arch/arm/configs/my_cool_defconfig again?
Like this:
make menuconfig
make savedefconfig
cp defconfig arch/arm/configs/defconfig
make -C kernel
make -C kernel
But if you execute it like this, it will interrupt with Error when make -C kernel.
Attached are the log files during execution.
BuildKernel_Error.log (29.0 KB)
這跟你執行的順序沒關係吧
問題是這一行
make[2]: *** No rule to make target 'debian/canonical-certs.pem', needed by 'certs/x509_certificate_list'.  Stop.
make[2]: *** Waiting for unfinished jobs....
還有你的config檔看起來問題很多
.config:5093:warning: symbol value 'm' invalid for GPIO_TPS68470
.config:6287:warning: symbol value 'm' invalid for RADIO_ADAPTERS
.config:6911:warning: symbol value 'm' invalid for DRM_GEM_SHMEM_HELPER
.config:7634:warning: symbol value 'm' invalid for SND_SOC_SOF_DEBUG_PROBES
.config:7677:warning: symbol value 'm' invalid for SND_SOC_SOF_HDA_PROBES
.config:10916:warning: override: SQUASHFS_DECOMP_MULTI changes choice state
.config:10917:warning: override: SQUASHFS_DECOMP_MULTI_PERCPU changes choice state
I modified the following two lines in defconfig
CONFIG_SYSTEM_TRUSTED_KEYS=""
CONFIG_SYSTEM_REVOCATION_KEYS=""
Then cp defconfig arch/arm64/configs/defconfig
After performing other steps of Build Kernel and DTBs, no errors occurred.
Thanks for the help!
In addition, my .config file contains the NV default value, which I have not modified, so I don’t know why these warnings occurred.
Hello @DaveYYY ,
Currently it becomes stuck during Flash (TimeOut)
Attached below the log file
flash_1-10_0_20240718-092030.log (9.7 KB)
Linux_for_Tegra\bootloader\generic\BCT\tegra234-mb2-bct-misc-p3767-0000.dts has been modified
tegra234-mb2-bct-misc-p3767-0000.txt (313 Bytes)
Please provide assistance, Thanks!
請抓serial console log
Flash_Timeout.log (291.1 KB)
我是說這個
Sorry, I’m using custom board
no Serial Console on it.
那你至少要把serial console接出來才能debug…
只要沒開進USB device mode 不管任何原因 host上都只會顯示time out
Hi @DaveYYY
I did not use make savedefconfig
Just add a few new additions to arch/arm64/configs/defconfig
No errors occurred in Build Kernel, DTBs, and Flash.
It’s because there are more than 5,000 defconfig projects generated by make savedefconfig
The default is only 1330
所以現在修好了?
