hi all,
please help!
It’s the jetson thor r38.4 + max96712 platform. Both vc-id and vc_id are 0 in dts file , and the data path is sensor → max96712 pipe2(VC0/ dst VC0) → CSI->VI, that is succeed.
But When i only config vc-id and vc_id are 2 and dst VC0 change to dst VC2, caputer-vi can not get any data, that is failure.
The vc_id/vc-id of DTS information is as follows:
fragment@0 {
target-path = "/";
__overlay__ {
tegra-capture-vi {
status = "okay";
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
lc305_vi_in0: endpoint {
status = "okay";
vc-id = <2>; <-----------------------
remote-endpoint = <&lc305_csi_out0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
status = "okay";
modules {
module0 {
status = "okay";
drivernode0 {
status = "okay";
fragment@1 {
target = <&nvcsi>;
__overlay__ {
status = "okay";
#size-cells = <0>;
num-channels = <1>;
channel@0 {
reg = <0>;
status = "okay";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
lc305_csi_in0: endpoint@0 {
status = "okay";
remote-endpoint = <&lc305_out0>;
port@1 {
reg = <1>;
status = "okay";
lc305_csi_out0: endpoint@1 {
status = "okay";
remote-endpoint = <&lc305_vi_in0>;
fragment@2 {
target = <&i2c3>;
__overlay__ {
status = "okay";
#size-cells = <0>;
lc305_a: lc305_a@42 {
status = "okay";
reg = <0x42>;
compatible = "lc305,isx031";
use_sensor_mode_id = "true";
cam-type = "RBG";
dser-link-port = "b";
st-vc = <0>;
nvidia,gmsl-dser-device = <&dser0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
lc305_out0: endpoint {
remote-endpoint = <&lc305_csi_in0>;
mode0 {
pixel_t = "yuv_yvyu16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "rggb";
vc_id = "2"; <-----------------------
dser0: max96712@6b {
status = "okay";
reg = <0x6b>;
reset-gpios = <&gpio_main CAM0_PWDN GPIO_ACTIVE_HIGH>;
could you help me, thanks.
