Hi
I use TX2, L4T32.4.3.configure sgtl5000 in tegra186-quill-common.dtsi,the audio is good runing.but can not use ctrl+alt+t shortcut key Open the terminal. I discovered that the reason has to do with closck= <&tegra_car Tegra186_CLK_AUD_MCLK>,How to solve this problem?
or Where are the shortcuts set in the device tree?
Hello!
Yes this is a known issue. We are investigating this but at the moment there is no known fix. We will provide an update when we know more.
Regards
Jon
