After converting from 400G DR4 to 4x 100G DR1, can connect x6 (MCX623106AN-CDAT) communicate?
Is it possible to convert a 400G DR4 to four 100G DR1s using a breakout cable, connect an optical module + MCX623106AN-CDAT to each 100G DR1, and communicate with the opposing 400G DR4?
400G DR4 -----------100G DR1 + optical module + connect x6 (MCX623106AN-CDAT)
       +-------100G DR1 + optical module + connect x6 (MCX623106AN-CDAT)
✔ Yes — if you really have:
A 400G DR4 port + appropriate breakout support on the switch/router and
A proper 400G DR4 transceiver that breaks out to 4×100GBASE‑DR1 and
Standard *breakout fiber + matching 100 G DR1 optics,
then each of the 4×100G lanes can connect to a 100G port on the MCX623106AN‑CDAT and those links will communicate.
❌ If the 400G side cannot actually send four independent 100G lanes (e.g., it’s fixed to 400G only), then the MCX623106AN‑CDAT cannot link to it, because it doesn’t understand a 400 G signal.
Thank you for your response.
Would the breakout via the switch be configured as shown in (1) below?
*Where the server and client are the communicating parties
■(1)
|  SWITCH |-----------------|                 |-----------------|----|
|         |  Optical Module |-------|---------|  Optical Module |NIC |server
|         |  400G DR4       |       |         |  100G DR1       |    |
|---------|                         |         |  100G DR1       |    |
                                    |---------|  Optical Module |NIC |client
                                    |         |  100G DR1       |    |
                                              |  100G DR1       |    |
We would like a configuration like the one in (2) below, but is it impossible to implement?
■(2)
 |----|-----------------|    |----------------|  SWITCH |-----------------|                 |-----------------|----|
 |NIC |  Optical Module |----| Optical Module |         |  Optical Module |-------|---------|  Optical Module |NIC |client
 |    |  400G DR4       |    | 400G DR4       |         |  400G DR4       |       |         |  100G DR1       |    |
 server                                       |         |                         |
        |         |  100G DR1       |    |
        |  100G DR1       |    |
