The device was unable to find the network card information. The source code was obtained through source_sync.sh and compiled using nvbuild.sh. The dmesg output is as follows.
ayxx@tegra-ubuntu:~$ sudo dmesg | grep eth
[sudo] password for ayxx:
[ 0.000000] psci: probing for conduit method from DT.
[ 4.475577] usbcore: registered new interface driver cdc_ether
[ 6.295923] optee: probing for conduit method.
[ 10.092037] nvethernet 6810000.ethernet: Adding to iommu group 51
[ 10.098620] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 10.106775] nvethernet 6810000.ethernet: failed to read MDIO address
[ 10.113322] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 10.120263] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 10.512685] nvethernet 6810000.ethernet: Ethernet MAC address: 3c:6d:66:b1:2d:d8
[ 10.520711] nvethernet 6810000.ethernet: macsec param in DT is missing or disabled
[ 10.528498] nvethernet 6810000.ethernet: Macsec not supported/Not enabled in DT
[ 10.537934] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 14.357594] using random self ethernet address
[ 14.362586] using random host ethernet address
[ 15.084344] using random self ethernet address
[ 15.088940] using random host ethernet address
[ 15.093738] mdio_bus 6810000.ethernet: MDIO device at address 0 is missing.
[ 15.100956] nvethernet 6810000.ethernet: failed to connect PHY
[ 15.107030] net eth0: ether_open: Cannot attach to PHY (error: -19)
[ 97.393112] mdio_bus 6810000.ethernet: MDIO device at address 0 is missing.
[ 97.400402] nvethernet 6810000.ethernet: failed to connect PHY
[ 97.406483] net eth0: ether_open: Cannot attach to PHY (error: -19)
