After flashing the Xavier nx production module, is there any way to install tensorRT, cuda, etc. other than using SDKManager?
I think the method of using SDKManager is not suitable for mass production. It means that each nx you want to produce needs a host pc.
I need another way.
Thank you.
An alternative is to download all the packages from SDKmanger first.
And install all of them with a custom script.
Can’t I install it with apt install?
Repositories are provided as shown in the picture below, right?
Thank you.
You can check this step:
https://docs.nvidia.com/jetson/jetpack/install-jetpack/index.html#install-jetpack
For limited storage:
sudo apt update
apt depends nvidia-jetpack | awk '{print $2}' | xargs -I {} sudo apt install -y {}
If you don’t have any free space problem, you can type these commands:
sudo apt update
sudo apt install nvidia-jetpack
Regards
