after i install face_recognition, it shows illegal command, pls teach me how to get it work?
thanks,
thanks,
Not sure if you a similar issue as below:
Would you mind to setup an environment variable and run the face_recognition again?
$ export OPENBLAS_CORETYPE=ARMV8
yes boss, it works after above command.
many thanks!
and if work RTSP by face_recognition, how can i output Chinese string name on video? it seems OPENCV doesn’t work chinese name.
You can use ImageFont
from PIL to achieve this.
Please check below page for the detailed information:
thank you boss and i will try PIL.
another question is when is pull RTSP stream by 1920*1080 for face recognition, shows resize( ) error and stops. problem is here:
small_frame = cv2.resize(frame, (0, 0), fx=0.25, fy=0.25)
how can i get it work normally by RTSP?
thanks!
It’s recommended to use Deepstream SDK for multimedia usage.
You can find the RTSP support below:
