After i2cset, nano can not boot and the serial port has no print information. When reflashing the nano with command “sudo ./flash.sh jetson-nano-emmc mmcblk0p1”, the terminal prints “Parsing board information failed.”
We use emmc nano board, without SD card.
hello clevor18,
may I know which I2C you’re programming to cause the issue?
BTW, you must put the board to enter forced-recovery mode for image flashing.
please check developer guide, To determine whether the developer kit is in Force Recovery mode.
thanks
