thank you.
We got a solution here. Is your device still there?
hi, WayneWWW,
yes, the device still here, i have contact the RMA and waiting email.
hi, WayneWWW,
what’s the solution, can you reply here? thank you.
After these binary, please add below to your board config.
tail jetson-nano-qspi-sd.conf
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
[b]BOARDID="3448";
FAB="100";
BOARDSKU="0000" ;
BOARDREV="C.0";[/b]
EMMC_CFG=flash_l4t_t210_spi_sd_p3448.xml;
BLBlockSize=1048576;
source "${LDK_DIR}/p3448-0000.conf.common";
T21BINARGS="--bins \"EBT cboot.bin; "
hi, WayneWWW,
i replace the nvtboot.tar.gz and update, it seems successful: http://101.200.50.71/test/host_update_command.txt
the uart log here: http://101.200.50.71/test/uart_output.txt
after command run finish, i reset the nano, the uart only output one byte: 0x00
can give some tips, thank you.
Can you boot up the device now? Any uart log? Do you mean it still hangs?
Could you find a HDMI monitor and connect to your nano?
hi, WayneWWW,
yes, it still hangs, i connect HDMI and output nothing, and uart output nothing also.
what’s your reproduce and test result?
thank you.
hi, WayneWWW,
Is there any other way to debug? i’ll send RMA tomarrow, before deliver we can do last test.
thank you.
Sorry that I missed the nvtboot.bin file. Please try this new tarball and reflash your device.
“nvtboot.bin” should be copied under "Linux_for_Tegra/bootlader/t210ref/ "
“nvtboot_recovery.bin” should be copied under “Linux_for_Tegra/bootloader/”
nvtboot.tar.gz (157 KB)
hi, WayneWWW,
i’ll test it ASAP, thank you
hi, WayneWWW,
after update, the jetson nano boot success, thank you.
i’ll close the issue.
best regards~
I have the same problem. I set eeprom mistakenly, and nano cannot boot now.
Is there any method to re-write eeprom in RCM?
Still failed!
Bus 001 Device 045: ID 0955:7f21 NVidia Corp.
# L4T BSP Information:
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
# DATE: Wed Mar 13 07:46:13 UTC 2019
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
Board ID(3448) version(100)
copying bctfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb)... done.
Making system.img...
populating rootfs from /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/rootfs ... sudo cp -vf ~done.
Sync'ing system.done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 5242880( 5 blks) ==> 28:5242892
1: SKP: 31457280( 30 blks) ==> 5242920:12
2: RAW: 1048576( 1 blks) ==> 5242932:1048588
3: SKP: 96468992( 92 blks) ==> 6291520:12
4: RAW: 1048576( 1 blks) ==> 6291532:1048588
5: SKP: 2097152( 2 blks) ==> 7340120:12
6: RAW: 28311552( 27 blks) ==> 7340132:28311564
7: SKP: 1048576( 1 blks) ==> 35651696:12
8: RAW: 35651584( 34 blks) ==> 35651708:35651596
9: SKP: 15728640( 15 blks) ==> 71303304:12
10: RAW: 28311552( 27 blks) ==> 71303316:28311564
11: SKP: 5242880( 5 blks) ==> 99614880:12
12: RAW: 47185920( 45 blks) ==> 99614892:47185932
13: SKP: 3145728( 3 blks) ==> 146800824:12
14: RAW: 101711872( 97 blks) ==> 146800836:101711884
15: SKP: 2097152( 2 blks) ==> 248512720:12
16: RAW: 4194304( 4 blks) ==> 248512732:4194316
17: SKP: 1048576( 1 blks) ==> 252707048:12
18: RAW: 82837504( 79 blks) ==> 252707060:82837516
19: SKP: 1048576( 1 blks) ==> 335544576:12
20: RAW: 177209344( 169 blks) ==> 335544588:177209356
21: SKP: 2097152( 2 blks) ==> 512753944:12
22: RAW: 126877696( 121 blks) ==> 512753956:126877708
23: SKP: 4194304( 4 blks) ==> 639631664:12
24: RAW: 91226112( 87 blks) ==> 639631676:91226124
25: SKP: 1048576( 1 blks) ==> 730857800:12
26: RAW: 18874368( 18 blks) ==> 730857812:18874380
27: SKP: 6291456( 6 blks) ==> 749732192:12
28: RAW: 17825792( 17 blks) ==> 749732204:17825804
29: SKP: 2097152( 2 blks) ==> 767558008:12
30: RAW: 12582912( 12 blks) ==> 767558020:12582924
31: SKP: 1048576( 1 blks) ==> 780140944:12
32: RAW: 20971520( 20 blks) ==> 780140956:20971532
33: SKP: 1048576( 1 blks) ==> 801112488:12
34: RAW: 2097152( 2 blks) ==> 801112500:2097164
35: SKP: 1048576( 1 blks) ==> 803209664:12
36: RAW: 47185920( 45 blks) ==> 803209676:47185932
37: SKP: 3145728( 3 blks) ==> 850395608:12
38: RAW: 54525952( 52 blks) ==> 850395620:54525964
39: SKP: 4194304( 4 blks) ==> 904921584:12
40: RAW: 24117248( 23 blks) ==> 904921596:24117260
41: SKP: 1048576( 1 blks) ==> 929038856:12
42: RAW: 49283072( 47 blks) ==> 929038868:49283084
43: SKP: 1048576( 1 blks) ==> 978321952:12
44: RAW: 42991616( 41 blks) ==> 978321964:42991628
45: SKP: 2097152( 2 blks) ==> 1021313592:12
46: RAW: 35651584( 34 blks) ==> 1021313604:35651596
47: SKP: 3145728( 3 blks) ==> 1056965200:12
48: RAW: 108003328( 103 blks) ==> 1056965212:108003340
49: SKP: 2097152( 2 blks) ==> 1164968552:12
50: RAW: 111149056( 106 blks) ==> 1164968564:111149068
51: SKP: 5242880( 5 blks) ==> 1276117632:12
52: RAW: 13631488( 13 blks) ==> 1276117644:13631500
53: SKP: 3145728( 3 blks) ==> 1289749144:12
54: RAW: 15728640( 15 blks) ==> 1289749156:15728652
55: SKP: 1048576( 1 blks) ==> 1305477808:12
56: RAW: 15728640( 15 blks) ==> 1305477820:15728652
57: SKP: 621805568( 593 blks) ==> 1321206472:12
58: RAW: 9437184( 9 blks) ==> 1321206484:9437196
59: SKP: 24117248( 23 blks) ==> 1330643680:12
60: RAW: 11534336( 11 blks) ==> 1330643692:11534348
61: SKP: 89128960( 85 blks) ==> 1342178040:12
62: RAW: 445644800( 425 blks) ==> 1342178052:445644812
63: SKP: 1048576( 1 blks) ==> 1787822864:12
64: RAW: 7340032( 7 blks) ==> 1787822876:7340044
65: SKP: 1048576( 1 blks) ==> 1795162920:12
66: RAW: 619708416( 591 blks) ==> 1795162932:619708428
67: SKP: 2097152( 2 blks) ==> 2414871360:12
68: RAW: 58720256( 56 blks) ==> 2414871372:58720268
69: SKP: 5242880( 5 blks) ==> 2473591640:12
70: RAW: 33554432( 32 blks) ==> 2473591652:33554444
71: SKP: 167772160( 160 blks) ==> 2507146096:12
72: RAW: 1048576( 1 blks) ==> 2507146108:1048588
73: SKP: 670040064( 639 blks) ==> 2508194696:12
74: RAW: 7340032( 7 blks) ==> 2508194708:7340044
75: SKP: 1048576( 1 blks) ==> 2515534752:12
76: RAW: 1048576( 1 blks) ==> 2515534764:1048588
77: SKP: 24117248( 23 blks) ==> 2516583352:12
78: RAW: 17825792( 17 blks) ==> 2516583364:17825804
79: SKP: 82837504( 79 blks) ==> 2534409168:12
80: RAW: 287309824( 274 blks) ==> 2534409180:287309836
81: SKP: 1048576( 1 blks) ==> 2821719016:12
82: RAW: 343932928( 328 blks) ==> 2821719028:343932940
83: SKP: 1048576( 1 blks) ==> 3165651968:12
84: RAW: 149946368( 143 blks) ==> 3165651980:149946380
85: SKP: 1229979648( 1173 blks) ==> 3315598360:12
86: RAW: 7340032( 7 blks) ==> 3315598372:7340044
87: SKP: 1048576( 1 blks) ==> 3322938416:12
88: RAW: 1048576( 1 blks) ==> 3322938428:1048588
89: SKP: 24117248( 23 blks) ==> 3323987016:12
90: RAW: 19922944( 19 blks) ==> 3323987028:19922956
91: SKP: 80740352( 77 blks) ==> 3343909984:12
92: RAW: 1048576( 1 blks) ==> 3343909996:1048588
93: SKP: 2097152( 2 blks) ==> 3344958584:12
94: RAW: 197132288( 188 blks) ==> 3344958596:197132300
95: SKP: 1048576( 1 blks) ==> 3542090896:12
96: RAW: 3145728( 3 blks) ==> 3542090908:3145740
97: SKP: 1048576( 1 blks) ==> 3545236648:12
98: RAW: 3145728( 3 blks) ==> 3545236660:3145740
99: SKP: 1048576( 1 blks) ==> 3548382400:12
100: RAW: 179306496( 171 blks) ==> 3548382412:179306508
101: SKP: 13631488( 13 blks) ==> 3727688920:12
102: RAW: 14680064( 14 blks) ==> 3727688932:14680076
103: SKP: 1595932672( 1522 blks) ==> 3742369008:12
104: RAW: 7340032( 7 blks) ==> 3742369020:7340044
105: SKP: 1048576( 1 blks) ==> 3749709064:12
106: RAW: 1048576( 1 blks) ==> 3749709076:1048588
107: SKP: 24117248( 23 blks) ==> 3750757664:12
108: RAW: 14680064( 14 blks) ==> 3750757676:14680076
109: SKP: 85983232( 82 blks) ==> 3765437752:12
110: RAW: 208666624( 199 blks) ==> 3765437764:208666636
111: SKP: 1048576( 1 blks) ==> 3974104400:12
112: RAW: 103809024( 99 blks) ==> 3974104412:103809036
113: SKP: 1699741696( 1621 blks) ==> 4077913448:12
114: RAW: 5242880( 5 blks) ==> 4077913460:5242892
115: SKP: 28311552( 27 blks) ==> 4083156352:12
116: RAW: 13631488( 13 blks) ==> 4083156364:13631500
117: SKP: 87031808( 83 blks) ==> 4096787864:12
118: RAW: 1048576( 1 blks) ==> 4096787876:1048588
119: SKP: 2097152( 2 blks) ==> 4097836464:12
120: RAW: 73400320( 70 blks) ==> 4097836476:73400332
121: SKP: 1936719872( 1847 blks) ==> 4171236808:12
122: RAW: 9437184( 9 blks) ==> 4171236820:9437196
123: SKP: 24117248( 23 blks) ==> 4180674016:12
124: RAW: 14680064( 14 blks) ==> 4180674028:14680076
125: SKP: 85983232( 82 blks) ==> 4195354104:12
126: RAW: 97517568( 93 blks) ==> 4195354116:97517580
127: SKP: 3145728( 3 blks) ==> 4292871696:12
128: RAW: 33554432( 32 blks) ==> 4292871708:33554444
129: SKP: 1879048192( 1792 blks) ==> 4326426152:12
-- Total: ---------------------------------------------------
130 CHUNK 15032385536( 14336 blks) ==> 4326426164(4126 blks)
done.
system.img built successfully.
Existing tbcfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb)... done.
copying cfgfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a01.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid
saving flash command in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)... done.
copying partition layout (flash.xml.sb)... done.
copying kernel dtb (tegra210-p3448-0000-p3449-0000-a01.dtb.sb)... done.
saving flash parameters in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_parameters.txt
saving Windows flash command to /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
[ 0.0000 ] Generating RCM messages
[ 0.0744 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0771 ] RCM 0 is saved as rcm_0.rcm
[ 0.0800 ] RCM 1 is saved as rcm_1.rcm
[ 0.0800 ] List of rcm files are saved in rcm_list.xml
[ 0.0800 ]
[ 0.0800 ] Signing RCM messages
[ 0.1160 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1186 ] Assuming zero filled SBK key
[ 0.1376 ]
[ 0.1377 ] Copying signature to RCM mesages
[ 0.1404 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.1441 ]
[ 0.1442 ] Parsing partition layout
[ 0.2409 ] tegraparser --pt flash.xml.tmp
[ 0.2459 ]
[ 0.2460 ] Creating list of images to be signed
[ 0.2885 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.3851 ]
[ 0.3852 ] Generating signatures
[ 0.3879 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3904 ] Assuming zero filled SBK key
[ 0.5555 ]
[ 0.5555 ] Generating br-bct
[ 0.6007 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.6032 ] Copying Sdram info from 0 to 1 set
[ 0.6084 ] Copying Sdram info from 1 to 2 set
[ 0.6084 ] Copying Sdram info from 2 to 3 set
[ 0.6084 ]
[ 0.6085 ] Updating boot device parameters
[ 0.6110 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.6136 ] Warning: No sdram params
[ 0.6140 ]
[ 0.6140 ] Updating bl info
[ 0.6167 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.7048 ]
[ 0.7049 ] Updating secondary storage information into bct
[ 0.7075 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.7387 ]
[ 0.7388 ] Updating Odmdata
[ 0.7414 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.7440 ] Warning: No sdram params
[ 0.7725 ]
[ 0.7726 ] Get Signed section of bct
[ 0.7752 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.7783 ]
[ 0.7783 ] Signing BCT
[ 0.7833 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.7860 ] Assuming zero filled SBK key
[ 0.7873 ]
[ 0.7873 ] Updating BCT with signature
[ 0.7899 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.7943 ]
[ 0.7945 ] Copying signatures
[ 0.7973 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.8302 ]
[ 0.8303 ] Updating BFS information on BCT
[ 0.8332 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.8357 ] BFS:
[ 0.8408 ] 0: [PT ] flash.xml.bin (size=2138/65536)
[ 0.8420 ] 2: [VER] qspi_bootblob_ver.txt (size=153/65536)
[ 0.8879 ] BFS0: 65536 @ 224 SUM 22d57bed over 3735552 bytes
[ 0.8887 ]
[ 0.8888 ] Boot Rom communication
[ 0.8914 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.8940 ] RCM version 0X210001
[ 1.3145 ] Boot Rom communication completed
[ 2.3215 ]
[ 2.3216 ] Sending BCTs
[ 2.3243 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 2.3268 ] Applet version 00.01.0000
[ 2.5014 ] Sending bct
[ 2.5018 ] [................................................] 100%
[ 2.5901 ]
[ 2.5902 ] Sending bootloader and pre-requisite binaries
[ 2.5929 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a01.dtb 0
[ 2.5954 ] Applet version 00.01.0000
[ 3.0116 ] Sending ebt
[ 3.0772 ]
Error: Return value 1
Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a01.dtb 0
Failed flashing t210ref.
0092.000] Enabled early print
[0092.003] [TegraBoot] (version 00.00.2018.01-l4t-32ed9048)
[0092.008] Processing in recovery mode
[0092.011] A02 Bootrom Patch rev = 1023
[0092.015] Power-up reason: pmc por
[0092.018] Established communication link with host
[0093.157] Odmdata from BCT: 0x00094000
[0093.161] DebugPort= 0x3
[0093.213] EEPROM CRC failed. Calculated crc=0x35 CRC stored = 0x9d
[0093.219] WARNING: Verifying Eeprom failed
[0093.223] Reading Board-ID for Board-Type-1 unsuccessful
[0093.228] BoardId read from EEPROM/NCT: 0
[0093.232] Unsupported Platform 0
[0093.235] Downloaded BCT successfully
Did you replace the nvtboot.bin and nvtboot_recovery.bin?
Hi WayneWWW,
Yes, but nano still cannot flash and boot as I posted https://devtalk.nvidia.com/default/topic/1056786/-eeprom-nano-cannot-boot/
Could you share the latest log , and the steps you update nvtboot + flash?
Is the log in topic 1056786 after the update of nvtboot or not?
Please note that I have a wrong patch in previous comment, you must use the latest tarball.
The log is after doing #34, #35, #40.
I set Nano to RCM and used the command “sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1” to flash.
