after i2cset test, nano can't boot
hi, WayneWWW,
i’ll test it ASAP, thank you
hi, WayneWWW,
after update, the jetson nano boot success, thank you.
i’ll close the issue.
best regards~
I have the same problem. I set eeprom mistakenly, and nano cannot boot now.
Is there any method to re-write eeprom in RCM?
use the image in #34, #35, #40, then update : http://101.200.50.71/test/host_update_command.txt
Still failed!
Bus 001 Device 045: ID 0955:7f21 NVidia Corp.
# L4T BSP Information:
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
# DATE: Wed Mar 13 07:46:13 UTC 2019
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
Board ID(3448) version(100)
copying bctfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
	populating kernel to rootfs... done.
	populating initrd to rootfs... done.
	populating extlinux.conf.emmc to rootfs... done.
	populating /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb)... done.
Making system.img...
	populating rootfs from /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/rootfs ... sudo cp -vf ~done.
	Sync'ing system.done.
	Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
  0: RAW:     5242880(      5 blks) ==>          28:5242892
  1: SKP:    31457280(     30 blks) ==>     5242920:12
  2: RAW:     1048576(      1 blks) ==>     5242932:1048588
  3: SKP:    96468992(     92 blks) ==>     6291520:12
  4: RAW:     1048576(      1 blks) ==>     6291532:1048588
  5: SKP:     2097152(      2 blks) ==>     7340120:12
  6: RAW:    28311552(     27 blks) ==>     7340132:28311564
  7: SKP:     1048576(      1 blks) ==>    35651696:12
  8: RAW:    35651584(     34 blks) ==>    35651708:35651596
  9: SKP:    15728640(     15 blks) ==>    71303304:12
 10: RAW:    28311552(     27 blks) ==>    71303316:28311564
 11: SKP:     5242880(      5 blks) ==>    99614880:12
 12: RAW:    47185920(     45 blks) ==>    99614892:47185932
 13: SKP:     3145728(      3 blks) ==>   146800824:12
 14: RAW:   101711872(     97 blks) ==>   146800836:101711884
 15: SKP:     2097152(      2 blks) ==>   248512720:12
 16: RAW:     4194304(      4 blks) ==>   248512732:4194316
 17: SKP:     1048576(      1 blks) ==>   252707048:12
 18: RAW:    82837504(     79 blks) ==>   252707060:82837516
 19: SKP:     1048576(      1 blks) ==>   335544576:12
 20: RAW:   177209344(    169 blks) ==>   335544588:177209356
 21: SKP:     2097152(      2 blks) ==>   512753944:12
 22: RAW:   126877696(    121 blks) ==>   512753956:126877708
 23: SKP:     4194304(      4 blks) ==>   639631664:12
 24: RAW:    91226112(     87 blks) ==>   639631676:91226124
 25: SKP:     1048576(      1 blks) ==>   730857800:12
 26: RAW:    18874368(     18 blks) ==>   730857812:18874380
 27: SKP:     6291456(      6 blks) ==>   749732192:12
 28: RAW:    17825792(     17 blks) ==>   749732204:17825804
 29: SKP:     2097152(      2 blks) ==>   767558008:12
 30: RAW:    12582912(     12 blks) ==>   767558020:12582924
 31: SKP:     1048576(      1 blks) ==>   780140944:12
 32: RAW:    20971520(     20 blks) ==>   780140956:20971532
 33: SKP:     1048576(      1 blks) ==>   801112488:12
 34: RAW:     2097152(      2 blks) ==>   801112500:2097164
 35: SKP:     1048576(      1 blks) ==>   803209664:12
 36: RAW:    47185920(     45 blks) ==>   803209676:47185932
 37: SKP:     3145728(      3 blks) ==>   850395608:12
 38: RAW:    54525952(     52 blks) ==>   850395620:54525964
 39: SKP:     4194304(      4 blks) ==>   904921584:12
 40: RAW:    24117248(     23 blks) ==>   904921596:24117260
 41: SKP:     1048576(      1 blks) ==>   929038856:12
 42: RAW:    49283072(     47 blks) ==>   929038868:49283084
 43: SKP:     1048576(      1 blks) ==>   978321952:12
 44: RAW:    42991616(     41 blks) ==>   978321964:42991628
 45: SKP:     2097152(      2 blks) ==>  1021313592:12
 46: RAW:    35651584(     34 blks) ==>  1021313604:35651596
 47: SKP:     3145728(      3 blks) ==>  1056965200:12
 48: RAW:   108003328(    103 blks) ==>  1056965212:108003340
 49: SKP:     2097152(      2 blks) ==>  1164968552:12
 50: RAW:   111149056(    106 blks) ==>  1164968564:111149068
 51: SKP:     5242880(      5 blks) ==>  1276117632:12
 52: RAW:    13631488(     13 blks) ==>  1276117644:13631500
 53: SKP:     3145728(      3 blks) ==>  1289749144:12
 54: RAW:    15728640(     15 blks) ==>  1289749156:15728652
 55: SKP:     1048576(      1 blks) ==>  1305477808:12
 56: RAW:    15728640(     15 blks) ==>  1305477820:15728652
 57: SKP:   621805568(    593 blks) ==>  1321206472:12
 58: RAW:     9437184(      9 blks) ==>  1321206484:9437196
 59: SKP:    24117248(     23 blks) ==>  1330643680:12
 60: RAW:    11534336(     11 blks) ==>  1330643692:11534348
 61: SKP:    89128960(     85 blks) ==>  1342178040:12
 62: RAW:   445644800(    425 blks) ==>  1342178052:445644812
 63: SKP:     1048576(      1 blks) ==>  1787822864:12
 64: RAW:     7340032(      7 blks) ==>  1787822876:7340044
 65: SKP:     1048576(      1 blks) ==>  1795162920:12
 66: RAW:   619708416(    591 blks) ==>  1795162932:619708428
 67: SKP:     2097152(      2 blks) ==>  2414871360:12
 68: RAW:    58720256(     56 blks) ==>  2414871372:58720268
 69: SKP:     5242880(      5 blks) ==>  2473591640:12
 70: RAW:    33554432(     32 blks) ==>  2473591652:33554444
 71: SKP:   167772160(    160 blks) ==>  2507146096:12
 72: RAW:     1048576(      1 blks) ==>  2507146108:1048588
 73: SKP:   670040064(    639 blks) ==>  2508194696:12
 74: RAW:     7340032(      7 blks) ==>  2508194708:7340044
 75: SKP:     1048576(      1 blks) ==>  2515534752:12
 76: RAW:     1048576(      1 blks) ==>  2515534764:1048588
 77: SKP:    24117248(     23 blks) ==>  2516583352:12
 78: RAW:    17825792(     17 blks) ==>  2516583364:17825804
 79: SKP:    82837504(     79 blks) ==>  2534409168:12
 80: RAW:   287309824(    274 blks) ==>  2534409180:287309836
 81: SKP:     1048576(      1 blks) ==>  2821719016:12
 82: RAW:   343932928(    328 blks) ==>  2821719028:343932940
 83: SKP:     1048576(      1 blks) ==>  3165651968:12
 84: RAW:   149946368(    143 blks) ==>  3165651980:149946380
 85: SKP:  1229979648(   1173 blks) ==>  3315598360:12
 86: RAW:     7340032(      7 blks) ==>  3315598372:7340044
 87: SKP:     1048576(      1 blks) ==>  3322938416:12
 88: RAW:     1048576(      1 blks) ==>  3322938428:1048588
 89: SKP:    24117248(     23 blks) ==>  3323987016:12
 90: RAW:    19922944(     19 blks) ==>  3323987028:19922956
 91: SKP:    80740352(     77 blks) ==>  3343909984:12
 92: RAW:     1048576(      1 blks) ==>  3343909996:1048588
 93: SKP:     2097152(      2 blks) ==>  3344958584:12
 94: RAW:   197132288(    188 blks) ==>  3344958596:197132300
 95: SKP:     1048576(      1 blks) ==>  3542090896:12
 96: RAW:     3145728(      3 blks) ==>  3542090908:3145740
 97: SKP:     1048576(      1 blks) ==>  3545236648:12
 98: RAW:     3145728(      3 blks) ==>  3545236660:3145740
 99: SKP:     1048576(      1 blks) ==>  3548382400:12
100: RAW:   179306496(    171 blks) ==>  3548382412:179306508
101: SKP:    13631488(     13 blks) ==>  3727688920:12
102: RAW:    14680064(     14 blks) ==>  3727688932:14680076
103: SKP:  1595932672(   1522 blks) ==>  3742369008:12
104: RAW:     7340032(      7 blks) ==>  3742369020:7340044
105: SKP:     1048576(      1 blks) ==>  3749709064:12
106: RAW:     1048576(      1 blks) ==>  3749709076:1048588
107: SKP:    24117248(     23 blks) ==>  3750757664:12
108: RAW:    14680064(     14 blks) ==>  3750757676:14680076
109: SKP:    85983232(     82 blks) ==>  3765437752:12
110: RAW:   208666624(    199 blks) ==>  3765437764:208666636
111: SKP:     1048576(      1 blks) ==>  3974104400:12
112: RAW:   103809024(     99 blks) ==>  3974104412:103809036
113: SKP:  1699741696(   1621 blks) ==>  4077913448:12
114: RAW:     5242880(      5 blks) ==>  4077913460:5242892
115: SKP:    28311552(     27 blks) ==>  4083156352:12
116: RAW:    13631488(     13 blks) ==>  4083156364:13631500
117: SKP:    87031808(     83 blks) ==>  4096787864:12
118: RAW:     1048576(      1 blks) ==>  4096787876:1048588
119: SKP:     2097152(      2 blks) ==>  4097836464:12
120: RAW:    73400320(     70 blks) ==>  4097836476:73400332
121: SKP:  1936719872(   1847 blks) ==>  4171236808:12
122: RAW:     9437184(      9 blks) ==>  4171236820:9437196
123: SKP:    24117248(     23 blks) ==>  4180674016:12
124: RAW:    14680064(     14 blks) ==>  4180674028:14680076
125: SKP:    85983232(     82 blks) ==>  4195354104:12
126: RAW:    97517568(     93 blks) ==>  4195354116:97517580
127: SKP:     3145728(      3 blks) ==>  4292871696:12
128: RAW:    33554432(     32 blks) ==>  4292871708:33554444
129: SKP:  1879048192(   1792 blks) ==>  4326426152:12
-- Total: ---------------------------------------------------
130 CHUNK 15032385536(  14336 blks) ==>  4326426164(4126 blks)
done.
system.img built successfully.
Existing tbcfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a01.dtb)... done.
copying cfgfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct  P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a01.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot"  --cfg flash.xml --chip 0x21   --skipuid
saving flash command in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)... done.
copying partition layout (flash.xml.sb)... done.
copying kernel dtb (tegra210-p3448-0000-p3449-0000-a01.dtb.sb)... done.
saving flash parameters in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_parameters.txt
saving Windows flash command to /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0000 ] Generating RCM messages
[   0.0744 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[   0.0771 ] RCM 0 is saved as rcm_0.rcm
[   0.0800 ] RCM 1 is saved as rcm_1.rcm
[   0.0800 ] List of rcm files are saved in rcm_list.xml
[   0.0800 ]
[   0.0800 ] Signing RCM messages
[   0.1160 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.1186 ] Assuming zero filled SBK key
[   0.1376 ]
[   0.1377 ] Copying signature to RCM mesages
[   0.1404 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[   0.1441 ]
[   0.1442 ] Parsing partition layout
[   0.2409 ] tegraparser --pt flash.xml.tmp
[   0.2459 ]
[   0.2460 ] Creating list of images to be signed
[   0.2885 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[   0.3851 ]
[   0.3852 ] Generating signatures
[   0.3879 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[   0.3904 ] Assuming zero filled SBK key
[   0.5555 ]
[   0.5555 ] Generating br-bct
[   0.6007 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[   0.6032 ] Copying Sdram info from 0 to 1 set
[   0.6084 ] Copying Sdram info from 1 to 2 set
[   0.6084 ] Copying Sdram info from 2 to 3 set
[   0.6084 ]
[   0.6085 ] Updating boot device parameters
[   0.6110 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[   0.6136 ] Warning: No sdram params
[   0.6140 ]
[   0.6140 ] Updating bl info
[   0.6167 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   0.7048 ]
[   0.7049 ] Updating secondary storage information into bct
[   0.7075 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[   0.7387 ]
[   0.7388 ] Updating Odmdata
[   0.7414 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[   0.7440 ] Warning: No sdram params
[   0.7725 ]
[   0.7726 ] Get Signed section of bct
[   0.7752 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[   0.7783 ]
[   0.7783 ] Signing BCT
[   0.7833 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[   0.7860 ] Assuming zero filled SBK key
[   0.7873 ]
[   0.7873 ] Updating BCT with signature
[   0.7899 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[   0.7943 ]
[   0.7945 ] Copying signatures
[   0.7973 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   0.8302 ]
[   0.8303 ] Updating BFS information on BCT
[   0.8332 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[   0.8357 ]    BFS:
[   0.8408 ]      0: [PT ] flash.xml.bin (size=2138/65536)
[   0.8420 ]      2: [VER] qspi_bootblob_ver.txt (size=153/65536)
[   0.8879 ] BFS0: 65536 @ 224 SUM 22d57bed over 3735552 bytes
[   0.8887 ]
[   0.8888 ] Boot Rom communication
[   0.8914 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[   0.8940 ] RCM version 0X210001
[   1.3145 ] Boot Rom communication completed
[   2.3215 ]
[   2.3216 ] Sending BCTs
[   2.3243 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[   2.3268 ] Applet version 00.01.0000
[   2.5014 ] Sending bct
[   2.5018 ] [................................................] 100%
[   2.5901 ]
[   2.5902 ] Sending bootloader and pre-requisite binaries
[   2.5929 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a01.dtb 0
[   2.5954 ] Applet version 00.01.0000
[   3.0116 ] Sending ebt
[   3.0772 ]
Error: Return value 1
Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a01.dtb 0
Failed flashing t210ref.
0092.000] Enabled early print
[0092.003] [TegraBoot] (version 00.00.2018.01-l4t-32ed9048)
[0092.008] Processing in recovery mode
[0092.011] A02 Bootrom Patch rev = 1023
[0092.015] Power-up reason: pmc por
[0092.018] Established communication link with host
[0093.157] Odmdata from BCT: 0x00094000
[0093.161] DebugPort= 0x3
[0093.213] EEPROM CRC failed. Calculated crc=0x35 CRC stored = 0x9d
[0093.219] WARNING: Verifying Eeprom failed
[0093.223] Reading Board-ID for Board-Type-1 unsuccessful
[0093.228] BoardId read from EEPROM/NCT: 0
[0093.232] Unsupported Platform 0
[0093.235] Downloaded BCT successfully
Did you replace the nvtboot.bin and nvtboot_recovery.bin?
Hi WayneWWW,
Yes, but nano still cannot flash and boot as I posted https://devtalk.nvidia.com/default/topic/1056786/-eeprom-nano-cannot-boot/
Could you share the latest log , and the steps you update nvtboot + flash?
Is the log in topic 1056786 after the update of nvtboot or not?
Please note that I have a wrong patch in previous comment, you must use the latest tarball.
The log is after doing #34, #35, #40.
I set Nano to RCM and used the command “sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1” to flash.
Yes, I want to know which file and what have you changed.
I tried to use a clear Jetson-Nano-Tegra210_Linux_R32.1.0_aarch64.tbz2 just now. The result did not change.
Step 1: uncompress Jetson-Nano-Tegra210_Linux_R32.1.0_aarch64.tbz2
Step 2: uncompress Jetson-Nano-Tegra_Linux_Sample-Root-Filesystem_R32.1.0_aarch64.tbz2
Step 3: run “sudo ./apply_binaries.sh”
Step 4: uncompress nvtboot.tar.gz downloaded from #40 and put nvtboot.bin to Linux_for_Tegra/bootloader/t210ref, nvtboot_recovery.bin to Linux_for_Tegra/bootloader
Step 5: modify jetson-nano-qspi-sd.conf
Step 6: set Nano to RCM
Step 7: use command “sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1” to flash
Just a test. Could you put this to the package downloaded from jetpack instead of using the tarball from download center?
Putting this to the package downloaded from jetpack is still useless!
help~~~
Do you meet same error even after using jetpack?
I mean do you hit same error as
[   3.0772 ]
Also, could you see any log on UART during flash?
Yes, the same error as the previous test.
UART log
0155.013] Enabled early print
[0155.016] [TegraBoot] (version 00.00.2018.01-l4t-32ed9048)
[0155.021] Processing in recovery mode
[0155.025] A02 Bootrom Patch rev = 1023
[0155.028] Power-up reason: pmc por
[0155.032] Established communication link with host
[0156.166] Odmdata from BCT: 0x00094000
[0156.170] DebugPort= 0x3
[0156.222] EEPROM CRC failed. Calculated crc=0x35 CRC stored = 0x9d
[0156.227] WARNING: Verifying Eeprom failed
[0156.232] Reading Board-ID for Board-Type-1 unsuccessful
[0156.237] BoardId read from EEPROM/NCT: 0
[0156.241] Unsupported Platform 0
[0156.244] Downloaded BCT successfully
Could you check the board id on your sticker or the print on your board?
Where can I find what you said?
The board should have some stickers on it and there are some numbers when you flip over the carrier board.
945-13450-0000-000
S/N: 0421619068092
There should be some text printed on the board. Could you just take a photo of it?
