Hi Lonesomesnow,
Can you please provide latest uart logs with latest nvtboot.bin/nvtboot_recovery.bin as provided by WayneWWW and board-config changes as:
BOARDID=“3448”;
FAB=“200”;
BOARDSKU=“0000” ;
BOARDREV=“C.0”;
And please paste the command you used to flash and output of: “tail jetson-nano-qspi-sd.conf”, output should be:
$ tail jetson-nano-qspi-sd.conf
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
BOARDID=“3448”;
FAB=“200”;
BOARDSKU=“0000” ;
BOARDREV=“C.0”;
EMMC_CFG=flash_l4t_t210_spi_sd_p3448.xml;
BLBlockSize=1048576;
source “${LDK_DIR}/p3448-0000.conf.common”;
T21BINARGS="–bins "EBT cboot.bin; "
Make sure you used below command to flash on jetson-nano:
sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
L4T r32.1
UART
0099.652] Enabled early print
[0099.654] [TegraBoot] (version 00.00.2018.01-l4t-f5c2145e)
[0099.660] Processing in recovery mode
[0099.663] A02 Bootrom Patch rev = 1023
[0099.666] Power-up reason: pmc por
[0099.670] Established communication link with host
[0101.046] Odmdata from BCT: 0x00094000
[0101.050] DebugPort= 0x3
[0101.101] EEPROM CRC failed. Calculated crc=0x35 CRC stored = 0x9d
[0101.107] WARNING: Eeprom verification failed, Error = 20
[0101.112] Reading Board-ID for Board-Type-1 unsuccessful
[0101.118] BoardId read from EEPROM/NCT: 0
[0101.121] Unsupported Platform 0
[0101.124] Downloaded BCT successfully
UBUNTU
victor@lu16d-64b:~/working_directory/nvidia/nano/Linux_for_Tegra$ sudo ./flash.sh jetson-nano-qspi-sd mmcblk0p1
# L4T BSP Information:
# R32 (release), REVISION: 1.0, GCID: 14531094, BOARD: t210ref, EABI: aarch64,
# DATE: Wed Mar 13 07:46:13 UTC 2019
# Target Board Information:
# Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
# OpMode: production, Boot Authentication: ,
Board ID(3448) version(200)
copying bctfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg)... done.
copying bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
copying cpu_bootloader(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
copying bpffile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)... done.
Existing badpagefile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/badpage.bin) reused.
copying wb0boot(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
Making system.img...
populating rootfs from /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 9437184( 9 blks) ==> 28:9437196
1: SKP: 27262976( 26 blks) ==> 9437224:12
2: RAW: 10485760( 10 blks) ==> 9437236:10485772
3: SKP: 87031808( 83 blks) ==> 19923008:12
4: RAW: 1048576( 1 blks) ==> 19923020:1048588
5: SKP: 2097152( 2 blks) ==> 20971608:12
6: RAW: 28311552( 27 blks) ==> 20971620:28311564
7: SKP: 1048576( 1 blks) ==> 49283184:12
8: RAW: 35651584( 34 blks) ==> 49283196:35651596
9: SKP: 15728640( 15 blks) ==> 84934792:12
10: RAW: 185597952( 177 blks) ==> 84934804:185597964
11: SKP: 2097152( 2 blks) ==> 270532768:12
12: RAW: 266338304( 254 blks) ==> 270532780:266338316
13: SKP: 2097152( 2 blks) ==> 536871096:12
14: RAW: 216006656( 206 blks) ==> 536871108:216006668
15: SKP: 1048576( 1 blks) ==> 752877776:12
16: RAW: 7340032( 7 blks) ==> 752877788:7340044
17: SKP: 1048576( 1 blks) ==> 760217832:12
18: RAW: 35651584( 34 blks) ==> 760217844:35651596
19: SKP: 4194304( 4 blks) ==> 795869440:12
20: RAW: 1048576( 1 blks) ==> 795869452:1048588
21: SKP: 2097152( 2 blks) ==> 796918040:12
22: RAW: 262144000( 250 blks) ==> 796918052:262144012
23: SKP: 3145728( 3 blks) ==> 1059062064:12
24: RAW: 1048576( 1 blks) ==> 1059062076:1048588
25: SKP: 2097152( 2 blks) ==> 1060110664:12
26: RAW: 142606336( 136 blks) ==> 1060110676:142606348
27: SKP: 1048576( 1 blks) ==> 1202717024:12
28: RAW: 9437184( 9 blks) ==> 1202717036:9437196
29: SKP: 3145728( 3 blks) ==> 1212154232:12
30: RAW: 88080384( 84 blks) ==> 1212154244:88080396
31: SKP: 4194304( 4 blks) ==> 1300234640:12
32: RAW: 24117248( 23 blks) ==> 1300234652:24117260
33: SKP: 1048576( 1 blks) ==> 1324351912:12
34: RAW: 49283072( 47 blks) ==> 1324351924:49283084
35: SKP: 1048576( 1 blks) ==> 1373635008:12
36: RAW: 55574528( 53 blks) ==> 1373635020:55574540
37: SKP: 3145728( 3 blks) ==> 1429209560:12
38: RAW: 22020096( 21 blks) ==> 1429209572:22020108
39: SKP: 3145728( 3 blks) ==> 1451229680:12
40: RAW: 108003328( 103 blks) ==> 1451229692:108003340
41: SKP: 2097152( 2 blks) ==> 1559233032:12
42: RAW: 87031808( 83 blks) ==> 1559233044:87031820
43: SKP: 4194304( 4 blks) ==> 1646264864:12
44: RAW: 13631488( 13 blks) ==> 1646264876:13631500
45: SKP: 3145728( 3 blks) ==> 1659896376:12
46: RAW: 16777216( 16 blks) ==> 1659896388:16777228
47: SKP: 25165824( 24 blks) ==> 1676673616:12
48: RAW: 14680064( 14 blks) ==> 1676673628:14680076
49: SKP: 253755392( 242 blks) ==> 1691353704:12
50: RAW: 7340032( 7 blks) ==> 1691353716:7340044
51: SKP: 26214400( 25 blks) ==> 1698693760:12
52: RAW: 11534336( 11 blks) ==> 1698693772:11534348
53: SKP: 89128960( 85 blks) ==> 1710228120:12
54: RAW: 274726912( 262 blks) ==> 1710228132:274726924
55: SKP: 2097152( 2 blks) ==> 1984955056:12
56: RAW: 479199232( 457 blks) ==> 1984955068:479199244
57: SKP: 1048576( 1 blks) ==> 2464154312:12
58: RAW: 11534336( 11 blks) ==> 2464154324:11534348
59: SKP: 1048576( 1 blks) ==> 2475688672:12
60: RAW: 305135616( 291 blks) ==> 2475688684:305135628
61: SKP: 2097152( 2 blks) ==> 2780824312:12
62: RAW: 164626432( 157 blks) ==> 2780824324:164626444
63: SKP: 33554432( 32 blks) ==> 2945450768:12
64: RAW: 33554432( 32 blks) ==> 2945450780:33554444
65: SKP: 33554432( 32 blks) ==> 2979005224:12
66: RAW: 1048576( 1 blks) ==> 2979005236:1048588
67: SKP: 670040064( 639 blks) ==> 2980053824:12
68: RAW: 6291456( 6 blks) ==> 2980053836:6291468
69: SKP: 27262976( 26 blks) ==> 2986345304:12
70: RAW: 16777216( 16 blks) ==> 2986345316:16777228
71: SKP: 83886080( 80 blks) ==> 3003122544:12
72: RAW: 40894464( 39 blks) ==> 3003122556:40894476
73: SKP: 1048576( 1 blks) ==> 3044017032:12
74: RAW: 13631488( 13 blks) ==> 3044017044:13631500
75: SKP: 1048576( 1 blks) ==> 3057648544:12
76: RAW: 3145728( 3 blks) ==> 3057648556:3145740
77: SKP: 1048576( 1 blks) ==> 3060794296:12
78: RAW: 24117248( 23 blks) ==> 3060794308:24117260
79: SKP: 1048576( 1 blks) ==> 3084911568:12
80: RAW: 3145728( 3 blks) ==> 3084911580:3145740
81: SKP: 1048576( 1 blks) ==> 3088057320:12
82: RAW: 5242880( 5 blks) ==> 3088057332:5242892
83: SKP: 1048576( 1 blks) ==> 3093300224:12
84: RAW: 104857600( 100 blks) ==> 3093300236:104857612
85: SKP: 33554432( 32 blks) ==> 3198157848:12
86: RAW: 27262976( 26 blks) ==> 3198157860:27262988
87: SKP: 1751121920( 1670 blks) ==> 3225420848:12
88: RAW: 5242880( 5 blks) ==> 3225420860:5242892
89: SKP: 28311552( 27 blks) ==> 3230663752:12
90: RAW: 13631488( 13 blks) ==> 3230663764:13631500
91: SKP: 87031808( 83 blks) ==> 3244295264:12
92: RAW: 1048576( 1 blks) ==> 3244295276:1048588
93: SKP: 2097152( 2 blks) ==> 3245343864:12
94: RAW: 567279616( 541 blks) ==> 3245343876:567279628
95: SKP: 33554432( 32 blks) ==> 3812623504:12
96: RAW: 23068672( 22 blks) ==> 3812623516:23068684
97: SKP: 1386217472( 1322 blks) ==> 3835692200:12
98: RAW: 3145728( 3 blks) ==> 3835692212:3145740
99: SKP: 30408704( 29 blks) ==> 3838837952:12
100: RAW: 13631488( 13 blks) ==> 3838837964:13631500
101: SKP: 87031808( 83 blks) ==> 3852469464:12
102: RAW: 35651584( 34 blks) ==> 3852469476:35651596
103: SKP: 1977614336( 1886 blks) ==> 3888121072:12
104: RAW: 9437184( 9 blks) ==> 3888121084:9437196
105: SKP: 24117248( 23 blks) ==> 3897558280:12
106: RAW: 14680064( 14 blks) ==> 3897558292:14680076
107: SKP: 85983232( 82 blks) ==> 3912238368:12
108: RAW: 1048576( 1 blks) ==> 3912238380:1048588
109: SKP: 2097152( 2 blks) ==> 3913286968:12
110: RAW: 193986560( 185 blks) ==> 3913286980:193986572
111: SKP: 4194304( 4 blks) ==> 4107273552:12
112: RAW: 33554432( 32 blks) ==> 4107273564:33554444
113: SKP: 1778384896( 1696 blks) ==> 4140828008:12
114: RAW: 7340032( 7 blks) ==> 4140828020:7340044
115: SKP: 26214400( 25 blks) ==> 4148168064:12
116: RAW: 14680064( 14 blks) ==> 4148168076:14680076
117: SKP: 85983232( 82 blks) ==> 4162848152:12
118: RAW: 159383552( 152 blks) ==> 4162848164:159383564
119: SKP: 1853882368( 1768 blks) ==> 4322231728:12
-- Total: ---------------------------------------------------
120 CHUNK 15032385536( 14336 blks) ==> 4322231740(4122 blks)
done.
system.img built successfully.
Existing tbcfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-a02.dtb)... done.
copying cfgfile(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_spi_sd_p3448.xml) to flash.xml... done.
copying flasher(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl cboot.bin --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --odmdata 0x94000 --bldtb tegra210-p3448-0000-p3449-0000-a02.dtb --applet nvtboot_recovery.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x21 --skipuid
saving flash command in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flashcmd.txt
copying boot image (boot.img.sb)... done.
copying partition layout (flash.xml.sb)... done.
copying kernel dtb (tegra210-p3448-0000-p3449-0000-a02.dtb.sb)... done.
saving flash parameters in /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_parameters.txt
saving Windows flash command to /home/victor/working_directory/nvidia/nano/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0116 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0144 ] RCM 0 is saved as rcm_0.rcm
[ 0.0177 ] RCM 1 is saved as rcm_1.rcm
[ 0.0177 ] List of rcm files are saved in rcm_list.xml
[ 0.0178 ]
[ 0.0178 ] Signing RCM messages
[ 0.0283 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0311 ] Assuming zero filled SBK key
[ 0.0843 ]
[ 0.0844 ] Copying signature to RCM mesages
[ 0.0873 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0912 ]
[ 0.0913 ] Parsing partition layout
[ 0.1350 ] tegraparser --pt flash.xml.tmp
[ 0.1385 ]
[ 0.1386 ] Creating list of images to be signed
[ 0.1543 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.2197 ]
[ 0.2198 ] Generating signatures
[ 0.2225 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.2250 ] Assuming zero filled SBK key
[ 0.3248 ]
[ 0.3249 ] Generating br-bct
[ 0.3427 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.3435 ] Copying Sdram info from 0 to 1 set
[ 0.3474 ] Copying Sdram info from 1 to 2 set
[ 0.3474 ] Copying Sdram info from 2 to 3 set
[ 0.3474 ]
[ 0.3474 ] Updating boot device parameters
[ 0.3482 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.3489 ] Warning: No sdram params
[ 0.3491 ]
[ 0.3491 ] Updating bl info
[ 0.3498 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.4102 ]
[ 0.4102 ] Updating secondary storage information into bct
[ 0.4113 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.4430 ]
[ 0.4430 ] Updating Odmdata
[ 0.4442 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.4455 ] Warning: No sdram params
[ 0.4766 ]
[ 0.4767 ] Get Signed section of bct
[ 0.4793 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.4826 ]
[ 0.4826 ] Signing BCT
[ 0.4882 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.4910 ] Assuming zero filled SBK key
[ 0.4922 ]
[ 0.4923 ] Updating BCT with signature
[ 0.4949 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.5013 ]
[ 0.5014 ] Copying signatures
[ 0.5042 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.5375 ]
[ 0.5377 ] Updating BFS information on BCT
[ 0.5406 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.5433 ] BFS:
[ 0.5484 ] 0: [PT ] flash.xml.bin (size=2138/65536)
[ 0.5492 ] 2: [VER] qspi_bootblob_ver.txt (size=153/65536)
[ 0.5626 ] BFS0: 65536 @ 224 SUM 521ba94b over 3735552 bytes
[ 0.5638 ]
[ 0.5639 ] Boot Rom communication
[ 0.5665 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.5688 ] RCM version 0X210001
[ 0.9906 ] Boot Rom communication completed
[ 1.9980 ]
[ 1.9981 ] Sending BCTs
[ 2.0008 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 2.0032 ] Applet version 00.01.0000
[ 2.4215 ] Sending bct
[ 2.4217 ] [................................................] 100%
[ 2.5111 ]
[ 2.5112 ] Sending bootloader and pre-requisite binaries
[ 2.5138 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
[ 2.5163 ] Applet version 00.01.0000
[ 2.9334 ] Sending ebt
[ 3.0001 ]
Error: Return value 1
Command tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
Failed flashing t210ref.
Could you try to compress your Linux_for_Tegra as a tarball. Put it to online storage like google drive or something for us to download?
We cannot reproduce your issue with our own driver package. Better directly using your setup.
[url]https://drive.google.com/file/d/1FMbDD8C_wiABLc23FIx8qrP_zA9pqeCD/view?usp=sharing[/url]
By the way, I borrow a Nano board from other people to test the flash function, and this Nano board can flash without any error by this tarball.
Please try to use these new nvtboot binary and share the boot log with us. Thanks.
nvtboot_20190711.tar.gz (160 KB)
UBUNTU
done.
0: RAW: 7340032( 7 blks) ==> 28:7340044
1: SKP: 29360128( 28 blks) ==> 7340072:12
2: RAW: 8388608( 8 blks) ==> 7340084:8388620
3: SKP: 89128960( 85 blks) ==> 15728704:12
4: RAW: 1048576( 1 blks) ==> 15728716:1048588
5: SKP: 2097152( 2 blks) ==> 16777304:12
6: RAW: 28311552( 27 blks) ==> 16777316:28311564
7: SKP: 1048576( 1 blks) ==> 45088880:12
8: RAW: 35651584( 34 blks) ==> 45088892:35651596
9: SKP: 15728640( 15 blks) ==> 80740488:12
10: RAW: 185597952( 177 blks) ==> 80740500:185597964
11: SKP: 2097152( 2 blks) ==> 266338464:12
12: RAW: 37748736( 36 blks) ==> 266338476:37748748
13: SKP: 1048576( 1 blks) ==> 304087224:12
14: RAW: 96468992( 92 blks) ==> 304087236:96469004
15: SKP: 4194304( 4 blks) ==> 400556240:12
16: RAW: 126877696( 121 blks) ==> 400556252:126877708
17: SKP: 2097152( 2 blks) ==> 527433960:12
18: RAW: 2097152( 2 blks) ==> 527433972:2097164
19: SKP: 3145728( 3 blks) ==> 529531136:12
20: RAW: 15728640( 15 blks) ==> 529531148:15728652
21: SKP: 1048576( 1 blks) ==> 545259800:12
22: RAW: 81788928( 78 blks) ==> 545259812:81788940
23: SKP: 2097152( 2 blks) ==> 627048752:12
24: RAW: 155189248( 148 blks) ==> 627048764:155189260
25: SKP: 4194304( 4 blks) ==> 782238024:12
26: RAW: 1048576( 1 blks) ==> 782238036:1048588
27: SKP: 2097152( 2 blks) ==> 783286624:12
28: RAW: 4194304( 4 blks) ==> 783286636:4194316
29: SKP: 1048576( 1 blks) ==> 787480952:12
30: RAW: 123731968( 118 blks) ==> 787480964:123731980
31: SKP: 2097152( 2 blks) ==> 911212944:12
32: RAW: 49283072( 47 blks) ==> 911212956:49283084
33: SKP: 1048576( 1 blks) ==> 960496040:12
34: RAW: 14680064( 14 blks) ==> 960496052:14680076
35: SKP: 2097152( 2 blks) ==> 975176128:12
36: RAW: 68157440( 65 blks) ==> 975176140:68157452
37: SKP: 2097152( 2 blks) ==> 1043333592:12
38: RAW: 6291456( 6 blks) ==> 1043333604:6291468
39: SKP: 1048576( 1 blks) ==> 1049625072:12
40: RAW: 5242880( 5 blks) ==> 1049625084:5242892
41: SKP: 1048576( 1 blks) ==> 1054867976:12
42: RAW: 62914560( 60 blks) ==> 1054867988:62914572
43: SKP: 4194304( 4 blks) ==> 1117782560:12
44: RAW: 24117248( 23 blks) ==> 1117782572:24117260
45: SKP: 1048576( 1 blks) ==> 1141899832:12
46: RAW: 49283072( 47 blks) ==> 1141899844:49283084
47: SKP: 1048576( 1 blks) ==> 1191182928:12
48: RAW: 55574528( 53 blks) ==> 1191182940:55574540
49: SKP: 3145728( 3 blks) ==> 1246757480:12
50: RAW: 22020096( 21 blks) ==> 1246757492:22020108
51: SKP: 3145728( 3 blks) ==> 1268777600:12
52: RAW: 108003328( 103 blks) ==> 1268777612:108003340
53: SKP: 2097152( 2 blks) ==> 1376780952:12
54: RAW: 26214400( 25 blks) ==> 1376780964:26214412
55: SKP: 6291456( 6 blks) ==> 1402995376:12
56: RAW: 54525952( 52 blks) ==> 1402995388:54525964
57: SKP: 4194304( 4 blks) ==> 1457521352:12
58: RAW: 13631488( 13 blks) ==> 1457521364:13631500
59: SKP: 3145728( 3 blks) ==> 1471152864:12
60: RAW: 15728640( 15 blks) ==> 1471152876:15728652
61: SKP: 1048576( 1 blks) ==> 1486881528:12
62: RAW: 15728640( 15 blks) ==> 1486881540:15728652
63: SKP: 445644800( 425 blks) ==> 1502610192:12
64: RAW: 3145728( 3 blks) ==> 1502610204:3145740
65: SKP: 30408704( 29 blks) ==> 1505755944:12
66: RAW: 13631488( 13 blks) ==> 1505755956:13631500
67: SKP: 87031808( 83 blks) ==> 1519387456:12
68: RAW: 60817408( 58 blks) ==> 1519387468:60817420
69: SKP: 1012924416( 966 blks) ==> 1580204888:12
70: RAW: 1048576( 1 blks) ==> 1580204900:1048588
71: SKP: 267386880( 255 blks) ==> 1581253488:12
72: RAW: 1048576( 1 blks) ==> 1581253500:1048588
73: SKP: 670040064( 639 blks) ==> 1582302088:12
74: RAW: 8388608( 8 blks) ==> 1582302100:8388620
75: SKP: 25165824( 24 blks) ==> 1590690720:12
76: RAW: 14680064( 14 blks) ==> 1590690732:14680076
77: SKP: 85983232( 82 blks) ==> 1605370808:12
78: RAW: 167772160( 160 blks) ==> 1605370820:167772172
79: SKP: 33554432( 32 blks) ==> 1773142992:12
80: RAW: 29360128( 28 blks) ==> 1773143004:29360140
81: SKP: 1782579200( 1700 blks) ==> 1802503144:12
82: RAW: 8388608( 8 blks) ==> 1802503156:8388620
83: SKP: 25165824( 24 blks) ==> 1810891776:12
84: RAW: 13631488( 13 blks) ==> 1810891788:13631500
85: SKP: 87031808( 83 blks) ==> 1824523288:12
86: RAW: 1048576( 1 blks) ==> 1824523300:1048588
87: SKP: 2097152( 2 blks) ==> 1825571888:12
88: RAW: 157286400( 150 blks) ==> 1825571900:157286412
89: SKP: 1048576( 1 blks) ==> 1982858312:12
90: RAW: 5242880( 5 blks) ==> 1982858324:5242892
91: SKP: 1048576( 1 blks) ==> 1988101216:12
92: RAW: 134217728( 128 blks) ==> 1988101228:134217740
93: SKP: 33554432( 32 blks) ==> 2122318968:12
94: RAW: 6291456( 6 blks) ==> 2122318980:6291468
95: SKP: 1671430144( 1594 blks) ==> 2128610448:12
96: RAW: 7340032( 7 blks) ==> 2128610460:7340044
97: SKP: 26214400( 25 blks) ==> 2135950504:12
98: RAW: 11534336( 11 blks) ==> 2135950516:11534348
99: SKP: 89128960( 85 blks) ==> 2147484864:12
100: RAW: 336592896( 321 blks) ==> 2147484876:336592908
101: SKP: 1048576( 1 blks) ==> 2484077784:12
102: RAW: 59768832( 57 blks) ==> 2484077796:59768844
103: SKP: 1048576( 1 blks) ==> 2543846640:12
104: RAW: 701497344( 669 blks) ==> 2543846652:701497356
105: SKP: 913309696( 871 blks) ==> 3245344008:12
106: RAW: 7340032( 7 blks) ==> 3245344020:7340044
107: SKP: 26214400( 25 blks) ==> 3252684064:12
108: RAW: 18874368( 18 blks) ==> 3252684076:18874380
109: SKP: 81788928( 78 blks) ==> 3271558456:12
110: RAW: 1048576( 1 blks) ==> 3271558468:1048588
111: SKP: 2097152( 2 blks) ==> 3272607056:12
112: RAW: 411041792( 392 blks) ==> 3272607068:411041804
113: SKP: 1048576( 1 blks) ==> 3683648872:12
114: RAW: 111149056( 106 blks) ==> 3683648884:111149068
115: SKP: 1486880768( 1418 blks) ==> 3794797952:12
116: RAW: 5242880( 5 blks) ==> 3794797964:5242892
117: SKP: 28311552( 27 blks) ==> 3800040856:12
118: RAW: 15728640( 15 blks) ==> 3800040868:15728652
119: SKP: 84934656( 81 blks) ==> 3815769520:12
120: RAW: 274726912( 262 blks) ==> 3815769532:274726924
121: SKP: 2097152( 2 blks) ==> 4090496456:12
122: RAW: 53477376( 51 blks) ==> 4090496468:53477388
123: SKP: 1048576( 1 blks) ==> 4143973856:12
124: RAW: 177209344( 169 blks) ==> 4143973868:177209356
125: SKP: 1504706560( 1435 blks) ==> 4321183224:12
126 CHUNK 15032385536( 14336 blks) ==> 4321183236(4121 blks)
done.
version 1.0.0
[ 0.0647 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0673 ] RCM 0 is saved as rcm_0.rcm
[ 0.0704 ] RCM 1 is saved as rcm_1.rcm
[ 0.0704 ] List of rcm files are saved in rcm_list.xml
[ 0.0705 ]
[ 0.0705 ] Signing RCM messages
[ 0.1324 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1349 ] Assuming zero filled SBK key
[ 0.1450 ]
[ 0.1451 ] Copying signature to RCM mesages
[ 0.1457 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.1466 ]
[ 0.1466 ] Parsing partition layout
[ 0.2448 ] tegraparser --pt flash.xml.tmp
[ 0.2483 ]
[ 0.2484 ] Creating list of images to be signed
[ 0.3144 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 0.3731 ]
[ 0.3732 ] Generating signatures
[ 0.3759 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.3784 ] Assuming zero filled SBK key
[ 0.5977 ]
[ 0.5978 ] Generating br-bct
[ 0.6365 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 0.6372 ] Copying Sdram info from 0 to 1 set
[ 0.6411 ] Copying Sdram info from 1 to 2 set
[ 0.6413 ] Copying Sdram info from 2 to 3 set
[ 0.7060 ]
[ 0.7061 ] Updating boot device parameters
[ 0.7089 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 0.7115 ] Warning: No sdram params
[ 0.7119 ]
[ 0.7120 ] Updating bl info
[ 0.7144 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 0.8326 ]
[ 0.8328 ] Updating secondary storage information into bct
[ 0.8357 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 0.8638 ]
[ 0.8639 ] Updating Odmdata
[ 0.8663 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0x94000
[ 0.8689 ] Warning: No sdram params
[ 0.8943 ]
[ 0.8944 ] Get Signed section of bct
[ 0.8971 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 0.9004 ]
[ 0.9005 ] Signing BCT
[ 0.9059 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.9087 ] Assuming zero filled SBK key
[ 0.9099 ]
[ 0.9100 ] Updating BCT with signature
[ 0.9127 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 0.9265 ]
[ 0.9266 ] Copying signatures
[ 0.9291 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 0.9646 ]
[ 0.9647 ] Updating BFS information on BCT
[ 0.9656 ] tegrabct --bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatebfsinfo flash.xml.bin
[ 0.9666 ] BFS:
[ 0.9685 ] 0: [PT ] flash.xml.bin (size=2138/65536)
[ 0.9688 ] 2: [VER] qspi_bootblob_ver.txt (size=153/65536)
[ 0.9814 ] BFS0: 65536 @ 224 SUM 50583031 over 3735552 bytes
[ 0.9823 ]
[ 0.9823 ] Boot Rom communication
[ 0.9838 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.9853 ] RCM version 0X210001
[ 1.4011 ] Boot Rom communication completed
[ 2.4086 ]
[ 2.4087 ] Sending BCTs
[ 2.4114 ] tegrarcm --download bct P3448_A00_4GB_Micron_4GB_lpddr4_204Mhz_P987.bct
[ 2.4138 ] Applet version 00.01.0000
[ 3.1513 ] Sending bct
[ 3.1516 ] [................................................] 100%
[ 3.3426 ]
[ 3.3427 ] Sending bootloader and pre-requisite binaries
[ 3.3455 ] tegrarcm --download ebt cboot.bin 0 0 --download rp1 tegra210-p3448-0000-p3449-0000-a02.dtb 0
[ 3.3480 ] Applet version 00.01.0000
[ 3.7678 ] Sending ebt
[ 3.8347 ]
UART
[0104.078] Enabled early print
[0104.080] [TegraBoot] (version 00.00.2018.01-l4t-175e178b)
[0104.086] Processing in recovery mode
[0104.089] A02 Bootrom Patch rev = 1023
[0104.092] Power-up reason: pmc por
[0104.096] NvTbootClockInit()
[0104.098] Established communication link with host
[0105.782] Module[6] Instance[0]Updating CLK_RST_CTRL Register [0x360] with 0x80400808
[0105.790] Odmdata from BCT: 0x00094000
[0105.794] DebugPort= 0x3
[0105.796] Reading board info Type: 1
[0105.800] Module[1] Instance[0]Updating CLK_RST_CTRL Register [0x4] with 0x1c93d288
[0105.807] Module[1] Instance[0]Updating CLK_RST_CTRL Register [0x124] with 0xc0000000
[0105.815] Module[1] Instance[0]Using Clock Divisor: 0x0[0105.820] Module[1] Instance[0]Updating CLK_RST_CTRL Register [0x124] with 0xc0000000
[0105.827] Module[1] Instance[0]Updating CLK_RST_CTRL Register [0x10] with 0x80401170
[0105.836] Module[1] Instance[0]Updating CLK_RST_CTRL Register [0x4] with 0x1c93c288
[0105.864] Module[1] Instance[2]Updating CLK_RST_CTRL Register [0xc] with 0x828ec5fa
[0105.872] Module[1] Instance[2]Updating CLK_RST_CTRL Register [0x1b8] with 0xc0000000
[0105.879] Module[1] Instance[2]Using Clock Divisor: 0x0[0105.884] Module[1] Instance[2]Updating CLK_RST_CTRL Register [0x1b8] with 0xc0000000
[0105.892] Module[1] Instance[2]Updating CLK_RST_CTRL Register [0x18] with 0x1f00208
[0105.900] Module[1] Instance[2]Updating CLK_RST_CTRL Register [0xc] with 0x828ec5f2
[0105.934] EEPROM CRC failed. Calculated crc=0x35 CRC stored = 0x9d
[0105.940] WARNING: Eeprom verification failed, Error = 20
[0105.946] Board Type: 1, Board Id: 0
[0105.949] Reading Board-ID for Board-Type-1 unsuccessful
[0105.954] BoardId read from EEPROM/NCT: 0
[0105.958] Unsupported Platform 0
[0105.961] Downloaded BCT successfully
Any progress?
Could you add below change and try?
DFLT_KERNEL_IMAGE="bootloader/${target_board}/p3450-porg/u-boot.bin";
fi;
BOOTLOADER="bootloader/${target_board}/cboot.bin";
TBCFILE="bootloader/nvtboot_cpu.bin";
BPFFILE="bootloader/t210ref/sc7entry-firmware.bin";
TOSFILE="bootloader/tos.img";
EKSFILE="bootloader/eks.img";
BCT="--bct ";
VERFILENAME="qspi_bootblob_ver.txt";
+ BCFFILE="bootloader/${target_board}/cfg/board_config_p3448.xml";
bootloader/t210ref/cfg/board_config_p3448.xml
<?xml version="1.0"?>
<!-- Nvidia Tegra board info configuration file -->
<board_configs>
- <board type="proc" id="2180" sku="0000" fab="0" />
+ <board type="proc" id="3448" sku="0000" fab="0" />
<board type="display" id="0xffff" sku="0000"/>
- <board type="pmu" id="2180" sku="0000" />
+ <board type="pmu" id="3448" sku="0000" />
</board_configs>
Hi WayneWWW,
#89 works! Nano can flash and boot now.
Thank you very much!
Then should I use i2cset to recover my EEPROM?
Why default value in board_config_p3448.xml is id=“2180”?
Is this a bug?
Yes, please restore the value inside the eeprom… normally there is no need to read board config xml file.
OK
Thanks for your support!
Hi Lonesomesnow,
[Nvidia] Please update your EEPROM with original contents and also update CRC (last byte of
root@tegra-ubuntu:/home/ubuntu# i2cdump 2 0x50 b) that is location “0xff”
Is this a bug?
[Nvidia] Actually, by default “Jetson-nano” flashing process doesn’t use “board_config_xxxxx.xml”, contents of this file is getting read by “nvtboot” from EEPROM during flash and boot, since somehow EEPROM is corrupted, so we provided this way to provide board-id/pmu-id details to “nvtboot”.
yes, this is bug, will be fixed in next release.
Hi jburman,
I recovered EEPROM with original values, and it works fine now.
Thanks for your explanation.
I have the same problem.
I did i2cset and change only macaddr,
and nano cannot boot with no debug output.
Refer to previous posts, I used “nvtboot_20190711.tar.gz”,
Tegra210_Linux_R32.3.1_aarch64.tbz2.
But Error at NvTbootLoadBinary and stop.
I’m using custom board, it’s boot from eMMC only.
Do I need nvtboot.bin for eMMC?
Could you give me some advice about this problem? Thanks.
UART
[0000.335] Platform-DebugCarveout: 0
[0000.339] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.344] Non secure mode, and RB not enabled.
[0000.361] Csd NumOfBlocks=0
[0000.372] Using BFS PT to query partitions
[0000.379] Using GPT Primary to query partitions
[0000.384] Error in NvTbootLoadBinary: 0x1 !
[0000.388] failed to load NvTbootTbootCpu from (0:3)
[0000.393] re-load NvTbootTbootCpu from (4:0)
[0000.401] Using GPT Primary to query partitions
[0000.409] Using BFS PT to query partitions
[0000.413] Error in NvTbootLoadBinary: 0x1 !
[0000.417] Error in NvTbootLoadBinary: 0x1 !
[0000.421] Error is 1
EEPROM (Before Overwrite)
root@desktop:~# i2cdump -f -y 2 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 01 00 fc 00 78 0d 02 00 04 46 00 00 00 00 00 00 ?.?.x??.?F......
10: 00 00 00 00 36 39 39 2d 31 33 34 34 38 2d 30 30 ....699-13448-00
20: 30 32 2d 34 30 30 20 46 2e 30 00 00 00 00 00 00 02-400 F.0......
30: 00 00 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff b4 ce e9 4b 04 00 31 34 32 33 30 31 ....???K?.142301
50: 39 31 31 33 32 39 35 00 00 00 00 00 00 00 00 00 9113295.........
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
90: 00 00 00 00 00 00 4e 56 43 42 1c 00 4d 31 00 00 ......NVCB?.M1..
a0: ff ff ff ff ff ff ff ff ff ff ff ff b4 ce e9 4b ............???K
b0: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ?...............
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 b6 ...............?
p3448-0000-emmc.conf
BOARDID="3448";
FAB="4";
BOARDSKU="0002" ;
BOARDREV="70";
EMMC_CFG=flash_l4t_t210_emmc_p3448.xml;
source "${LDK_DIR}/p3448-0000.conf.common";
T21BINARGS="--bins \"EBT cboot.bin; "
CMDLINE_ADD="console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1";
ROOTFSSIZE=14GiB;
VERFILENAME="emmc_bootblob_ver.txt";
20200528_UART.log (7.9 KB) 20200528_Ubuntu.log (14.3 KB)
