After kernel minimization on Jetson Nano is not starting GPU
Good afternoon, dear Nvidia! After the minor defconfig optimization I cannot start the GPU because of error:
[    6.838561] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[    6.849730] gk20a 57000000.gpu: Falling back to user helper
[    6.858213] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[    6.869482] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[    7.360706] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[    7.370335] gk20a 57000000.gpu: Falling back to user helper
[    7.378790] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[    7.390315] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[    7.619881] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[    7.629489] gk20a 57000000.gpu: Falling back to user helper
[    7.638009] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[    7.649320] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
Ubuntu 18.04.5 LTS lecor-utm ttyS0
lecor-utm login: [   15.314397] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   15.324106] gk20a 57000000.gpu: Falling back to user helper
[   15.331660] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   15.342963] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   22.010167] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   22.019948] gk20a 57000000.gpu: Falling back to user helper
[   22.027590] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   22.039024] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   22.558431] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   22.568078] gk20a 57000000.gpu: Falling back to user helper
[   22.575587] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   22.586943] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   23.540369] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   23.549968] gk20a 57000000.gpu: Falling back to user helper
[   23.557350] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   23.568601] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   24.088319] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   24.097925] gk20a 57000000.gpu: Falling back to user helper
[   24.105224] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   24.116475] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   25.072378] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   25.081955] gk20a 57000000.gpu: Falling back to user helper
[   25.089466] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   25.100779] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   25.620957] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   25.633385] gk20a 57000000.gpu: Falling back to user helper
[   25.641679] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   25.652916] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   26.603821] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   26.613444] gk20a 57000000.gpu: Falling back to user helper
[   26.620874] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   26.632140] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   27.154939] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   27.164976] gk20a 57000000.gpu: Falling back to user helper
[   27.172676] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   27.183917] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   28.143007] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   28.153381] gk20a 57000000.gpu: Falling back to user helper
[   28.162189] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   28.173432] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
[   28.694701] gk20a 57000000.gpu: Direct firmware load for gm20b/nv_acr_ucode_prod.bin failed with error -2
[   28.704329] gk20a 57000000.gpu: Falling back to user helper
[   28.711707] nvgpu: 57000000.gpu            gm20b_bootstrap_hs_acr:1279 [ERR]  nv_acr_ucode_prod.bin ucode get fail for gm20b
[   28.722988] nvgpu: 57000000.gpu            gk20a_finalize_poweron:328  [ERR]  ACR bootstrap failed
I tried to find why and that’s what discovered:
int gm20b_bootstrap_hs_acr(struct gk20a *g, struct nvgpu_acr *acr,
	struct hs_acr *acr_desc)
    acr_fw = nvgpu_request_firmware(g, acr_desc->acr_fw_name,
				NVGPU_REQUEST_FIRMWARE_NO_SOC);
		if (acr_fw == NULL) {
			nvgpu_err(g, "%s ucode get fail for %s",
				acr_desc->acr_fw_name, g->name);
			return -ENOENT;
Then I found nvgpu_request_firmware:
struct nvgpu_firmware *nvgpu_request_firmware(struct gk20a *g,
					      const char *fw_name,
					      int flags)
	return NULL;
How can I fix this? I have observed all the dependencies and the kernel starts like this, I don’t get any errors during the compilation, but nevertheless the GPU does not start…
/lib/firmware on your jetson shall have these two files. Are you sure they are still there?
./tegra21x/nv_acr_ucode_prod.bin
./gm20b/nv_acr_ucode_prod.bin
Yes - these files are in place. But why do I need this now? I can’t compile the kernel and rootfs on the target system has nothing to do with it.
Is your problem “cannot compile kernel” or “after compile kernel, some drivers are dead”?
Your error log told these files cannot get read. That is why I asked whether those file really present or not. Hope this explains your problem.
So, sorry, yes, I got confused in my own open threads. Yes, the board does not start, but these files are there - I checked. They are in the rootfs that I upload to the board.
Then you need to clarify what are those “minor defconfig optimization” you did on your side.
You need to describe everything you did on your side.
Also, please try to build kernel with default tegra_defconfig first without modifying anything. Make sure this can give you a working kernel image.
Yes, I already tried to build tegra defconfig and it worked well, so now I want to understang how to build small kernel.
My .config file:
config.txt (102.5 KB)
No, you were right, it is not such files in my rootfs but there are plenty of another files:
$ ls /lib/firmware/tegra21x
acr_ucode.bin  gpmu_ucode.bin        NETB_img.bin           pmu_bl.bin
fecs.bin       gpmu_ucode_desc.bin   nvhost_nvdec020_ns.fw  pmu_sig.bin
fecs_sig.bin   gpmu_ucode_image.bin  nvhost_nvenc050.fw     vic04_ucode.bin
gpccs.bin      gpu2cde.bin           nvhost_nvjpg010.fw
$ ls /lib/firmware/gm20b/
acr_ucode.bin  gpccs.bin            gpmu_ucode_image.bin  pmu_bl.bin
fecs.bin       gpmu_ucode.bin       gpu2cde.bin           pmu_sig.bin
fecs_sig.bin   gpmu_ucode_desc.bin  NETB_img.bin
It is strange because before the config minimization it worked well so something appears in config that requires that files…
Where can I find this files now and why if I boot with tegra_defconfig I don’t need this files?
Do I even need GK20A and ACR configs to provide GPU working on my Jetson Nano?
How I understood - for GPU working I really need this options, so I really need this files but I cannot find them into the rootfs. Could you help me with this? Maybe you could share this files with me or tell me what had been changed that this file is suddenly appears to be needed.
Actually I am not sure why you keep asking me how to find this file.
I only open my default jetpack and check the rootfs. That firmware is over there.
If this file is not present on your side, then maybe you should go back from scratch and see if you deleted it accidentally.
rootfs/lib/firmware$ find -iname “nv_acr_ucode_prod*”
Thanks, you were right. I used wrong rootfs from another release. I didn’t thought that you will change firmware from 32.6 to 32.7 and tried to use 32.7 kernel with the 32.6 rootfs, then, sorry.
But now I have another problem: nvgpu_probe:265 [INFO] platform probe failed in dmesg. Then cuda is not working.
Attaching my full dmesg:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.337-dirty (rvp@rvp-pc) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #24 SMP PREEMPT Thu Oct 26 18:56:21 MSK 2023
[    0.000000] Boot CPU: AArch64 Processor [411fd071]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  7ee00000
[    0.000000] OF: fdt: - 100000000 ,  7f200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[    0.000000] On node 0 totalpages: 1039872
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 519168 pages, LIFO batch:31
[    0.000000]   Normal zone: 8136 pages used for memmap
[    0.000000]   Normal zone: 520704 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 23 pages/cpu s53592 r8192 d32424 u94208
[    0.000000] pcpu-alloc: s53592 r8192 d32424 u94208 alloc=23*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] CPU features: enabling workaround for ARM erratum 832075
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023544
[    0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt  earlycon=uart8250,mmio32,0x70006000  root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 131072 bytes
[    0.000000] early log buf free: 29676(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3582964K/4159488K available (10750K kernel code, 1520K rwdata, 4252K rodata, 2624K init, 584K bss, 101388K reserved, 475136K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 10752 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  4288 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  2624 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  1521 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   585 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03fc8000   (    63 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0ff200000   (  4082 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[    0.000000] t210 clock and reset probe
[    0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[    0.000000] clk_cbus_recalc_rate: no gbus parent
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.001553] Console: colour dummy device 80x25
[    0.001565] console [tty0] enabled
[    0.001570] bootconsole [uart8250] disabled
[    0.001601] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[    0.001612] pid_max: default: 32768 minimum: 301
[    0.001712] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001718] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002866] sched-energy: CPU device node has no sched-energy-costs
[    0.012178] ASID allocator initialised with 65536 entries
[    0.036087] tegra-id: chipid=22117.
[    0.036097] tegra-id: opt_subrevision=0.
[    0.036114] Tegra Speedo/IDDQ fuse revision 4
[    0.036119] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[    0.036123] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[    0.036128] Tegra: CPU Speedo Value 2102, SoC Speedo Value 1972, GPU Speedo Value 2094
[    0.036132] Tegra: CPU IDDQ Value 2288, SoC IDDQ Value 2492, GPU IDDQ Value 3020
[    0.036215] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[    0.036229] DTS File Name: /home/rvp/work/nvidia/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/lecor.dts
[    0.036238] DTB Build time: Sep 13 2023 11:59:53
[    0.084446] CPU1: Booted secondary processor [411fd071]
[    0.116364] CPU2: Booted secondary processor [411fd071]
[    0.148355] CPU3: Booted secondary processor [411fd071]
[    0.148428] Brought up 4 CPUs
[    0.148434] SMP: Total of 4 processors activated.
[    0.148443] CPU features: detected feature: 32-bit EL0 Support
[    0.148670] CPU: All CPU(s) started at EL2
[    0.148687] alternatives: patching kernel code
[    0.155268] devtmpfs: initialized
[    0.187631] Initilizing CustomIPI irq domain
[    0.187893] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.187912] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.198017] pinctrl core: initialized pinctrl subsystem
[    0.198503] OS set in device tree is not L4T.
[    0.198823] regulator-dummy: no parameters
[    0.199067] Initializing plugin-manager
[    0.199193] Plugin module not found
[    0.199231] Plugin-manager not available
[    0.202410] NET: Registered protocol family 16
[    0.203557] pstore: using zlib compression
[    0.203588] console [pstore-1] enabled
[    0.203592] pstore: Registered ramoops as persistent store backend
[    0.203598] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[    0.224169] cpuidle: using governor menu
[    0.227268] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[    0.229086] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.229107] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.230725] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.233117] Serial: AMBA PL011 UART driver
[    0.233668] tegra_powergate_init: DONE
[    0.233681] DTS File Name: /home/rvp/work/nvidia/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/lecor.dts
[    0.233688] DTB Build time: Sep 13 2023 11:59:53
[    0.235465] Tegra reboot handler registered.
[    0.239719] iommu: Adding device tegra-carveouts to group 0
[    0.239808] platform tegra-carveouts: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.240126] iommu: Adding device smmu_test to group 1
[    0.240224] platform smmu_test: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.240960] mc: mapped MMIO address: 0x        (ptrval) -> 0x70019000
[    0.241018] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001c000
[    0.241075] mc: mapped MMIO address: 0x        (ptrval) -> 0x7001d000
[    0.241085] nv-tegra-mc 70019000.mc: No mssnvlink node
[    0.241099] mc-err: mcerr ops are set to t21x
[    0.250974] iommu: Adding device 70090000.xusb to group 2
[    0.251221] iommu: Adding device 70006000.serial to group 3
[    0.251289] platform 70006000.serial: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.251672] iommu: Adding device 70006040.serial to group 4
[    0.251905] iommu: Adding device 70006200.serial to group 5
[    0.252112] iommu: Adding device sound to group 6
[    0.252155] platform sound: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.252742] iommu: Adding device 7000d400.spi to group 7
[    0.252978] iommu: Adding device 7000d600.spi to group 8
[    0.253278] iommu: Adding device 50000000.host1x to group 9
[    0.253522] iommu: Adding device 54080000.vi to group 10
[    0.253881] iommu: Adding device 54600000.isp to group 11
[    0.254122] iommu: Adding device 54680000.isp to group 12
[    0.254389] iommu: Adding device tegradc.0 to group 13
[    0.254468] platform tegradc.0: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.254973] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[    0.255278] iommu: Adding device tegradc.1 to group 14
[    0.255321] platform tegradc.1: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.255820] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[    0.256038] iommu: Adding device 54340000.vic to group 15
[    0.256218] iommu: Adding device 544c0000.nvenc to group 16
[    0.256407] iommu: Adding device 54500000.tsec to group 17
[    0.256610] iommu: Adding device 54100000.tsecb to group 18
[    0.256789] iommu: Adding device 54480000.nvdec to group 19
[    0.256974] iommu: Adding device 54380000.nvjpg to group 20
[    0.257969] iommu: Adding device 546c0000.i2c to group 21
[    0.258271] iommu: Adding device 57000000.gpu to group 22
[    0.258320] platform 57000000.gpu: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.258353] platform 57000000.gpu: domain=        (ptrval) allocates as[1]=        (ptrval)
[    0.258390] platform 57000000.gpu: domain=        (ptrval) allocates as[2]=        (ptrval)
[    0.258426] platform 57000000.gpu: domain=        (ptrval) allocates as[3]=        (ptrval)
[    0.259256] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[    0.259266] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[    0.259277] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.259281] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[    0.259285] tegra-pmc: ### PMC reset status reg: 0x3
[    0.308600] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.308608] tegra-pmc: Clear bootloader IO dpd settings
[    0.308629] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[    0.308695] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[    0.308961] iommu: Adding device 70012000.se to group 23
[    0.309665] iommu: Adding device 7000c000.i2c to group 24
[    0.309901] iommu: Adding device 7000c400.i2c to group 25
[    0.310135] iommu: Adding device 7000c500.i2c to group 26
[    0.310368] iommu: Adding device 7000c700.i2c to group 27
[    0.310589] iommu: Adding device 7000d000.i2c to group 28
[    0.310856] iommu: Adding device 7000d100.i2c to group 29
[    0.311106] iommu: Adding device sdhci-tegra.3 to group 30
[    0.311157] platform sdhci-tegra.3: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.311539] iommu: Adding device sdhci-tegra.2 to group 31
[    0.311584] platform sdhci-tegra.2: domain=        (ptrval) allocates as[0]=        (ptrval)
[    0.312323] iommu: Adding device 700d0000.xudc to group 32
[    0.315210] vdd-ac-bat: 5000 mV
[    0.315524] vdd-5v0-sys: 5000 mV
[    0.316130] vdd-5v0-hdmi: 5000 mV
[    0.316567] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[    0.316803] vdd-1v8-sys: 1800 mV
[    0.317140] vdd-fan: 5000 mV
[    0.317333] vdd-fan: supplied by vdd-5v0-sys
[    0.317569] vdd-usb-vbus: 5000 mV
[    0.317766] vdd-usb-vbus: supplied by vdd-5v0-sys
[    0.318089] vdd-usb-vbus2: 5000 mV
[    0.349118] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.350592] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[    0.351712] GPIO line 6 (system-suspend-gpio) hogged as output/high
[    0.351992] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[    0.359613] eventlib_kernel: keventlib is initialized, test id: 0
[    0.359853] SCSI subsystem initialized
[    0.360025] libata version 3.00 loaded.
[    0.363753] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[    0.368327] vdd-core: 1000 <--> 1162 mV at 1075 mV
[    0.369245] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[    0.372174] vdd-ddr-1v1: 1150 mV
[    0.376252] vdd-pre-reg-1v35: 1350 mV
[    0.380167] vdd-1v8: 1800 mV
[    0.384165] avdd-sys-1v2: 1200 mV
[    0.388167] vdd-pex-1v0: 1050 mV
[    0.388772] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[    0.389294] max77620-ldo3: at 3100 mV
[    0.392168] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[    0.392726] max77620-ldo5: at 3100 mV
[    0.396173] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 2800 mV
[    0.400164] avdd-1v05-pll: 1050 mV
[    0.404163] avdd-io-hdmi-dp: 1050 mV
[    0.406515] GPIO line 505 (spmic-default-output-high) hogged as output/high
[    0.406753] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[    0.406999] max77620 4-003c: max77620 probe successful
[    0.409877] media: Linux media interface: v0.10
[    0.409928] Linux video capture interface: v2.00
[    0.410812] pps_core: LinuxPPS API ver. 1 registered
[    0.410818] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.414390] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[    0.417065] tegra210_dvfs: no clock found for sdmmc2_ddr
[    0.417082] tegra210_dvfs: no clock found for sdmmc4_ddr
[    0.417127] tegra210_dvfs: no clock found for sdmmc1_ddr
[    0.417141] tegra210_dvfs: no clock found for sdmmc3_ddr
[    0.420313] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[    0.421546] vdd-3v3-sys: 3300 mV
[    0.421884] vdd-3v3-sys: supplied by vdd-5v0-sys
[    0.421966] vdd-1v8-sys: supplied by vdd-3v3-sys
[    0.424454] vdd-usb-vbus2: supplied by vdd-3v3-sys
[    0.424856] vdd-3v3-sd: 3300 mV
[    0.425207] vdd-3v3-sd: supplied by vdd-3v3-sys
[    0.425755] avdd-io-edp-1v05: 1050 mV
[    0.426121] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[    0.426287] vdd-usb-hub-en: 5000 mV
[    0.426617] vdd-usb-hub-en: supplied by vdd-1v8-sys
[    0.427635] camchar: rtcpu character device driver loaded
[    0.428233] clocksource: Switched to clocksource arch_sys_counter
[    0.428551] VFS: Disk quotas dquot_6.6.0
[    0.428612] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.428837] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.429059] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[    0.429073]  dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[    0.429208] cma: enabled page replacement for spfn=d7000, epfn=f0000
[    0.429214] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.429223] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[    0.429245] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[    0.429251] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[    0.429270] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[    0.429276] nvmap_page_pool_init: Total RAM pages: 1014525
[    0.429281] nvmap_page_pool_init: nvmap page pool size: 126815 pages (495 MB)
[    0.429392] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.429667] misc nvmap: created heap iram base 0x        (ptrval) size (252KiB)
[    0.430478] misc nvmap: created heap vpr base 0x        (ptrval) size (409600KiB)
[    0.437476] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[    0.437832] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[    0.438054] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.438244] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.438409] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.438662] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.438667] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[    0.438794] NET: Registered protocol family 2
[    0.438936] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.460384] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.460599] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.461103] TCP: Hash tables configured (established 32768 bind 32768)
[    0.461250] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.461329] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.461563] NET: Registered protocol family 1
[    0.462023] RPC: Registered named UNIX socket transport module.
[    0.462029] RPC: Registered udp transport module.
[    0.462032] RPC: Registered tcp transport module.
[    0.462036] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.462049] PCI: CLS 0 bytes, default 64
[    0.462266] Trying to unpack rootfs image as initramfs...
[    0.752806] Freeing initrd memory: 6992K
[    0.762269] host1x 50000000.host1x: initialized
[    0.763907] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.766771] audit: initializing netlink subsys (disabled)
[    0.766825] audit: type=2000 audit(0.763:1): initialized
[    0.767379] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.773258] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.773912] ntfs: driver 2.1.32 [Flags: R/W].
[    0.776713] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.776817] io scheduler noop registered
[    0.776920] io scheduler cfq registered (default)
[    0.778960] gic 702f9000.agic: GIC IRQ controller registered
[    0.781862] iommu: Adding device 702ef000.adsp to group 33
[    0.790367] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[    0.790507] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[    0.791035] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x91e9411
[    0.791043] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[    0.793305] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[    0.793389] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[    0.793471] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[    0.793631] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[    0.793713] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[    0.793791] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[    0.793876] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[    0.793954] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[    0.794027] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[    0.794099] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[    0.799818] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[    0.801390] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[    0.803171] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[    0.804464] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[    0.804807] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[    0.805820] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.806013] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=5250, vi_iso_bw=1029000, max_bw=1029000
[    0.806253] Adding domain tsec-pd to PM domain host1x-pd
[    0.808415] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[    0.809247] tsec 54500000.tsec: initialized
[    0.810760] tsec 54100000.tsecb: initialized
[    0.811416] Adding domain nvdec-pd to PM domain host1x-pd
[    0.814742] nvdec 54480000.nvdec: initialized
[    0.815756] Adding domain vic03-pd to PM domain host1x-pd
[    0.815928] Adding domain msenc-pd to PM domain host1x-pd
[    0.816086] Adding domain nvjpg-pd to PM domain host1x-pd
[    0.820207] falcon 54340000.vic: initialized
[    0.821366] falcon 544c0000.nvenc: initialized
[    0.822614] falcon 54380000.nvjpg: initialized
[    0.826710] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=97
[    0.826768] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[    0.826794] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[    0.826995] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[    0.827073] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[    0.827077] tegra_cec 70015000.tegra_cec: probed
[    0.827097] display board info: id 0x0, fab 0x0
[    0.827165] generic_infoframe_type: 0x87
[    0.827310] tegradc tegradc.0: DT parsed successfully
[    0.827357] tegradc tegradc.0: Display dc.        (ptrval) registered with id=0
[    0.830237] tegradc tegradc.0: probed
[    0.830898] Console: switching to colour frame buffer device 80x30
[    0.830934] tegradc tegradc.0: fb registered
[    0.832196] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[    0.832320] tegradc tegradc.1: No lt-data, using default setting
[    0.832345] tegradc tegradc.1: No hpd-gpio in DT
[    0.832377] tegradc tegradc.1: DT parsed successfully
[    0.832419] tegradc tegradc.1: Display dc.        (ptrval) registered with id=1
[    0.833811] tegradc tegradc.1: dpd enable lookup fail:-19
[    0.834856] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[    1.339556] Host read timeout at address 545c00c4
[    1.340888] tegradc tegradc.1: probed
[    1.341238] tegradc tegradc.1: fb registered
[    1.342504] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[    1.343243] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[    1.343249] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[    1.343535] kfuse 7000fc00.kfuse: initialized
[    1.344473] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[    1.344481] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[    1.344491] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[    1.344507] tegradc tegradc.1: blank - powerdown
[    1.344520] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[    1.344523] Extcon DP: HPD disabled
[    1.344525] hpd: hpd_switch 0
[    1.344529] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[    1.344575] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[    1.344583] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[    1.345317] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    1.345948] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[    1.345959] vdd-cpu: 708 <--> 1322 mV at 708 mV
[    1.346357] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[    1.347530] vdd-gpu: applied init 1000000uV constraint
[    1.347537] vdd-gpu: 708 <--> 1323 mV at 997 mV
[    1.347890] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[    1.351054] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.351141] No Device Node present for smmu client: serial8250 !!
[    1.351151] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[    1.351189] iommu: Adding device serial8250 to group 35
[    1.353347] console [ttyS0] disabled
[    1.353412] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[    1.363616] console [ttyS0] enabled
[    1.364492] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[    1.364759] serial-tegra 70006200.serial: RX in PIO mode
[    1.364850] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[    1.365624] [drm] Initialized
[    1.366290] nvgpu: 57000000.gpu                       nvgpu_probe:265  [INFO]  platform probe failed
[    1.375329] brd: module loaded
[    1.380087] loop: module loaded
[    1.380706] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.382334] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.383943] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.385553] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.387160] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.388297] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.389903] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.391509] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.393132] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.394741] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.396302] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.397908] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.399515] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.401125] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.402732] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.404300] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.405906] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.407511] tegra-i2c 7000c000.i2c: no acknowledge from address 0x51
[    1.409207] tegra_profiler: version: 1.145, samples/io: 49/28
[    1.409342] tegra_profiler: auth: init
[    1.410698] THERMAL EST: found 2 subdevs
[    1.410708] THERMAL EST num_resources: 0
[    1.410715] [THERMAL EST subdev 0]
[    1.410723] [THERMAL EST subdev 1]
[    1.411230] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    1.411233] THERMAL EST: thz register success.
[    1.411381] THERMAL EST: end of probe, return err: 0
[    1.412584] sd: No Scsi addr parsed to reserve index
[    1.412650] hisi_sas: driver version v1.6
[    1.419747] tegra-xudc-new 700d0000.xudc: device count: 1
[    1.420115] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[    1.421519] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[    1.421531] tegra-xudc-new 700d0000.xudc: vbus state: 0
[    1.421570] tegra-xudc-new 700d0000.xudc: entering ELPG
[    1.421906] tegra-xudc-new 700d0000.xudc: entering ELPG done
[    1.422563] mousedev: PS/2 mouse device common for all mice
[    1.535293] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.537684] rtc rtc1: alarm rtc device
[    1.537704] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[    1.537736] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[    1.538287] i2c /dev entries driver
[    1.540411] letim 6-003a: tegracam sensor driver:letim_v2.0.6
[    1.541091] letim 6-003b: tegracam sensor driver:letim_v2.0.6
[    1.541716] letim 6-003c: tegracam sensor driver:letim_v2.0.6
[    1.542300] letim 6-003d: tegracam sensor driver:letim_v2.0.6
[    1.543013] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.545503] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[    1.545510] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[    1.545950] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.545967] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[    1.545977] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[    1.546110] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.546120] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[    1.546128] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[    1.546277] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.546286] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[    1.546293] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[    1.546502] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[    1.547293] tegra_aotag tegra-aotag: Registering sensor 0
[    1.547352] tegra_aotag tegra-aotag: Invalid temp readout
[    1.547377] tegra_aotag tegra-aotag: Invalid temp readout
[    1.547393] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[    1.547403] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[    1.548312] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.548331] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[    1.548513] tegra_aotag tegra-aotag: Invalid temp readout
[    1.548544] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[    1.548949] parse_throttle_dt_data: Num cap clks = 6
[    1.548956] parse_throttle_dt_data: clk=cclk_g type=2
[    1.548970] parse_throttle_dt_data: clk=gpu type=4
[    1.548996] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[    1.549015] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[    1.549035] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[    1.549039] parse_throttle_dt_data: clk=emc type=3
[    1.549405] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.549494] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.549617] tegra_throttle_probe: probe successful. #cdevs=4
[    1.550341] FAN dev name: pwm-fan
[    1.550429] FAN:gpio request success.
[    1.550493] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[    1.550779] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.550953] pwm_fan_driver pwm-fan: fan tach request irq success
[    1.550963] pwm_fan_driver pwm-fan: tach period: 1000
[    1.551070] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.551076] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[    1.551082] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    1.551087] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    1.551092] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.551097] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.551101] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.551106] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.551111] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.551116] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.552362] device-mapper: uevent: version 1.0.3
[    1.552662] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.558681] tegra210-cpufreq cpufreq: probe()...completed
[    1.559349] sdhci: Secure Digital Host Controller Interface driver
[    1.559351] sdhci: Copyright(c) Pierre Ossman
[    1.559353] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.559695] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[    1.564261] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[    1.566581] tegra-se 70012000.se: tegra_se_probe: complete
[    1.567064] hidraw: raw HID events driver (C) Jiri Kosina
[    1.569187] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[    1.569329] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[    1.570875] Initializing XFRM netlink socket
[    1.571095] NET: Registered protocol family 10
[    1.571485] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.571752] NET: Registered protocol family 17
[    1.571762] NET: Registered protocol family 15
[    1.572021] Registered cp15_barrier emulation handler
[    1.572027] Registered setend emulation handler
[    1.572924] registered taskstats version 1
[    1.573338] Adding domain ve2-pd to PM domain host1x-pd
[    1.573582] Adding domain ve-pd to PM domain host1x-pd
[    1.575536] isp 54600000.isp: initialized
[    1.576293] isp 54680000.isp: initialized
[    1.585960] last reset is due to software reset
[    1.585965] KERNEL: PMC reset status reg: 0x3
[    1.586027] BL: PMC reset status reg: 0x3
[    1.586030] BL: PMIC poweroff Event Recorder: 0x0
[    1.587650] clk_cbus_recalc_rate: no gbus parent
[    1.587655] clk_cbus_round_rate: no gbus parent
[    1.587658] clk_cbus_round_rate: no gbus parent
[    1.587665] clk_cbus_recalc_rate: no gbus parent
[    1.587756] clk_cbus_recalc_rate: no gbus parent
[    1.587759] clk_cbus_round_rate: no gbus parent
[    1.587762] clk_cbus_round_rate: no gbus parent
[    1.587765] clk_cbus_recalc_rate: no gbus parent
[    1.588457] tegra_dvfs: GPU-cap: registered
[    1.588506] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[    1.588509] tegra dvfs: vdd-core: nominal 1075mV, offset 1000000uV, step 12500uV, scaling enabled
[    1.588511] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[    1.589859] tegra_dvfs: vdd-gpu-vts: registered
[    1.590528] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[    1.591223] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[    1.594057] nvgpu: 57000000.gpu           gm20b_init_clk_setup_sw:1268 [INFO]  GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[    1.604308] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[    1.604337] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[    1.622559] tegra_rtc 7000e000.rtc: setting system clock to 2023-10-26 16:04:25 UTC (1698336265)
[    1.623475] vi 54080000.vi: vi_probe: ++
[    1.625678] vi 54080000.vi: initialized
[    1.627628] vi 54080000.vi: subdev nvcsi--4 bound
[    1.627640] vi 54080000.vi: subdev letim 6-003a bound
[    1.628764] vi 54080000.vi: subdev nvcsi--3 bound
[    1.628769] vi 54080000.vi: subdev letim 6-003b bound
[    1.629866] vi 54080000.vi: subdev nvcsi--2 bound
[    1.629871] vi 54080000.vi: subdev letim 6-003c bound
[    1.630969] vi 54080000.vi: subdev nvcsi--1 bound
[    1.630974] vi 54080000.vi: subdev letim 6-003d bound
[    1.632672] Disable partitions left on by BL
[    1.632675]   disb
[    1.632826] bwmgr: missing cdev-type property
[    1.632914] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[    1.632919] DRAM derating cdev registered.
[    1.635148] Freeing unused kernel memory: 2624K
[    1.660809] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.665013] Root device found: mmcblk0p1
[    1.665208] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.669460] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.669574] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.669682] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.672588]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9
[    1.742525] tegra-pcie 1003000.pcie: link 0 down, retrying
[    1.852248] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[    1.852252] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[    1.872050] Found dev node: /dev/mmcblk0p1
[    1.893854] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.895610] Rootfs mounted over mmcblk0p1
[    1.910862] Switching from initrd to actual rootfs
[    2.051068] cgroup: cgroup2: unknown option "nsdelegate"
[    2.059946] systemd[1]: systemd 254.5-1-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    2.059960] systemd[1]: Detected architecture arm64.
[    2.060369] systemd[1]: Warning! Reported kernel version 4.9.337-dirty is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
[    2.062479] systemd[1]: Hostname set to <alarm>.
[    2.077387] systemd[1]: bpf-lsm: BPF LSM hook not enabled in the kernel, BPF LSM not supported
[    2.150274] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.350435] systemd[1]: /etc/systemd/system/nvs-service.service:38: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.354336] systemd[1]: /etc/systemd/system/nvargus-daemon.service:40: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    2.369096] systemd[1]: Queued start job for default target Graphical Interface.
[    2.372704] systemd[1]: Created slice Slice /system/getty.
[    2.373433] systemd[1]: Created slice Slice /system/modprobe.
[    2.374134] systemd[1]: Created slice Slice /system/serial-getty.
[    2.374595] systemd[1]: Created slice User and Session Slice.
[    2.374770] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.374930] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.375036] systemd[1]: Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    2.375124] systemd[1]: Reached target Local Encrypted Volumes.
[    2.375196] systemd[1]: Reached target Local Integrity Protected Volumes.
[    2.375288] systemd[1]: Reached target Path Units.
[    2.375340] systemd[1]: Reached target Remote File Systems.
[    2.375379] systemd[1]: Reached target Slice Units.
[    2.375442] systemd[1]: Reached target Swaps.
[    2.375501] systemd[1]: Reached target Local Verity Protected Volumes.
[    2.375719] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.379338] systemd[1]: Listening on Process Core Dump Socket.
[    2.379696] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.380000] systemd[1]: Listening on Journal Socket.
[    2.380443] systemd[1]: Listening on Network Service Netlink Socket.
[    2.380818] systemd[1]: Listening on udev Control Socket.
[    2.381080] systemd[1]: Listening on udev Kernel Socket.
[    2.382982] systemd[1]: Mounting Huge Pages File System...
[    2.384979] systemd[1]: Mounting POSIX Message Queue File System...
[    2.386808] systemd[1]: Mounting Kernel Debug File System...
[    2.387072] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    2.389714] systemd[1]: Mounting Temporary Directory /tmp...
[    2.389906] systemd[1]: Create List of Static Device Nodes was skipped because of an unmet condition check (ConditionFileNotEmpty=/lib/modules/4.9.337-dirty/modules.devname).
[    2.392642] systemd[1]: Starting Load Kernel Module configfs...
[    2.395175] systemd[1]: Starting Load Kernel Module dm_mod...
[    2.397576] systemd[1]: Starting Load Kernel Module drm...
[    2.400363] systemd[1]: Starting Load Kernel Module fuse...
[    2.402694] systemd[1]: Starting Load Kernel Module loop...
[    2.403402] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    2.403413] systemd[1]: systemd-journald.service: (This warning is only shown for the first unit using IP firewalling.)
[    2.404947] systemd[1]: Starting Journal Service...
[    2.408421] systemd[1]: Starting Load Kernel Modules...
[    2.410528] systemd[1]: Starting Generate network units from Kernel command line...
[    2.410678] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[    2.413033] systemd[1]: Starting Remount Root and Kernel File Systems...
[    2.415338] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[    2.417708] systemd[1]: Starting Coldplug All udev Devices...
[    2.422366] systemd[1]: Mounted Huge Pages File System.
[    2.422762] systemd[1]: Mounted POSIX Message Queue File System.
[    2.423382] systemd[1]: Mounted Kernel Debug File System.
[    2.423759] systemd[1]: Mounted Temporary Directory /tmp.
[    2.424914] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    2.425312] systemd[1]: Finished Load Kernel Module configfs.
[    2.428667] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    2.429049] systemd[1]: Finished Load Kernel Module dm_mod.
[    2.430192] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    2.430569] systemd[1]: Finished Load Kernel Module drm.
[    2.431677] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    2.432076] systemd[1]: Finished Load Kernel Module fuse.
[    2.433247] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    2.433678] systemd[1]: Finished Load Kernel Module loop.
[    2.434654] systemd[1]: Finished Load Kernel Modules.
[    2.435337] systemd[1]: Finished Generate network units from Kernel command line.
[    2.435989] systemd[1]: Finished Remount Root and Kernel File Systems.
[    2.437003] systemd[1]: Reached target Preparation for Network.
[    2.437341] systemd[1]: FUSE Control File System was skipped because of an unmet condition check (ConditionPathExists=/sys/fs/fuse/connections).
[    2.439185] systemd[1]: Mounting Kernel Configuration File System...
[    2.441429] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    2.443689] systemd[1]: Starting Load/Save OS Random Seed...
[    2.443853] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[    2.445034] systemd-journald[1488]: Collecting audit messages is disabled.
[    2.445953] systemd[1]: Starting Apply Kernel Variables...
[    2.447702] systemd[1]: Mounted Kernel Configuration File System.
[    2.552241] tegra-pcie 1003000.pcie: link 0 down, retrying
[    2.554260] tegra-pcie 1003000.pcie: link 0 down, ignoring
[    2.596882] systemd[1]: Finished Apply Kernel Variables.
[    2.597399] systemd[1]: Started Journal Service.
[    2.623657] systemd-journald[1488]: Received client request to flush runtime journal.
[    2.654756] systemd-journald[1488]: /var/log/journal/b50e63a22b7f423cb41ca0b07c14da26/system.journal: Journal file uses a different sequence number ID, rotating.
[    2.654770] systemd-journald[1488]: Rotating system journal.
[    2.659616] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[    2.659623] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.659627] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[    2.659631] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[    2.659636] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.659658] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[    2.659839] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.660029] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.660134] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[    2.660160] pci 0000:01:00.0: reg 0x10: [io  0x0000-0x00ff]
[    2.660193] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit pref]
[    2.660216] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit pref]
[    2.660379] pci 0000:01:00.0: supports D1 D2
[    2.660383] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.672291] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.672324] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[    2.672329] pci 0000:00:02.0: BAR 13: assigned [io  0x1000-0x1fff]
[    2.672336] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[    2.672356] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[    2.672374] pci 0000:01:00.0: BAR 0: assigned [io  0x1000-0x10ff]
[    2.672383] pci 0000:00:02.0: PCI bridge to [bus 01]
[    2.672387] pci 0000:00:02.0:   bridge window [io  0x1000-0x1fff]
[    2.672393] pci 0000:00:02.0:   bridge window [mem 0x20000000-0x200fffff 64bit pref]
[    2.672640] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[    2.672644] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.672649] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[    2.672731] aer 0000:00:02.0:pcie002: service driver aer loaded
[    2.672901] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[    2.672920] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[    2.694293] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[    2.694375] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 00:04:4b:e9:fb:54 from device tree
[    2.695003] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[    2.695020] r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    2.990401] proc: unrecognized mount option "hidepid=invisible" or missing value
[    3.202829] eth0: 0xffffff8009aa3000, 00:04:4b:e9:fb:54, IRQ 407
[    3.280262] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.550457] proc: unrecognized mount option "hidepid=invisible" or missing value
[    3.840235] random: crng init done
[    3.984267] using random self ethernet address
[    3.984271] using random host ethernet address
[    4.131880] Mass Storage Function, version: 2009/09/11
[    4.131886] LUN: removable file: (no medium)
[    4.135382] using random self ethernet address
[    4.135387] using random host ethernet address
And I cannot understand why.
I hope it is the final problem that I encounter on the road to obtain the minimal kernel that possible. And it is the only one problem in dmesg.
Fixed lots time ago
@ATAineri I’m seeing a similar issue. How did you fix it?
Hi, Sanjay! Send me your dmesg
