Greetings,
On our mature custom TX2 carrier board, we successfully use UPHY Lane Configuration #6, with a custom DTB file, and L4T version 32.4. With this configuration we are able to utilize a WiFi module inserted into the M.2 interface.
We are in the process of upgrading to L4T 33.7.1 on the same TX2 carrier board. The WiFi module mentioned above is not detected and the device are no longer appears in the output of the lspci command. Inspection of the system regarding the use of UPHY Lane Configuration #6 all looks good and is included below. Is it possible that switching to L4T 33.7.1 requires changes to our DTB file? Are there any other possible causes we should consider?
Best Regards,
Todd
ODMDATA is correct
/# ./odmtool --read
Current ODMDATA value: 0x3090000
Lane mappings look good: pcie-controller: 2x1, 1x1, 1x1 configuration
/# dmesg | grep -i pcie
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.presilicon=true firmware_class.path=/etc/firmware video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1 root=UUID=ba1eadef-edc1-4ce1-b7d5-86bc0a65e794 ro rootwait gasket.dma_bit_mask=32 pcie_aspm=off l4tver=32.7.1 isolcpus=1,2,3 sdhci_tegra.en_boot_part_access=1
[ 0.000000] PCIe ASPM is disabled
[ 0.535241] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 1.314953] iommu: Adding device 10003000.pcie-controller to group 49
[ 1.321702] arm-smmu: forcing sodev map for 10003000.pcie-controller
[ 2.258318] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[ 2.276438] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 2.276785] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[ 2.278948] tegra-pcie 10003000.pcie-controller: probing port 1, using 1 lanes
[ 2.281108] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 2.770822] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 3.769473] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 4.181852] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 4.183866] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 4.585247] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 4.988426] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 5.391131] tegra-pcie 10003000.pcie-controller: link 1 down, retrying
[ 5.399732] tegra-pcie 10003000.pcie-controller: link 1 down, ignoring
[ 5.810989] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 6.219192] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 6.637002] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 6.645151] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 6.959125] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 6.968751] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
The values below match these expected values: pcie/lane2, pcie/lane4, sata/lane5, xusb/lane0 and xusb/lane1
/# ls -lah /proc/device-tree/chosen/plugin-manager/odm-data/enableuphy
/proc/device-tree/chosen/plugin-manager/odm-data/enable-pcie-on-uphy-lane2
/proc/device-tree/chosen/plugin-manager/odm-data/enable-pcie-on-uphy-lane4
/proc/device-tree/chosen/plugin-manager/odm-data/enable-sata-on-uphy-lane5
/proc/device-tree/chosen/plugin-manager/odm-data/enable-xusb-on-uphy-lane0
/proc/device-tree/chosen/plugin-manager/odm-data/enable-xusb-on-uphy-lane1
USB Controllers are showing up correctly
/# lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/3p, 5000M
|__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/7p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=tegra-xusb/4p, 480M
|__ Port 2: Dev 7, If 0, Class=Hub, Driver=hub/7p, 480M
|__ Port 7: Dev 8, If 0, Class=Human Interface Device, Driver=usbhid, 480M
CPU Isolation is correct
/# cat /sys/devices/system/cpu/isolated
1-3
