After patching RT-Kernel Jetson AGX can´t shut down
Hallo,
i patched a RT-Kernel on my Nvidia Jetson AGX Xavier.
It looks everything works but if i try to shut down my xavier the operating system goes down quite normal.
But the LED in the front stays on.
Are thre any issues on the RT-Kernel?
Does that LED stays on without RT patch?
  1. Could you try to remove the HDMI cable during shutdown.
  2. Change the cpu governor to userspace to try.
Hi vflorianehnle,
We haven’t heard back from you in a couple weeks, so marking this topic not an issue.
Please open a new forum issue when you are ready and we’ll pick it up there.
Hi ,
I am facing the same issue on Jetson AGX Xavier board. I installed the RT Linux on the Xavier board and it seems everything works fine. But when I shut down the system, the LED continues to glow. I have to press the shutdown button for 10 seconds in order to shut the system.
Hi anandprakaas,
Please help to open a new topic for your issue. Thanks
Created a new topic:
