Hi we found a xavier module ,after power off,enter the recovery mode, Follow the system swiping tutorial reflash the board, but will occur the error(as below picture),after return, it stays in recovery mode, has tried many time, allways come the same circumstance, do your have any suggestion for this case,thanks
I cannot tell what is wrong according to this picture.
Please refer to this page and dump the log.
Hi Wayne:
its stuck in this screen, cant write any command and got the log, can we reflash this with other way?
thanks
Please do read the page I shared. I am asking you not to use sdkm but directly using flash.sh to do the work and dump the log.
In that case, nothing should get stuck…
Hi Wayne:
thanks, please help check the log,
SDKM_logs_JetPack_4.4_Linux_for_Jetson_AGX_Xavier_2020-08-26_17-37-45.zip (151.3 KB)
