1766 CHUNK 15288238080(3732480 blks) ==> 2372330212(579177 blks)
done.
system.img built successfully.
copying dtbfile(/home/joel/Downloads/TK1/Linux_for_Tegra_tk1/kernel/dtb/tegra124-jetson_tk1-pm375-000-c00-00.dtb)… done.
copying cfgfile(/home/joel/Downloads/TK1/Linux_for_Tegra_tk1/bootloader/ardbeg/cfg/gnu_linux_fastboot_emmc_full.cfg) to flash.cfg… done.
creating gpt(ppt.img)…
*** GPT Parameters ***
Device Sector Size ------- 512
device size -------------- 15766388736
bootpart size ------------ 8388608
userpart size ------------ 15758000128
Erase Block Size --------- 2097152
FS Buffer size ----------- 4096
Partition Config file ---- flash.cfg
Visible partition flag — GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(20 partitions) ***
[ BCT] BH 0 16383 8.0MiB
[ PPT] UH 0 4095 2.0MiB ppt.img
[ PT] UH 4096 8191 2.0MiB
[ EBT] UH 8192 16383 4.0MiB u-boot.bin
[ LNX] UH 16384 49151 16.0MiB
[ SOS] UH 49152 61439 6.0MiB
[ NVC] UH 61440 65535 2.0MiB
[ MPB] UH 65536 77823 6.0MiB
[ MBP] UH 77824 90111 6.0MiB
[ GP1] UH 90112 94207 2.0MiB
[ APP] UV 94208 29954047 14580.0MiB system.img
[ DTB] UV 29954048 29962239 4.0MiB tegra124-jetson_tk1-pm375-000-c00-00.dtb
[ EFI] UV 29962240 30093311 64.0MiB
[ USP] UV 30093312 30101503 4.0MiB
[ TP1] UV 30101504 30109695 4.0MiB
[ TP2] UV 30109696 30117887 4.0MiB
[ TP3] UV 30117888 30126079 4.0MiB
[ WB0] UV 30126080 30130175 2.0MiB
[ UDA] UV 30130176 30773247 314.0MiB
[ GPT] UH 30773248 30777343 2.0MiB gpt.img
copying flasher(/home/joel/Downloads/TK1/Linux_for_Tegra_tk1/bootloader/ardbeg/fastboot.bin)… done.
Existing flashapp(/home/joel/Downloads/TK1/Linux_for_Tegra_tk1/bootloader/nvflash) reused.
*** Flashing target device started. ***
./nvflash --bct PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg --setbct --configfile flash.cfg --create --bl fastboot.bin --odmdata 0x6009C000 --go
Nvflash 4.13.0000 started
BR_CID: 0x34001001740de1001c0000000b058340
rcm version 0X400001
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x00000001740de1001c0000000b058340
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59637/59637 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader – load address: 0x83d88000 entry point: 0x83d88000
sending file: fastboot.bin - 594363/594363 bytes sent
fastboot.bin sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ML execution and Cpu Handover took 1 Secs
Partition backup took 0 Secs
setting device: 2 3
deleting device partitions
creating partition: BCT
creating partition: PPT
creating partition: PT
creating partition: EBT
creating partition: LNX
creating partition: SOS
creating partition: NVC
creating partition: MPB
creating partition: MBP
creating partition: GP1
creating partition: APP
creating partition: DTB
creating partition: EFI
creating partition: USP
creating partition: TP1
creating partition: TP2
creating partition: TP3
creating partition: WB0
creating partition: UDA
creating partition: GPT
sending file: ppt.img
\ 2097152/2097152 bytes sent
ppt.img sent successfully
padded 12 bytes to bootloader
sending file: u-boot.bin - 440016/440016 bytes sent
u-boot.bin sent successfully
sending file: system.img
| 2372330212/2372330212 bytes sent
system.img sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb - 59637/59637 bytes sent
sending file: gpt.img
gpt.img sent successfully
Create, format and download took 216 Secs
Time taken for flashing 219 Secs
*** The target ardbeg has been flashed successfully. ***
Reset the board to boot from internal eMMC.
