After running deepstream for a period of time, the perf module stopped printing
**• Hardware Platform (Jetson / GPU)6.1
**• DeepStream Version 7.1
**• JetPack Version (valid for Jetson only)6.1
**• TensorRT Version 10.3
**• NVIDIA GPU Driver Version (valid for GPU only)540.4.0
The Type of this mechine is Orin AGX 64G
log.txt (521.5 KB)
Is it possible the issue related with the huge log file size in this topic: Log problem - Intelligent Video Analytics / Metropolis Microservices for Jetson - NVIDIA Developer Forums?
No , it is deepstream’s problem [After running deepstream for a period of time, the perf module stopped printing]
I remember you said the deepstream works fine after 8 days stress test. How long time you meet this problem in this topic?
2 weeks
I would like to describe my problem in detail,
Yesterday, there was a situation where perf did not print,
Active sources : 0
Mon Jan 6 20:20:17 2025
**PERF:
0.00 (16.85) 0.00 (16.15) 0.00 (17.08) 0.00 (16.28) 0.00 (15.77) 0.00 (16.91) 0.00 (17.71)
This is the last time,
This problem has been reproduced. The last meeting was on the 2nd
But yesterday I also mentioned that the logs are quite large, and this phenomenon is also difficult to reproduce.
So yesterday’s log issue was a prelude to this problem.
This is a partial log of the situation where perf did not print yesterday.
In fact, the core issue is that Deepstream does not print, and the large logs are just a prelude.
Did I not make myself clear?
Because if the log is large, it may be difficult to locate the problem, so we proposed the requirement of storing yesterday’s log size on a daily basis
So let’s see if you can get the message I want to convey on your end
So now there are two issues, one is the problem with Deepstream, and the other is to lay the groundwork for better analysis from Deepstream logs
I can first solve the requirement of logs, and then when the log size is not large, I can find a way to send more logs for analysis. After running deepstream for a period of time, The perf module stopped printing issue. Extracting only a small portion of the logs may not necessarily provide comprehensive information
