It successfully updated itself to 36.3.0 (with some restarts), then I have load on the USB the Jetson Orin Nano Developer Kit JetPack 6.2, it run some work, restarted I think 3 times, yet then never actually trigger of the firmware update. When I run it again (even with new USB card and reloaded JetPack 6.2) it is stack on black screen with the cursor pulsing.
I have tried to install SDKManger, it worked well (debian 12), but as my OS is not Ubuntu 22.04, it doesnβt allow me to use it to make the final update to 36.4.3.
If you have any tips how to fix it, reset, or do some force update either through SD card or SDKManger, please let me know. As otherwise, could it be physical failure of the board?
I saw network setting log in screen shot. It might be a network issue, please disable the firewall and run sdk manager again.
Also EXPORT LOGS to provide the full log for us to review.
There is an alternative method manual flash when sdk manager have some problems:
