After switch migration, mlag keeps showing peering, how should I fix it?
After the migration of two switches that normally run mlag, all the service interfaces of the standby switch are Down, and checking the mlag status shows peering. How can I fix it?
master:
Admin status: Enabled
Operational status: Up
Reload-delay: 30 sec
Keepalive-interval: 1 sec
Upgrade-timeout: 60 min
System-mac: 00:00:5E:00:01:F7
MLAG Ports Configuration Summary:
Configured: 48
Disabled: 0
Enabled: 48
MLAG Ports Status Summary:
Inactive: 4
Active-partial: 0
Active-full: 44
MLAG IPLs Summary:
ID Group Vlan Operational Local Peer Up Time Toggle Counter
Port-Channel Interface State IP address IP address
1 Po1 4000 Up 10.0.0.2 10.0.0.1 6 days, 21:45:44 5
MLAG Members Summary:
System-id State Hostname
1C:34:DA:EE:FF:48 Up
1C:34:DA:EE:FD:C8 Peering sr102-F05-41
standby:
Configured: 47
Disabled: 47
Enabled: 0
Inactive: 47
Active-partial: 0
Active-full: 0
MLAG IPLs Summary:
1 Po1 4000 Up 10.0.0.1 10.0.0.2 6 days, 21:44:39 5
1C:34:DA:EE:FF:48 Peering sr102-F06-41
Hello!
Can you try to remove then re-add the IPL link and see if that helps:
  • no interface ethernet 1/x channel-group
  • no interface port-channel 1
Then add the configuration for IPL and member interfaces back into the port-channel.
If this does not help, please open a case with support team for further investigation.
