After using nvmultiurisrcbin and using nvvideoconvert and capsfilter in the pipeline, the program Segmentation fault (core dumped)
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version docker-ds6.3
• TensorRT Version 8.5
• NVIDIA GPU Driver Version (valid for GPU only) 550.142
Here’s how my pipes are connected:
        self.nvmultiurisrcbin.link(self.queue1)
        self.queue1.link(self.preprocess)
        self.preprocess.link(self.queue2)
        self.queue2.link(self.pgie)
        self.pgie.link(self.queue3)
        self.queue3.link(self.converter)
        self.converter.link(self.queue4)
        self.queue4.link(self.capsfilter)
        self.capsfilter.link(self.queue5)
        if self.nvdslogger:
            self.queue5.link(self.nvdslogger)
            self.nvdslogger.link(self.tiler)
        else:
            self.queue5.link(self.tiler)
        self.tiler.link(self.queue6)
        self.queue6.link(self.nvvidconv)
        self.nvvidconv.link(self.queue7)
        self.queue7.link(self.nvosd)
        self.nvosd.link(self.queue8)
        self.queue8.link(self.sink)
The self.converter and self.capsfilter plugins look like this:
self.converter = Gst.ElementFactory.make("nvvideoconvert", f"converter-2RBGA")
        self.converter.set_property("gpu_id", GPU_ID)
        self.capsfilter = Gst.ElementFactory.make("capsfilter", f"capsfilter-2RGBA")
        caps = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
        # self.converter.set_property("nvbuf-memory-type", 0)
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        self.converter.set_property("nvbuf-memory-type", mem_type)
        self.tiler.set_property("nvbuf-memory-type", mem_type)
        self.capsfilter.set_property("caps", caps)
The reason I added these two plugins in the pipeline is that I need to convert the raw images to opencv format images in the probe function
When I used these two plugins, the video stream would crash after it finished. Segmentation fault (core dumped), but not when I comment out these two plugins
Here’s my code
code.zip (16.6 KB)
Please follow the platform compatibility first. Installation — DeepStream documentation
My graphics card is 4080s, it doesn’t seem to fit R525.125.06
  1. The DeepStream 6.3 nvdsmultiurisrcbin is just alpha version, there may be some bug in it.
  2. Have you debug with your code to find out whether the segmentation fault is related to the DeepStream APIs? Can the sample /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-server work for your case?
Seems you need to upgrade to the latest DeepStream version.
I encountered another phenomenon on the basis of this environment and program, when I used nvmultiurisrcbin plugin to open the code stream of two cameras, I manually unplugged the network cable of one camera, after a period of time, the program crashed, I wanted to test whether it was a problem with the graphics card driver, I was on the 3060 graphics card this phenomenon occurred, I can’t find the R525.125.06 driver on the official website, can you give me a connection, or can you check if there is this problem before
The 525.125.06 driver can be downloaded here Linux x64 (AMD64/EM64T) Display Driver 525.125.06 | Linux 64-bit | NVIDIA
I just tried it, the environment didn’t change, and when I unplugged one of the cameras, the phenomenon was the same
This is the configuration file
Please upgrade to the latest DeepStream version.
Is this a problem with properly installing docker-ds6.3? My 3060 uninstall 550.142 driver install 525.125 driver will give an error.
No. The latest DeepStream fixed many bugs. It is better to use the latest DeepStream version.
May I ask if this is an answer to my question about the program exception after the abnormal closure of the code stream above? If ds6.3 is normally installed, this problem will not be encountered, I want to use it on 6.3 as much as possible, and reinstall the operating system to try
The answer is for your question of “Is this a problem with properly installing docker-ds6.3?”
There is no clear clue to show what is the root cause of the program exception problem.
