Agent Debugging and Observability
Hi Community, Hope you’ll doing well. I wanted to ask for your feedback on something I built.
It’s a debugger for AI agent workflows. You can inspect each step, override a parameter, and replay from that point, and an RCA agent finds the root cause automatically.
Here’s demo: Debugging Agentic Systems with AGDebugger - Oracle Internship | Loom
Does this match the failure modes you’ve seen with agents in production? Would really value your take.
Hi, I am interested in the authorization boundary between parameter override and replay, especially if replay can call live tools.
My T0 requirement is that the task owner defines, before execution, who may intervene, which changes are permitted, what invalidates permission, and who receives control on STOP. A diagnostic recommendation must not become its own restart authorization.
Does an override create an explicitly authorized new run, or continue under the previous run’s authority? If a tool committed but its response was lost, replaying that step could duplicate an external effect even though the workflow appears paused.
A minimal test: use a mock write tool with an append-only effect log; commit once, drop the response, then request an override and replay. Declare the authorized outcome beforehand. Require reconciliation of the committed state, rejection of unauthorized replay before another write, and a STOP result identifying the failed condition and responsible decision-maker. Include a positive control where a separately permitted new action executes once.
Where is this restart decision enforced? If replay is entirely isolated, what prevents it from reaching live capabilities? The post does not specify that boundary. I want to verify the actual mechanism, rather than treat debugging capability as a closed authorization loop.
Hii, Thanks for raising this. An important distinction in our current implementation is that the override mechanism will be restricted to health-check operations; it does not grant additional privileges to execute arbitrary tools.
However, the authorization boundary between resuming a workflow and preventing duplicate side effects during replay is a separate concern. The health-check restriction alone does not establish that guarantee, particularly when a tool invocation may have committed before its response was lost. The endpoints need to be idempotent for ideal case to stop any incurring errors.
Your proposed mock-write test is a useful way to validate that behavior. I’ll distinguish the guarantees provided by the current override mechanism from any stronger guarantees around replay authorization and side-effect reconciliation.
Thanks for clarifying that health-check restrictions alone do not guarantee replay authorization or prevent duplicate side effects.
I have built a shared architecture with function contracts designed for controllable costs and safe execution. Here is my public demo for reference. If you’re interested, feel free to contact me, Shen Yao 888π / Wen-Yao Hsu. I can personally design deterministic function rules for your specific requirements.
