We want SOM work at -40 degeree,so we decide to add a heater for SOM,When at -40,we disable rhe MODULE_POWER_ON signal and heater the SOM temperature to above -25, when temperature rises above -25,then we enable MODULE_POWER_ON signal to power on the SOM,please help to evaluate if it is possibile,thanks,for hardware,we decide to add a AND logic for MODULE_POWER_ON signal before it send to SOM,only tempreature rise above -25,we enable the MODULE_POWER_ON signal.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
- TensorFlow: Installing TensorFlow for Jetson Platform - NVIDIA Docs
- PyTorch: Installing PyTorch for Jetson Platform - NVIDIA Docs
We also have containers that have frameworks preinstalled:
Data Science, Machine Learning, AI, HPC Containers | NVIDIA NGC
3. Tutorial
Startup deep learning tutorial:
- Jetson-inference: Hello AI World guide to deploying deep-learning inference networks and deep vision primitives with TensorRT and NVIDIA Jetson
- TensorRT sample: Jetson/L4T/TRT Customized Example - eLinux.org
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
could you read my questions carefully? i think you dont get it.
It is OK for module as its lowest storage temp is -40C and -25C @ operational
thanks ,i maily want to confirm if the control logic for SOM has any risk? as we add
AND logic forMODULE_POWER_ON signal compare to carrier board hardware deisn,thanks
Your power delivery could itself just not power the Jetson until a certain temperature is reached. It sounds like you want this to be part of a custom carrier board though, and I couldn’t say if that particular signal is sufficient for your purposes.
I would be tempted to require temperature to be above a certain value for some amount of time to give components time to warm up.
