I’m working on Jetpack 4.6 with AGX, a new issue pop up, the USB network card cannot be detected automatically during L4T boot up, I have to unplug the usb cable and plug again, the NIC worked properly.
here is the dmesg with “USB device” related, we can see during 1st time boot up, only usb hub ([ 2.069463] usb 1-1: New USB device found, idVendor=2109, idProduct=2817) was found, and no usb NIC info. when I re-plug the usb NIC, firstly USB hub found ([ 233.649439] usb 1-1: New USB device found, idVendor=2109, idProduct=2817), then the USB NIC was found and configured properly.([ 234.389436] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8153).
Highly appreciation for any comments or help.
Willian
~$ dmesg | grep “USB device”
[ 1.715809] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.715816] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.717316] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.717322] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.043488] usb 1-1: new high-speed USB device number 2 using tegra-xusb
[ 2.069470] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.783449] usb 1-1.3: new high-speed USB device number 3 using tegra-xusb
[ 2.804198] usb 1-1.3: New USB device found, idVendor=0bda, idProduct=8151
[ 2.804202] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 3.769655] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.769660] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.770436] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.770440] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 233.627505] usb 1-1: new high-speed USB device number 4 using tegra-xusb
[ 233.649452] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 234.367552] usb 1-1.3: new high-speed USB device number 5 using tegra-xusb
[ 234.389464] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 234.528052] usb 1-1.3: reset high-speed USB device number 5 using tegra-xusb
