AGX deepstream5.0 multi udpsink output cause "*** stack smashing detected ***: <unknown> terminated" error
• Hardware Platform (Jetson / GPU) Jetson AGX 32G
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version 7.1
• Issue Type( questions, new requirements, bugs) bugs
  1. config 16 rstp streams input
  2. config 16 udp sink rtsp stream output
  3. use gst command push these 16 output rstp to stream server.
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8555/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8556/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8557/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8558/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8559/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8560/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8561/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8562/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8563/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8564/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8565/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8566/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8567/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8568/ds-test ***
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8569/ds-test ***
cmd:
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8554/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture0’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8555/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture1’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8556/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture2’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8557/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture3’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8558/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture4’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8559/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture5’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8560/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture6’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8561/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture7’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8562/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture8’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8563/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture9’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8564/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture10’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8565/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture11’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8566/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture12’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8567/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture13’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8568/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture14’ > /dev/null 2>&1 &
nohup gst-launch-1.0 -e -v rtspsrc location=‘rtsp://localhost:8569/ds-test’ latency=1000 ! rtph264depay ! h264parse ! flvmux streamable=true ! rtmpsink async=false location=‘rtmp://localhost:1935/live/capture15’ > /dev/null 2>&1 &
when run sometime ,it will cause
***** stack smashing detected *: terminated
Aborted (core dumped)
but when the streams count down to 12 streams, it will works well.
Can you try to get the core dump log of the crash?
